"Manic-Mechanic" 1,485 #1 Posted November 27, 2025 (edited) 2nd Test: Installed tighter idler tension spring Installed light duty spring between the PTO clips. A lot smoother… Edited November 27, 2025 by "Manic-Mechanic" Video link failed 5 Share this post Link to post Share on other sites
kpinnc 17,297 #2 Posted November 27, 2025 5 hours ago, "Manic-Mechanic" said: 2nd Test: I'm jealous. I've always wanted a sickle bar attachment. One day maybe. Yours is very nice! 2 1 Share this post Link to post Share on other sites
ebinmaine 77,554 #3 Posted November 27, 2025 Looks and runs great! Do you have a particular area/reason/ chore in mind for the sickle? We'll be very unlikely to ever own one here because of rough terrain. Interesting mechanisms. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #4 Posted November 27, 2025 21 minutes ago, ebinmaine said: Looks and runs great! Do you have a particular area/reason/ chore in mind for the sickle? We'll be very unlikely to ever own one here because of rough terrain. Interesting mechanisms. I may use it here an there… The 800 was just asking for a higher purpose and to my knowledge it hasn’t been done before so I can say I really love all the moving parts! 1 2 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #5 Posted November 27, 2025 4 hours ago, kpinnc said: I'm jealous. I've always wanted a sickle bar attachment. One day maybe. Yours is very nice! We could work something out with all that creativity you’ve got going on! 1 1 Share this post Link to post Share on other sites
peter lena 9,782 #6 Posted November 27, 2025 @Manicmacanic GOOD TURKEY DAY ! your operational sickle function says it all . that running EASE is what I regularly go for , now from that point , zero in on ANYTHING THAT IS NOT IN THAT PHASE OF SMOOTH , QUIET FUNCTION . done a lot of that , initially its a train wreck , now obviousely , much better . the noise / malfunction phase is the typical set up I see on anything that has not been , cared for . when you set up your stuff , with this baseline , its amazingly different , another glairing point is consistent , smooth easy use, things I have modified , have gone years , without failure or issues , just lubricant and a look see , basic stuff , added tension spring , washers , elastic lock nuts , shoulder bolts , for smooth lever swing start . springs on my choke / throttle cables , to close them ? try something , pete 2 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #7 Posted November 27, 2025 1 hour ago, peter lena said: @Manicmacanic GOOD TURKEY DAY ! your operational sickle function says it all . that running EASE is what I regularly go for , now from that point , zero in on ANYTHING THAT IS NOT IN THAT PHASE OF SMOOTH , QUIET FUNCTION . done a lot of that , initially its a train wreck , now obviousely , much better . the noise / malfunction phase is the typical set up I see on anything that has not been , cared for . when you set up your stuff , with this baseline , its amazingly different , another glairing point is consistent , smooth easy use, things I have modified , have gone years , without failure or issues , just lubricant and a look see , basic stuff , added tension spring , washers , elastic lock nuts , shoulder bolts , for smooth lever swing start . springs on my choke / throttle cables , to close them ? try something , pete I’ll tell you what, I have an 18 Auto your more than welcome to re-engineer! Getting ready to install a second pump! 1 Share this post Link to post Share on other sites
lynnmor 8,650 #8 Posted November 27, 2025 6 hours ago, kpinnc said: I'm jealous. I've always wanted a sickle bar attachment. One day maybe. Shortly after buying my new 1991 520H I saw a sickle bar in good condition at a yard sale for $25. I thought that running it would require 2 right hands, one for motion and the other to control the sickle, so I didn't buy. Now that I am older, and hopefully wiser, I need a kick in the rear for that mistake. I have some pine trees that I leave the lower branches touch the ground and a sickle would be great to trim the weeds under them, and that sickle bar, that I stupidly passed on, had a homemade guide to lift branches up and over so they weren't affected. 2 Share this post Link to post Share on other sites
peter lena 9,782 #9 Posted November 27, 2025 @Manicmacanic sounds and looks happy in operation ,emphasis is that you , corrected a common issue , got it out of the way , usually takes a little tweaking , to enhance that , you have done well , try and use that same idea frame of mind , on other issues , that solid , pto belt says it all , did that on top of mower decks , long unsupported belt return , to spindle pulleys , added , a flat idler pulley to deck , no more belt bounce , also use lucas xtra fd green chassis grease , cleaned out and hand packed every related bearing .. quiet smooth , also spins up very easily at pto lever engagement , no screaming clutch , this is another , GOLD MINE , area to improve , loaded with related heavy drag . pete 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #10 Posted November 27, 2025 2 minutes ago, peter lena said: @Manicmacanic sounds and looks happy in operation ,emphasis is that you , corrected a common issue , got it out of the way , usually takes a little tweaking , to enhance that , you have done well , try and use that same idea frame of mind , on other issues , that solid , pto belt says it all , did that on top of mower decks , long unsupported belt return , to spindle pulleys , added , a flat idler pulley to deck , no more belt bounce , also use lucas xtra fd green chassis grease , cleaned out and hand packed every related bearing .. quiet smooth , also spins up very easily at pto lever engagement , no screaming clutch , this is another , GOLD MINE , area to improve , loaded with related heavy drag . pete Speaking of Lucas, going to add stop leak to oil sumps and such to swell the seals, have you? Share this post Link to post Share on other sites
