meadowfield
Another 4x4 - I’ll just leave this here….
SylvanLakeWH
:popcorn:
Pullstart
So awesome!  :eusa-clap:
Handy Don
Some real innovative thinking there! Congrats to your son 👏
Tapping the brake drum shaft for front-drive power is so clever.
Please elaborate on the sources for the front differential and the 90º gearbox amidship!
ri702bill
Excellent potential there!
I see what I believe is a 1:1 chain drive to power a right-angle gearbox - also 1:1?? I ask because of the different sized tires front to rear as the circumference of both are different.
Also, is there a one-way clutch hidden in there to allow the tractor to roll in neutral with the brake applied or to semi-address my above question? I take it that the front driveshaft is splined to allow it to lengthen & shorten too, as the shaft centerline is not coincident to the front axle pivot? You got a few bucks tied up there. Off to a good start.
Bill
Edited by ri702bill
JoeM
4 hours ago, meadowfield said:
and a lot of lathe and milling
and ciphering!
nice work
Bill D
Wow, just wow!!
953 nut
:text-coolphotos:                                :woohoo:
@meadowfield, your son is a chip off the old block, outstanding workmanship just like your "BENDY" and "C4" Wheel Horses.         :notworthy:
ebinmaine
Awesome!
Easton Rich
:popcorn::handgestures-thumbupright:
Easton Rich
What paint is that? It’s beautiful!
meadowfield
Bill
it's not 1:1 drive it's under - 20/23, axle ratios and tyre diameters are factored in and ratio is spot on. Driveshaft is splined, but actually only moves 1/8" when the axle tilts. Brake drum works as before - it's a newer version of my 4x4 wheel horse I built 12 years ago.
  • Excellent 3
meadowfield
my 4x4 wheel horses, both use the brake drum, so that was the logical thing to do.  Front differental is a peerless built into a custom casing, Rear box is from a mower.
  • Excellent 2
kpinnc
17 hours ago, meadowfield said:
704 that he has been making into a 4x4.
complete scratch built axle, and a lot of lathe and milling….
Exceptional work!
Small block Kohler tied to a 4WD with a crawler gear? Rugged machine for certain! :thumbs:
