FLtractor 223 #1 Posted December 3, 2025 Will these fit a 856 23x8x12.. worth the $ for what they are? 200 mile roundtrip drive Only pictures from listing. Thank you 1 Share this post Link to post Share on other sites
adsm08 5,148 #2 Posted December 3, 2025 Probably not. They are too narrow to fit the factory wheels, and those look like 6-lugs, the originals for an 856 are 5-lug. Share this post Link to post Share on other sites
ebinmaine 80,710 #3 Posted December 3, 2025 Doesn't seem so. The 8.8- 22 is likely the size. Quite a bit bigger than your own. 22 is the rim size. 3 Share this post Link to post Share on other sites
FLtractor 223 #4 Posted December 3, 2025 3 minutes ago, ebinmaine said: Doesn't seem so. The 8.8- 22 is likely the size. Quite a bit bigger than your own. 22 is the rim size. The add says 8.8-22. Can you tell me what that number means in relation to my 856 rear of 23x8x12? What would or should I go with? 1 Share this post Link to post Share on other sites
FLtractor 223 #5 Posted December 3, 2025 4 minutes ago, ebinmaine said: Doesn't seem so. The 8.8- 22 is likely the size. Quite a bit bigger than your own. 22 is the rim size. Thank you for prompt reply 2 Share this post Link to post Share on other sites
ebinmaine 80,710 #6 Posted December 3, 2025 1 minute ago, FLtractor said: The add says 8.8-22. Can you tell me what that number means in relation to my 856 rear of 23x8x12? What would or should I go with? I'm not positive here.... I believe the 8.8 is the "advertised width" of the tire. The 22 should be the wheel diameter. Many (most?) Garden Tractor tires are on a 12" wheel. The middle number is the width. The first number is the outer diameter of the tire. There are a few tires that don't get even remotely close to the actual size with their advertised size. You may very well find that getting two new tires is far easier and less expensive than shopping for usable used ones. Factor in your own time and fuel. 5 Share this post Link to post Share on other sites
ri702bill 13,067 #7 Posted December 3, 2025 10 hours ago, ebinmaine said: There are a few tires that don't get even remotely close to the actual size with their advertised size. Deestones are notorious for running on the SMALL end of the scale... 2 Share this post Link to post Share on other sites
ri702bill 13,067 #8 Posted December 3, 2025 (edited) 13 hours ago, FLtractor said: Will these fit a 856 23x8x12.. That size is not original to a 856. The 6-12 would be Those are from a later tractor like a B or C series - and the wider tires DO give you a wider track and more stability. New same size as what you have tires may be the way to go. Edited December 3, 2025 by ri702bill Share this post Link to post Share on other sites
FLtractor 223 #9 Posted December 3, 2025 (edited) 4 hours ago, ri702bill said: That size is not original to a 856. The 6-12 would be Those are from a later tractor like a B or C series - and the wider tires DO give you a wider track and more stability. New same size as what you have tires may be the way to go. So Orginal wheelhouse size tires for my 856 would be 23x6x12? Given I may eventually very well may need both rear tires AND wheels given how rusty they are from the calcium chloride? Filled, is there a certian place new that’s highly recommended for getting the needed Wheelhorse wheels and tires together these days? Edited December 3, 2025 by FLtractor Share this post Link to post Share on other sites
ri702bill 13,067 #10 Posted December 3, 2025 (edited) Calcium chloride is the rim killer over time. Attracts moisture and rots the rims from the inside out.... Rimguard (beet juice) does not. Look at pictures of other 856's - and the IPM parts list to verify the original tire & rim size. Your tractor, your choice. Most folks pick up a pair of used rims and new tires of their choice. Then mount them at home... Edited December 4, 2025 by ri702bill 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #11 Posted December 3, 2025 here is couple pics I posted a while back of my 856 on the difference between Deestone and Carlisle tires both 23x8.50x12 on same size rim. Ive had good luck with the deestones but you can see how much smaller they run.... They are usally quite a bit cheaper though. 2 Share this post Link to post Share on other sites
FLtractor 223 #12 Posted December 3, 2025 (edited) 3 hours ago, sqrlgtr said: here is couple pics I posted a while back of my 856 on the difference between Deestone and Carlisle tires both 23x8.50x12 on same size rim. Ive had good luck with the deestones but you can see how much smaller they run.... They are usally quite a bit cheaper though. Thank you for the measurements and info. Do you or someone else know if this is a legit website? Says they’ve sold over 1 million tires and prices seem very cheap. Giga-tires.com Accidentally posted this vice grip garage video I was watching and can’t figure out how to remove it. Edited December 4, 2025 by FLtractor Share this post Link to post Share on other sites