kpinnc 17,297 #11 Posted November 27, 2025 10 hours ago, "Manic-Mechanic" said: We could work something out with all that creativity you’ve got going on! I'm game! I do like a challenge! 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #12 Posted November 27, 2025 12 minutes ago, kpinnc said: I'm game! I do like a challenge! There was a member converting a D to a manual but haven’t heard much on that? Share this post Link to post Share on other sites
kpinnc 17,297 #13 Posted November 27, 2025 2 minutes ago, "Manic-Mechanic" said: There was a member converting a D to a manual but haven’t heard much on that? Now that would be a good one. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #14 Posted November 27, 2025 4 minutes ago, kpinnc said: Now that would be a good one. I “think”, may be wrong, it’s D-160? Share this post Link to post Share on other sites
kpinnc 17,297 #15 Posted November 28, 2025 2 hours ago, "Manic-Mechanic" said: think”, may be wrong, it’s D-160? The hard question would be if you wanted to keep the engine mounting the same. Either routing the belt or using a very large right angle gearbox would be needed. Just spitballing but the 8 speed itself would be fairly easy. Longer axles could be replaced with 2 or 3 inch spacers. Assuming the 6 bolt pattern is common enough to find them. As I understand it, the long D series axles were a failure point. Likely because folks treated them like a true sub compact tractor. But yeah, it would be doable. Just depends on how much money and time you're willing to spend on it. I always wanted to find a 5xi hydro to use a big engine on. The Eaton 1100 is facing forward on those transmissions. I have a Generac 33hp engine that would make a heckuva machine with that setup. 1 Share this post Link to post Share on other sites
ebinmaine 77,554 #16 Posted November 28, 2025 3 minutes ago, kpinnc said: The hard question would be if you wanted to keep the engine mounting the same. Either routing the belt or using a very large right angle gearbox would be needed. Just spitballing but the 8 speed itself would be fairly easy. Longer axles could be replaced with 2 or 3 inch spacers. Assuming the 6 bolt pattern is common enough to find them My Colossus project has these very things in usage. My engine sets with the crankshaft fore n aft instead of side to side like most Horses. I plan on using a right angle gear box mounted under the frame to transfer power rearward. My axles are the longer GT14 type along with 3" thick wheel adapters. 6 hole adapters could be made... 1 Share this post Link to post Share on other sites
kpinnc 17,297 #17 Posted November 28, 2025 1 minute ago, ebinmaine said: 6 hole adapters could be made... Probably easier to just widen a set of 5 bolt wheels. 1 Share this post Link to post Share on other sites
ebinmaine 77,554 #18 Posted November 28, 2025 1 minute ago, kpinnc said: Probably easier to just widen a set of 5 bolt wheels. Definitely agreed 1 Share this post Link to post Share on other sites
peter lena 9,782 #19 Posted November 28, 2025 @Manicmacanic have not had any sump related oil leaks , only thing I add to every oil change is , 4 oz of RISLONE ZINK , SUPPLEMENT , thats bottle specs for 2+ qts of oil , the oil flushing / cleaning with that / and the very noticeable engine running ease is very apparent , realise this is a very contentious issue / area , none of my engines , smoke in any way , or use oil at all . anything I refer to , has been in use for years , regularly experiment with chronic issues . most of my neighbor's , anything sounds like a squeaky , squealing mechanical mess , especially love to see the solid rust cables ," oil "barely on the stick . pete 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #20 Posted November 28, 2025 (edited) 15 minutes ago, peter lena said: @Manicmacanic have not had any sump related oil leaks , only thing I add to every oil change is , 4 oz of RISLONE ZINK , SUPPLEMENT , thats bottle specs for 2+ qts of oil , the oil flushing / cleaning with that / and the very noticeable engine running ease is very apparent , realise this is a very contentious issue / area , none of my engines , smoke in any way , or use oil at all . anything I refer to , has been in use for years , regularly experiment with chronic issues . most of my neighbor's , anything sounds like a squeaky , squealing mechanical mess , especially love to see the solid rust cables ," oil "barely on the stick . pete Amazing how a neglected engine can keep on going! I bought a Ford LGT for the M14, big risk as the dip stick tube was actually cut and sealed shut to accommodate a longer starter! One never knew what’s inside this sump! For $50 I took the gamble! The liquid drained out of there, (flushed out) was beyond my capacity to describe! Albeit, rebuilt and running today! Proprietary oil sump part of the motor mount assembly. Amazing, simply out of this world! Edited November 28, 2025 by "Manic-Mechanic" Share this post Link to post Share on other sites
peter lena 9,782 #21 Posted November 28, 2025 @Manicmacanic actually today anything to do with maintenance of anything is not even on the screen , made a point of doing this with my grandson , EMPHASIZING , A VERIFIED CONDITION OF MECHANICAL / ELECTRICAL ANYTHING . he now regularly asks me about anything , just drove in from ohio , older toyota camry , very solid , ever area has been checked out , upgraded to , solid , new , also oil spray down for rustproofing and paint recovery . he knows what , regular service checks give you . did that on his camaro too , certified submarine finish welder , and govt related frame welder . pete 1 Share this post Link to post Share on other sites
