meadowfield 3,191 #1 Posted November 24, 2025 My son doesn’t come on here anymore, but here is a 704 that he has been making into a 4x4. complete scratch built axle, and a lot of lathe and milling…. I’ll try sort some build pics out! 4 26 7 Share this post Link to post Share on other sites
Pullstart 71,292 #3 Posted November 24, 2025 So awesome! 2 Share this post Link to post Share on other sites
Handy Don 17,487 #4 Posted November 24, 2025 Some real innovative thinking there! Congrats to your son 👏 Tapping the brake drum shaft for front-drive power is so clever. Please elaborate on the sources for the front differential and the 90º gearbox amidship! 3 Share this post Link to post Share on other sites
ri702bill 13,087 #5 Posted November 24, 2025 (edited) Excellent potential there! I see what I believe is a 1:1 chain drive to power a right-angle gearbox - also 1:1?? I ask because of the different sized tires front to rear as the circumference of both are different. Also, is there a one-way clutch hidden in there to allow the tractor to roll in neutral with the brake applied or to semi-address my above question? I take it that the front driveshaft is splined to allow it to lengthen & shorten too, as the shaft centerline is not coincident to the front axle pivot? You got a few bucks tied up there. Off to a good start. Bill Edited November 24, 2025 by ri702bill 4 Share this post Link to post Share on other sites
JoeM 10,294 #6 Posted November 24, 2025 4 hours ago, meadowfield said: and a lot of lathe and milling and ciphering! nice work 3 Share this post Link to post Share on other sites
Bill D 3,158 #7 Posted November 25, 2025 Wow, just wow!! 3 Share this post Link to post Share on other sites
953 nut 69,519 #8 Posted November 25, 2025 @meadowfield, your son is a chip off the old block, outstanding workmanship just like your "BENDY" and "C4" Wheel Horses. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,764 #9 Posted November 25, 2025 Awesome! 1 Share this post Link to post Share on other sites
Easton Rich 1,260 #11 Posted November 25, 2025 What paint is that? It’s beautiful! 1 Share this post Link to post Share on other sites
meadowfield 3,191 #12 Posted November 25, 2025 12 hours ago, ri702bill said: Excellent potential there! I see what I believe is a 1:1 chain drive to power a right-angle gearbox - also 1:1?? I ask because of the different sized tires front to rear as the circumference of both are different. Also, is there a one-way clutch hidden in there to allow the tractor to roll in neutral with the brake applied or to semi-address my above question? I take it that the front driveshaft is splined to allow it to lengthen & shorten too, as the shaft centerline is not coincident to the front axle pivot? You got a few bucks tied up there. Off to a good start. Bill it's not 1:1 drive it's under - 20/23, axle ratios and tyre diameters are factored in and ratio is spot on. Driveshaft is splined, but actually only moves 1/8" when the axle tilts. Brake drum works as before - it's a newer version of my 4x4 wheel horse I built 12 years ago. 3 6 Share this post Link to post Share on other sites
meadowfield 3,191 #13 Posted November 25, 2025 13 hours ago, Handy Don said: Some real innovative thinking there! Congrats to your son 👏 Tapping the brake drum shaft for front-drive power is so clever. Please elaborate on the sources for the front differential and the 90º gearbox amidship! my 4x4 wheel horses, both use the brake drum, so that was the logical thing to do. Front differental is a peerless built into a custom casing, Rear box is from a mower. 4 3 Share this post Link to post Share on other sites
kpinnc 18,976 #14 Posted November 25, 2025 17 hours ago, meadowfield said: 704 that he has been making into a 4x4. complete scratch built axle, and a lot of lathe and milling…. Exceptional work! Small block Kohler tied to a 4WD with a crawler gear? Rugged machine for certain! 3 Share this post Link to post Share on other sites
702854boy 1,150 #15 Posted November 25, 2025 18 hours ago, meadowfield said: 2 Share this post Link to post Share on other sites
meadowfield 3,191 #16 Posted November 27, 2025 (edited) A few more of the build Edited November 27, 2025 by meadowfield 1 13 3 Share this post Link to post Share on other sites
ebinmaine 80,764 #17 Posted November 27, 2025 Incredible work! 3 Share this post Link to post Share on other sites
AlexR 3,118 #18 Posted November 27, 2025 Wow that is a lot of machine work and fabrication to do the front axle. The result is really awesome though 2 Share this post Link to post Share on other sites
Wayne0 1,635 #19 Posted November 27, 2025 That is some MAD skills!! 2 Share this post Link to post Share on other sites
kpinnc 18,976 #20 Posted November 27, 2025 12 hours ago, meadowfield said: few more of the build Absolutely amazing. I'm always in awe of any custom machine work. I'm lucky if I can drill something on center with my lathe. This is some serious fabrication skills! 4 1 Share this post Link to post Share on other sites
meadowfield 3,191 #21 Posted December 8, 2025 (edited) A few more - he completed the drive flanges, so now the hubs are driven. onto final bits = the rear axle keyways were badly wallowed. So fresh 1/4 slots milled ready for much longer keys. Edited December 8, 2025 by meadowfield 3 8 Share this post Link to post Share on other sites
ebinmaine 80,764 #22 Posted December 8, 2025 18 minutes ago, meadowfield said: fresh 1/4 slots milled ready for much longer keys. Niiiiice. For that reason alone - I would love to have a small mill. I'm hoping someday to figure out if I can use my recent drill press purchase. 3 Share this post Link to post Share on other sites
peter lena 10,076 #23 Posted December 8, 2025 @meadowfield , LOVE IT ! incredible build standard , lots of thinking / opportunities , you tore down the wall of improvements . and put this on top of the hill ! pete 2 Share this post Link to post Share on other sites
lynnmor 9,042 #24 Posted December 8, 2025 4 hours ago, ebinmaine said: For that reason alone - I would love to have a small mill. I'm hoping someday to figure out if I can use my recent drill press purchase. A drill press usually doesn't have the rigidity to do milling. The one you bought might do better than most but I wouldn't count on it. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,764 #25 Posted December 8, 2025 1 minute ago, lynnmor said: A drill press usually doesn't have the rigidity to do milling. The one you bought might do better than most but I wouldn't count on it. That's the basic thought process I have as well. It's been indicated to me by someone here in real life that, instead of making standard small long thin Mill style cuts, I could potentially lock the depth up and down and make a whole bunch of drill holes in a row, then, straighten the slot. I'm no machinist so I don't know if that's realistic. Just what I've been told. 4 Share this post Link to post Share on other sites