wallfish 20,618 #13 Posted December 3, 2025 3 hours ago, sqrlgtr said: but you can see how much smaller they run Not sure that 3/4" to 1" of difference is a large amount but that could probably be made up with tire pressure. 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #14 Posted December 4, 2025 12 hours ago, wallfish said: Not sure that 3/4" to 1" of difference is a large amount but that could probably be made up with tire pressure. I don't want to be around when you try and make them Deestones as big as the Carlisles by putting more air in them. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #15 Posted December 4, 2025 (edited) Another great video by vice grip garage he is a bit quirky,but he knows what he is doing. I enjoyed all his vid`s. Thanks @FLtractor for posting this. Edited December 4, 2025 by Retired Wrencher Share this post Link to post Share on other sites
adsm08 5,148 #16 Posted December 4, 2025 (edited) 12 hours ago, FLtractor said: Do you or someone else know if this is a legit website? Says they’ve sold over 1 million tires and prices seem very cheap. Giga-tires.com Using the amazing Google Machine I have found the following: Giga-tires has a Walmart vendor store, so they exist to some degree. They do not seem to be a reputable or reliable seller based on this Reddit thread: https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.reddit.com/r/tires/comments/18ypzjy/is_gigatires_a_reputable_place_to_buy_from_they/&ved=2ahUKEwiw4t-e-qORAxW3kIkEHXm-CDoQFnoECBQQAQ&usg=AOvVaw1gdGDEryEqtDPotMtesMVl I know those prices are great, but I would find somewhere else to buy. Edited December 4, 2025 by adsm08 Share this post Link to post Share on other sites
702854boy 1,149 #17 Posted December 4, 2025 32 minutes ago, sqrlgtr said: I don't want to be around when you try and make them Deestones as big as the Carlisles by putting more air in them. When I was mounting our deestones, they said they had a max inflation of 35 psi, boy would that be a bumpy and hard ride Share this post Link to post Share on other sites
702854boy 1,149 #18 Posted December 4, 2025 12 hours ago, FLtractor said: Accidentally posted this vice grip garage video I was watching and can’t figure out how to remove it. There's nothing wrong with some Vice Grip Garage Share this post Link to post Share on other sites
ebinmaine 80,710 #19 Posted December 4, 2025 12 hours ago, wallfish said: Not sure that 3/4" to 1" of difference is a large amount but that could probably be made up with tire pressure. Ain't very big but remember that's all the way around the tire. Share this post Link to post Share on other sites
wallfish 20,618 #20 Posted December 4, 2025 (edited) 7 hours ago, ebinmaine said: Ain't very big but remember that's all the way around the tire. According to the tape measure in those pictures. That's the total height it raised the tractor so adjustment could probably be made to compensate. Some air in one set and less in the other Edited December 4, 2025 by wallfish Share this post Link to post Share on other sites
wallfish 20,618 #21 Posted December 4, 2025 8 hours ago, sqrlgtr said: I don't want to be around when you try and make them Deestones as big as the Carlisles by putting more air in them. The pictures are a bit of an optical illusion as the smaller tires are actually on the right pic. The total amount the tractor height raised with the bigger tires is only 3/4"-1" higher. Pressure could also be let out of the Carlise tires too. Share this post Link to post Share on other sites
ebinmaine 80,710 #22 Posted December 4, 2025 9 minutes ago, wallfish said: Not according to the tape measure in those pictures. That's the total height it raised the tractor Yessir I see that. In all reality it probably doesn't matter much unless you're really close to the ground already like we are up here quite often. The other reason it would matter is, I like the fender well to be full of tire, not airspace. That's what I mean when I say it would be the size lost, all the way around. Those Deestones lose three quarter inch on the bottom and lower the tractor that much.... and they also lose it on the top which means there's that much more air gap. Share this post Link to post Share on other sites
wallfish 20,618 #23 Posted December 4, 2025 Just now, ebinmaine said: The other reason it would matter is, I like the fender well to be full of tire, not airspace. I prefer that look as well Share this post Link to post Share on other sites
Handy Don 17,474 #24 Posted December 4, 2025 (edited) 9 minutes ago, wallfish said: The pictures are a bit of an optical illusion as the smaller tires are actually on the right pic. The total amount the tractor height raised with the bigger tires is only 3/4"-1" higher. Pressure could also be let out of the Carlise tires too. 2” overall height difference--23 to 21? Maybe 9% smaller? Big saving when making 000’s of tires. Smaller tires = greater torque (as if we really taxed our WHs) and slower speed (maybe 5.5 instead of 6.0 mph?) Edited December 4, 2025 by Handy Don Share this post Link to post Share on other sites
ebinmaine 80,710 #25 Posted December 4, 2025 Just now, wallfish said: I prefer that look as well Wait till you get to see my formerly Tecumseh horse, future Briggs horse. That thing has 24-12-12 on it. 1 Share this post Link to post Share on other sites
