Krice58
C160 Ignition Wiring Issue
Krice58
Having a weird issue with the starter wire from the ignition switch to the pto switch smoking every time I try to crank it over. I redid some wiring on the 75 C160 recently to clean things up. Everything functioned correctly before but now it will not crank from the key, it will start with solenoid jumped and every time I try to turn it over with the key I get nothing but a smoking wire. I can’t figure out why this is happening, it’s just the short wire from the ignition switch to the pto switch. The wire is intact, well insulated and not touching anything other than the two terminals it needs to. I’ve tried multiple ignition switches that I know are good and I get the same result. Any ideas?
On a side note, I’ve been posting semi-regularly for the past few months and I just want to say how much I appreciate this community. You guys have been extremely helpful in problem solving and it makes me so happy that I’ve been able to revive my grandfathers old horse that I remember so vividly from my childhood. I’m not sure my wife would be as thankful because I’ve gone from 1 Wheel Horse to 5 in a short period of time, but I’m sure she’ll get over it.
Edited by Krice58
  • Thanks 1
Ed Kennell
Probably a short to ground in the wiring between the ignition switch and the solenoid trigger lug.
Krice58
The one that goes from to and from the pedal switch?
Edited by Krice58
gwest_ca
I would suspect a short in the pto switch or pedal switch if the wiring in between is OK. Is this the switch you have?
  • Excellent 3
Ed Kennell
Could be anywhere in the starting circuit wiring.   Ignition switch to PTO safety switch to pedal switch to solenoid.
The wire between the PTO and pedal switches would be my guess.  May be rubbing on the steering gear.
Unplug each of these three wires and use your ohm meter to find the short to ground.
Edited by Ed Kennell
  • Like 4
ri702bill
The last part - as long as there is not a whole one in the Parlor or a Unidrive in the tub, you're good....
  • Haha 2
Krice58
Not yet
  • Thanks 1
Krice58
Sounds like a plan
gwest_ca
Look for a flat spot worn into the wire insulation that has been in contact with the steering shaft for years. A closer inspection of that flat area may reveal a line down the center of it. That line could be bare wire causing the short.
953 nut
One by one just disconnect wires and look for smoke. First disconnect the wire from the PTO switch that comes from the ignition switch, turn the key.
If no smoke reconnect that wire then disconnect the wire from the PTO switch that goes to the pedal switch, turn the key.
If no smoke then reconnect that wire and disconnect the wire from the pedal switch to the solenoid.
Hope this is helpful.
Krice58
Yes that’s the one
gwest_ca
8 hours ago, Krice58 said:
Yes that’s the one
Someone was kind enough to post a picture of the wiring at the switch. That will show what goes where. Did you see it? If not click on the picture of the switch in the link. It is one of the thumbnails that comes up.
  • Thanks 1
Krice58
I think I found my issue. When I traced the wires from the pto switch, I found the wire to the brake safety switch was worn and making contact with the lift cylinder. Replaced the wire and rerouted it so it wouldn’t happen again. Got too cold to try to fire it up, but I’ll verify tomorrow to make sure that solved the problem.
  • Excellent 1
  • Thanks 1
Krice58
No more short. Fires right up with the key. Now just gotta get her ready to plow.
  • Excellent 3
