joj2180 0 #1 Posted December 1, 2025 I am switching out a 1976 Kohler 14 hp K321s with a Kohler M14QS 60125 in a 1976 Bobcat M371. The M14 came out of a wheelhorse tractor, but I didn't remove it. I am having trouble with the wiring- can anyone provide any photos of the solenoid setup, regulator/rectifier and the key switch. There are no lights, I just nee the engine to start and turn a few pulleys. Thanks! Share this post Link to post Share on other sites
Sparky-(Admin) 24,685 #2 Posted December 1, 2025 I broke your question out and made it its own topic. Will get more eyes on it this way. Does your Mag 14 have a voltage regulator? Usually mounted up near the carburetor and that would make it a 15a charging system. Some Mag 14’s didn’t come with a regulator and that would make it an unregulated 3a charging system. Share this post Link to post Share on other sites
pfrederi 19,973 #3 Posted December 1, 2025 4 hours ago, joj2180 said: I am switching out a 1976 Kohler 14 hp K321s with a Kohler M14QS 60125 in a 1976 Bobcat M371. The M14 came out of a wheelhorse tractor, but I didn't remove it. I am having trouble with the wiring- can anyone provide any photos of the solenoid setup, regulator/rectifier and the key switch. There are no lights, I just nee the engine to start and turn a few pulleys. Thanks! But the big issue is the K321 was PROBABLY a battery points ignition system.. The Magnum 14 has a magneto system. You have to be absoutley sure because the wrong ignition switch may fry the M-14 ignition system. You need an ignition switch with an "M" terminate for the M14 Share this post Link to post Share on other sites
joj2180 0 #4 Posted December 1, 2025 I do not believe I have a voltage regulator. I have two wires that come out from behind the flywheel, they go into a small connector mounted above the started on the shroud for the flywheel. One purple wire comes out of this connector and that goes to another loose connector that also has a wire coming into it from the ignition module. I do not know what this connector (with the purple wire and wire from the ignition module) connected to. And thank you for breaking out my question! Share this post Link to post Share on other sites
joj2180 0 #5 Posted December 1, 2025 I am good to pick up a new ignition switch if I need to for the M14, but I am finding that the switches available for the "M" series do not include the 14 hp. Share this post Link to post Share on other sites
pfrederi 19,973 #6 Posted December 2, 2025 Any "M" terminal switch will work the only issue usually is the size of the hole in the instrument panel it will fit into. Make sure the switch has good ground ...other wise you will not be able to turn off your M-14 Share this post Link to post Share on other sites
953 nut 64,361 #7 Posted December 2, 2025 Going from a K series to an M series Kohler is very using a relay that can be purchased at any auto parts store. 1 hour ago, joj2180 said: do not believe I have a voltage regulator. The voltage regulator on the Kohler "M" series engines is mounted in the fan shroud around the flywheel. I have two wires that come out from behind the flywheel, they go into a small connector mounted above the started on the shroud for the flywheel. One purple wire comes out of this connector and that goes to another loose connector that also has a wire coming into it from the ignition module. I do not know what this connector (with the purple wire and wire from the ignition module) connected to. The purple wire started life as a whit wire but for some reason they tend to turn purple, don't know why but at any rate the purple wire comes from your voltage regulator and will go to the "R" terminal of the ignition switch. Share this post Link to post Share on other sites
JoeM 9,650 #8 Posted December 2, 2025 I like mounting the starting solenoid right to the magnum engines. The white wire is the turns off the engine when grounded. hooks up to M The purple wire is charging circuit, (hooks up to acc on switch) You will need a start wire that run to the solenoid. and of course battery + and - Some magnum had low oil switches that would be hooked into a kill relay,. but most people disable the low oil switch and can be ignored. 1 Share this post Link to post Share on other sites
joj2180 0 #9 Posted December 2, 2025 Sorry for my confusion, I read through the linked posts and I have a question. Do I need a relay and an ignition switch (key)? Share this post Link to post Share on other sites
953 nut 64,361 #10 Posted December 3, 2025 1 hour ago, joj2180 said: Do I need a relay and an ignition switch (key)? If you want to rewire the tractor you will need a new 103991 ignition switch or you can keep the wiring as is and add the kill relay, your choice. If you want to rewire the unit use this drawing as an example. Share this post Link to post Share on other sites
Bill D 2,631 #11 Posted December 3, 2025 9 minutes ago, 953 nut said: If you want to rewire the tractor you will need a new 103991 ignition switch or you can keep the wiring as is and add the kill relay, your choice. If you want to rewire the unit use this drawing as an example. Add the kill relay and leave the stock wiring alone. If I rewire a tractor, I wire it for a powered ignition engine. If I'm installing an engine that uses a magneto I just add a relay to kill the engine in place of a coil. 2 Share this post Link to post Share on other sites
