Junkyard_sal 13 #1 Posted December 2, 2025 I have have a low hours WH 520H when cold the idle hunts. my small engine guy doesn’t want to touch an Onan saying parts are not available. i know the intake could be a problem but it doesn’t seem to change when I spray carb cleaner all over with the air filter off. that said adding choke seems to smooth it out. is there a good carb rebuild kit or intake seal kit? When running right this thing is a beast but the hunting is super bothersome and can be problematic if it dies on a steep slope! IMG_6025.mov 1 Share this post Link to post Share on other sites
Ed Kennell 44,386 #2 Posted December 2, 2025 If you all ready checked the intake for leaks, just clean the carb. I had to clean mine 3 times to finally stop the searching. 4 1 Share this post Link to post Share on other sites
Junkyard_sal 13 #3 Posted December 2, 2025 Checking the intake again tomorrow with more carb cleaner is there a good carb kit if I get in there and something is amiss Share this post Link to post Share on other sites
953 nut 63,782 #4 Posted December 2, 2025 Are you running gasoline with ethanol? If you have been then change over to ethanol free gas and run some Berrymans B12 fuel treatment at twice the recommended rate. Here is a site that will show you the gas stations in your area that have ethanol free gas. https://www.pure-gas.org/ 1 Share this post Link to post Share on other sites
lynnmor 8,471 #5 Posted December 2, 2025 Clean the carb, you may not need any parts besides the intake and carb base gaskets. There is no such thing as an intake seal kit. Hope you don’t have a fire spraying cleaner all over the place. 1 Share this post Link to post Share on other sites
Junkyard_sal 13 #6 Posted December 2, 2025 9 hours ago, 953 nut said: Are you running gasoline with ethanol? If you have been then change over to ethanol free gas and run some Berrymans B12 fuel treatment at twice the recommended rate. Here is a site that will show you the gas stations in your area that have ethanol free gas. https://www.pure-gas.org/ I run ethanol free and add chevon cleaner. I can try this b12 1 Share this post Link to post Share on other sites
Junkyard_sal 13 #7 Posted December 2, 2025 7 hours ago, lynnmor said: Clean the carb, you may not need any parts besides the intake and carb base gaskets. There is no such thing as an intake seal kit. Hope you don’t have a fire spraying cleaner all over the place. Good point I will bring my extinguisher Share this post Link to post Share on other sites
Junkyard_sal 13 #8 Posted December 4, 2025 I sprayed the crap out of the intake. No change in throttle. I cleaned the upper part of the carb and it is running better and starting easier. I am hesitant to take the whole carb off without a quality rebuild kit in hand. anyone have one that they like? I am goi g over to Onan to try and find a part number for the rebuild kit and pray someone still offers it for sale. 1 Share this post Link to post Share on other sites
lynnmor 8,471 #9 Posted December 4, 2025 What do you expect to find in a “rebuild kit”? Share this post Link to post Share on other sites
Ed Kennell 44,386 #10 Posted December 4, 2025 3 hours ago, Junkyard_sal said: I am hesitant to take the whole carb off without a quality rebuild kit in hand. I cleaned mine 3 times without a kit. Each time the surging got less so I kept cleaning till it stopped surging. 2 Share this post Link to post Share on other sites
