Bar Nuthin 2,257 #1 Posted November 29, 2025 I often see the Hydraulic lifts (and parts) referred to with acronyms like HY2, HY5, HY6, etc. Is there a post or file that breaks down the different designations? All three of my tractors have hydraulic lifts, but only one is completely stock. It gets confusing when looking for parts - not knowing the differences. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #2 Posted November 29, 2025 This is what we have for the HY- and they are in a random order. https://www.wheelhorseforum.com/search/?&q="hy-"&type=downloads_file&search_and_or=or&sortby=relevancy 1 1 Share this post Link to post Share on other sites
Bar Nuthin 2,257 #3 Posted November 29, 2025 (edited) 1 hour ago, gwest_ca said: This is what we have for the HY- and they are in a random order. https://www.wheelhorseforum.com/search/?&q="hy-"&type=downloads_file&search_and_or=or&sortby=relevancy Thanks. That's the exact same search I ran before I made this post. At a minimum, I believe the two "non-stock" lifts I have are HY-6 - maybe The confusing part for me comes with matching hoses for older lift kits to new Sundstrand models. The ORB fittings are different sizes, even though the lift cylinders seem to be the same. Edited November 29, 2025 by Bar Nuthin Share this post Link to post Share on other sites
ri702bill 11,617 #4 Posted November 29, 2025 The HY2 and HY3 are identical except for the bellcrank. HY2 fits the PITA to remove shaft thru the tube design 1961 and 1962 tractors, HY3 has the bellcrank that is easy to remove with 2 bolts for the 1963 and 64, possibly more years than that. No Automatics those years... 2 Share this post Link to post Share on other sites
sqrlgtr 2,397 #5 Posted November 29, 2025 @Bar Nuthin glad you brought this up, I've been wondering the same thang... 3 hours ago, ri702bill said: The HY2 and HY3 are identical except for the bellcrank. HY2 fits the PITA to remove shaft thru the tube design 1961 and 1962 tractors, HY3 has the bellcrank that is easy to remove with 2 bolts for the 1963 and 64, possibly more years than that. No Automatics those years... Bill. are you talking about the handle that operates the up down or sumin else. This is the only hy unit I've been around and was told it was hy2 unit from 953 but I can take the handle off with 2 bolts. Will try and post a pic in a minute if I can find one. Share this post Link to post Share on other sites
sqrlgtr 2,397 #6 Posted November 29, 2025 Best i could do Share this post Link to post Share on other sites
ri702bill 11,617 #7 Posted November 29, 2025 No, the bellcrank that replaces the manual lift lever assembly. 1 Share this post Link to post Share on other sites
sqrlgtr 2,397 #8 Posted November 29, 2025 6 minutes ago, ri702bill said: No, the bellcrank that replaces the manual lift lever assembly. Got ya brain fart gettin old stinks... 1 Share this post Link to post Share on other sites
ri702bill 11,617 #9 Posted November 29, 2025 1 minute ago, sqrlgtr said: Got ya brain fart gettin old stinks... Beats the alternative though... 1 1 Share this post Link to post Share on other sites
