1987_WHEEHORSE312 79 #1 Posted November 24, 2025 So I think I have a bad vent issue with the Gas Cap on my 312-8. After about an hour of running the motor sputters real bad like there is no fuel, and when I pull the chose it seems to resolve for a few minutes and then sputters again. When I go to check the gas, the cap is extremely hard to twist off, and feels way tighter then when I put it back on, like there is a vacuum in the tank. With that being said it seems like the fuel filter doesn't have a lot of gas in it either. I do have a tank shutoff at the bottom of the tank that I know can get a clogged screen, but I want to replace the cap with a cheap TSC one for the time being to see if the issue resolves its self before I spend $40+ dollars on one with a gauge. If it doesn't resolve its self then I'll investigate further, but with winter setting in, and no warm place to work on my tractor would rather start simple. With that being said can anyone drop part number to a generic cap from TSC that would work? Thanks! Share this post Link to post Share on other sites
oliver2-44 11,137 #2 Posted November 24, 2025 Before you buy a cheap gage, try just leaving you existing cap a little loose with the tank not all the way full. 2 Share this post Link to post Share on other sites
Handy Don 15,607 #3 Posted November 24, 2025 The gauge cap on my Snapper has a thumbscrew to open/close the venting action (it’s there because the mower can be stood on end for access to the blade or for storage and it prevents fuel from leaking out). If I forget to open it, it does fuel-starve the engine after running for a while. Other gauge caps I’ve seen have a small hole in the clear bezel that must remain un-clogged. Share this post Link to post Share on other sites
1987_WHEEHORSE312 79 #4 Posted November 24, 2025 4 minutes ago, Handy Don said: The gauge cap on my Snapper has a thumbscrew to open/close the venting action (it’s there because the mower can be stood on end for access to the blade or for storage and it prevents fuel from leaking out). If I forget to open it, it does fuel-starve the engine after running for a while. Other gauge caps I’ve seen have a small hole in the clear bezel that must remain un-clogged. Any idea where the vent would be on a Wheelhorse Stock gas cap? Share this post Link to post Share on other sites
Lee1977 7,499 #5 Posted November 24, 2025 23 minutes ago, 1987_WHEEHORSE312 said: Any idea where the vent would be on a Wheelhorse Stock gas cap? The cap with the gage vents up though the center gage hole and another small hole in the plastic lens close to the black part of the cap 2 Share this post Link to post Share on other sites
