meadowfield 2,853 #1 Posted Monday at 06:06 PM My son doesn’t come on here anymore, but here is a 704 that he has been making into a 4x4. complete scratch built axle, and a lot of lathe and milling…. I’ll try sort some build pics out! 2 20 5 Share this post Link to post Share on other sites
Pullstart 68,407 #3 Posted Monday at 06:50 PM So awesome! 1 Share this post Link to post Share on other sites
Handy Don 14,886 #4 Posted Monday at 07:03 PM Some real innovative thinking there! Congrats to your son 👏 Tapping the brake drum shaft for front-drive power is so clever. Please elaborate on the sources for the front differential and the 90º gearbox amidship! 2 Share this post Link to post Share on other sites
ri702bill 10,310 #5 Posted Monday at 07:47 PM (edited) Excellent potential there! I see what I believe is a 1:1 chain drive to power a right-angle gearbox - also 1:1?? I ask because of the different sized tires front to rear as the circumference of both are different. Also, is there a one-way clutch hidden in there to allow the tractor to roll in neutral with the brake applied or to semi-address my above question? I take it that the front driveshaft is splined to allow it to lengthen & shorten too, as the shaft centerline is not coincident to the front axle pivot? You got a few bucks tied up there. Off to a good start. Bill Edited Monday at 10:35 PM by ri702bill 3 Share this post Link to post Share on other sites
JoeM 9,071 #6 Posted Monday at 10:54 PM 4 hours ago, meadowfield said: and a lot of lathe and milling and ciphering! nice work 2 Share this post Link to post Share on other sites
Bill D 2,401 #7 Posted Tuesday at 12:07 AM Wow, just wow!! 2 Share this post Link to post Share on other sites
953 nut 62,621 #8 Posted Tuesday at 12:25 AM @meadowfield, your son is a chip off the old block, outstanding workmanship just like your "BENDY" and "C4" Wheel Horses. 2 1 Share this post Link to post Share on other sites
ebinmaine 75,008 #9 Posted Tuesday at 12:47 AM Awesome! Share this post Link to post Share on other sites
Easton Rich 760 #11 Posted Tuesday at 01:28 AM What paint is that? It’s beautiful! Share this post Link to post Share on other sites
meadowfield 2,853 #12 Posted Tuesday at 08:10 AM 12 hours ago, ri702bill said: Excellent potential there! I see what I believe is a 1:1 chain drive to power a right-angle gearbox - also 1:1?? I ask because of the different sized tires front to rear as the circumference of both are different. Also, is there a one-way clutch hidden in there to allow the tractor to roll in neutral with the brake applied or to semi-address my above question? I take it that the front driveshaft is splined to allow it to lengthen & shorten too, as the shaft centerline is not coincident to the front axle pivot? You got a few bucks tied up there. Off to a good start. Bill it's not 1:1 drive it's under - 20/23, axle ratios and tyre diameters are factored in and ratio is spot on. Driveshaft is splined, but actually only moves 1/8" when the axle tilts. Brake drum works as before - it's a newer version of my 4x4 wheel horse I built 12 years ago. 2 5 Share this post Link to post Share on other sites
meadowfield 2,853 #13 Posted Tuesday at 08:11 AM 13 hours ago, Handy Don said: Some real innovative thinking there! Congrats to your son 👏 Tapping the brake drum shaft for front-drive power is so clever. Please elaborate on the sources for the front differential and the 90º gearbox amidship! my 4x4 wheel horses, both use the brake drum, so that was the logical thing to do. Front differental is a peerless built into a custom casing, Rear box is from a mower. 3 3 Share this post Link to post Share on other sites
kpinnc 15,971 #14 Posted Tuesday at 11:37 AM 17 hours ago, meadowfield said: 704 that he has been making into a 4x4. complete scratch built axle, and a lot of lathe and milling…. Exceptional work! Small block Kohler tied to a 4WD with a crawler gear? Rugged machine for certain! 1 Share this post Link to post Share on other sites
702854boy 333 #15 Posted Tuesday at 12:48 PM 18 hours ago, meadowfield said: Share this post Link to post Share on other sites
meadowfield 2,853 #16 Posted 7 hours ago (edited) A few more of the build Edited 7 hours ago by meadowfield 5 Share this post Link to post Share on other sites
ebinmaine 75,008 #17 Posted 4 hours ago Incredible work! 1 Share this post Link to post Share on other sites
AlexR 2,274 #18 Posted 4 hours ago Wow that is a lot of machine work and fabrication to do the front axle. The result is really awesome though 1 Share this post Link to post Share on other sites
