Mike'sHorseBarn 3,681 #1 Posted November 22, 2025 I've posted about this thing before. Its leaked ever since I got it due to the hole where the input shaft is being wallowed out. I've done seals may times, but i'm just sick of it making a mess of the tractor. Im thinking about taking it off amd putting a manual lift on, but that almost ruins the tractor. Would anyone have a pump that is in better shape than this one i could swap out? Thoughts on the whole ordeal?? 4 Share this post Link to post Share on other sites
ri702bill 13,067 #2 Posted November 22, 2025 (edited) I too have a HY-2 that needed a return spring, so I got the whole Kit from Lowell. The shaft seal was correct but did not fit the housing. I contacted him - after measuring it, we agree that the housing seal bore was machined out to be one size larger for the OD of the seal, with the same original ID. I had to source one - it works fine. That may work for you.... The shaft bore on mine looks original, yours may need a bushing... Edited November 22, 2025 by ri702bill Share this post Link to post Share on other sites
Pullstart 71,248 #3 Posted November 22, 2025 Mike do you have any 953 carcasses around? Same pump 2 Share this post Link to post Share on other sites
953 nut 69,315 #4 Posted November 22, 2025 11 hours ago, Mike'sHorseBarn said: leaked ever since I got it due to the hole where the input shaft is being wallowed out. I've done seals may times Could you drill it out and press in a bronze bushing and then put in a new seal? 3 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #5 Posted November 22, 2025 10 hours ago, 953 nut said: Could you drill it out and press in a bronze bushing and then put in a new seal? That's what Id like to do, but I dont have good enough equipment to do so. If I knew if a machine shop in pa that would do it I'd take it there. 2 Share this post Link to post Share on other sites
adsm08 5,148 #6 Posted November 23, 2025 I know a place in Carlisle that might be able to do something wit it, but it probably won't be cheap. Share this post Link to post Share on other sites
oliver2-44 11,751 #7 Posted November 23, 2025 I've used Locktite 660 for some gap filling situations. So for what its worth, I asked AI to suggest a product to fill the gap around the outside of a seal in a worn bore and it suggested Locktite 660 as well. My Oliver Backhoe had a hydraulic cylinder top shaft end seal area was pitted. I embedder the seal in a thin film of JB Well. it has lasted 20+years. I seem to recall heating the part on the gas grill to burn all the oil out of the metal. Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #8 Posted November 23, 2025 (edited) 1 hour ago, adsm08 said: I know a place in Carlisle that might be able to do something wit it, but it probably won't be cheap. What is anymore. Edited November 23, 2025 by Mike'sHorseBarn Share this post Link to post Share on other sites
Handy Don 17,474 #9 Posted November 23, 2025 (edited) 8 minutes ago, Mike'sHorseBarn said: What is anymore. My grandfather said to me at least 50 times while doing projects together in my youth “talk is cheap...” -- the rest has been redacted. 😁 Edited November 23, 2025 by Handy Don 5 Share this post Link to post Share on other sites
adsm08 5,148 #10 Posted November 23, 2025 8 hours ago, Mike'sHorseBarn said: What is anymore. I've been told that deer nuts are still under a buck. But you can give Turner Hydraulics a call. They advertise hydraulic and machining repairs. 3 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #11 Posted November 24, 2025 16 hours ago, adsm08 said: But you can give Turner Hydraulics a call. They advertise hydraulic and machining repairs. Thanks! Share this post Link to post Share on other sites
