enticer 340 1 #1 Posted November 25, 2025 (edited) ive noticed a weird noise on my toro, it sounds like a knock. but i read on the forums it might be a valve noise. would anybody know which one it is? ( im reving the engine, its not surging ) 494e0ddb-4cba-4ac5-976b-b93ea7f25713.mp4 Edited November 27, 2025 by enticer 340 Share this post Link to post Share on other sites
Ed Kennell 44,871 #2 Posted November 25, 2025 to the All I can hear is a badly surging engine. Remove one spark plug at a time to determine if there is a problem in one of the cylinders. Share this post Link to post Share on other sites
lynnmor 8,625 #4 Posted November 25, 2025 If you throttle up you should be able to keep the engine running on one cylinder. See if the sound changes when you do that. Next step would be a compression test, it might show which cylinder is the problem but it may not prove that there is a valve seat issue. Surging is usually caused by an intake air leak or a dirty carburetor. Share this post Link to post Share on other sites
ri702bill 11,256 #5 Posted November 25, 2025 2 hours ago, lynnmor said: Surging is usually caused by an intake air leak or a dirty carburetor. Welcome! I do not own one, but I have read enough posts describing both. How many hours on the engine?? I ask because the dreaded loose valve seat issue seems to show up mostly in machines with a lot of hours... Share this post Link to post Share on other sites
Handy Don 15,943 #6 Posted November 26, 2025 3 hours ago, ri702bill said: I ask because the dreaded loose valve seat issue seems to show up mostly in machines with a lot of hours... and with poor cooling airflow--especially on the rear cylinder. 1 Share this post Link to post Share on other sites
enticer 340 1 #8 Posted November 27, 2025 (edited) 43585c7e-56e7-4cd3-89c4-f7916b166346.mp4 On 11/25/2025 at 4:51 PM, Ed Kennell said: to the All I can hear is a badly surging engine. Remove one spark plug at a time to determine if there is a problem in one of the cylinders. i was just reving the engine to see if it would make the noise. it doesnt surge when i leave the throttle alone Edited November 27, 2025 by enticer 340 1 Share this post Link to post Share on other sites
enticer 340 1 #9 Posted November 27, 2025 (edited) On 11/25/2025 at 7:51 PM, ri702bill said: Welcome! I do not own one, but I have read enough posts describing both. How many hours on the engine?? I ask because the dreaded loose valve seat issue seems to show up mostly in machines with a lot of hours... the engine has more then 2000 hours on it, the hour meter stoped working since the fuse blew up Edited November 27, 2025 by enticer 340 Share this post Link to post Share on other sites
RED-Z06 2,716 #10 Posted November 27, 2025 I hear a bit of something, either rod or piston slap. That said...some onans make noise, ive got a B43G that rough at higher rpms but silent idle, a p218g that has a prounounced idle rattle but hums off idle..1100 and 250hrs respectively. Share this post Link to post Share on other sites
kpinnc 17,153 #11 Posted November 27, 2025 If you go to the trouble of sealing the manifold and cleaning the carb- it's a good time to clean the carbon on the heads and adjust your valves. If everything else is good, it might help with the noise. Onan engines that I've had always had alot of carbon on top of the pistons and clickety valves. Very few people do the 500 hours head cleaning. The valve rattle is always more prevalent when increasing speed or when the governor pulls in under load. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,450 #12 Posted November 29, 2025 Enjoy the site as you can see lots of help here already. Share this post Link to post Share on other sites
enticer 340 1 #13 Posted November 29, 2025 On 11/27/2025 at 7:06 PM, kpinnc said: If you go to the trouble of sealing the manifold and cleaning the carb- it's a good time to clean the carbon on the heads and adjust your valves. If everything else is good, it might help with the noise. Onan engines that I've had always had alot of carbon on top of the pistons and clickety valves. Very few people do the 500 hours head cleaning. The valve rattle is always more prevalent when increasing speed or when the governor pulls in under load. yea i did start noticing the noise when i was pulling a snowmobile with it. i took the engine out so i will check the valves. Share this post Link to post Share on other sites
