Dand685 0 #1 Posted November 22, 2025 I have a 97 520H. Probably one of the last of the great ones. It has a different steering wheel, much thicker then previous years, also belt cover and different rubber footpads. Problem is dashlights all come on when turning key to start, but then when engine runs all remain bright but the oil pressure light constantly blinks. Occasionally the dash lights will all go off and stay off after engine is running. My 9 pin connector has top left(no.1?) wire cut and removed. I took the oil filter off, felt for the switch and found wire intact and connected. Impossible to see the color. I’ve jiggled the nine pin, no luck. Some times the safety switch on the trans control behind the vertical dash panel seems to solve the flashing oil light and steady rest of the lights. I’ve replaced the ignition switch twice, but wonder if there’s a special one year only ignition switch. I have wiring diagrams, I’m pretty good on tracing, but with faded colors on the wires entering the 9 pin connector I’m not sure which it is. I need an actual diagram of the 9 pin to see what goes to and came from. What to try next? Engine runs fine, powerful, no issues otherwise. Share this post Link to post Share on other sites
953 nut 63,984 #2 Posted November 22, 2025 This wiring guide should be helpful. Share this post Link to post Share on other sites
lynnmor 8,566 #3 Posted November 22, 2025 The oil pressure switch supplies the ground to the hour meter thru the black wire when there is oil pressure. The oil pressure switch also supplies the ground to the oil light thru the dark blue wire when there is no pressure. 2 Share this post Link to post Share on other sites
Dand685 0 #4 Posted November 22, 2025 Thanks both of you. So there’s no set location in the 9 pin connector for locating the wires, just make sure the second half location matches the first. But I’ve never had a Wheelhorse that lit up all the indicator lights. What sets that off? The owners manual just says a defect will record as a flashing light on the appropriate signal. It doesn’t say they all light up. Also, I thought a ground was just a ground. The wiring diagram specifically says the oil pressure black ground goes to the hour meter. Is it possible I have the wrong black ground on the hour meter? It works just fine recording time running. Share this post Link to post Share on other sites
lynnmor 8,566 #5 Posted November 22, 2025 On the two items being discussed the ground side is switched while the positive side stays connected, this method greatly simplifies the wiring. The hour meter should not run if the engine is not running. All of the display lights up briefly when turning the switch on. Some of the wires may be different colors across the 9 pin connection. Share this post Link to post Share on other sites
ri702bill 11,147 #6 Posted November 22, 2025 42 minutes ago, lynnmor said: Some of the wires may be different colors across the 9 pin connection. That sounds scary!! My old Jeep Wagonaire was the same way. No fuse block, just a collection of inline fuses located all over the place behind the dash!! That 9 pin connector is a common source of problems as the tractor ages. Most likely, the charging wire was removed from it - that is the one that overheats as the resistance goes up thru corrosion... I see you are a newbie - Welcome! I also see you are from northern RI; I am in central RI. Share this post Link to post Share on other sites
953 nut 63,984 #7 Posted November 22, 2025 (edited) Is there a test switch that allows you to test the indicating lights? if so take a look at the test switch, it could be the problem. Also check for corrosion or loose connections. Edited November 22, 2025 by 953 nut Share this post Link to post Share on other sites
lynnmor 8,566 #8 Posted November 22, 2025 3 hours ago, 953 nut said: Is there a test switch that allows you to test the indicating lights? if so take a look at the test switch, it could be the problem. Also check for corrosion or loose connections. The lights are tested at startup and may be part of the OP's concern. The test switch was only on 88, 89 & 90 520's way before the 1997 in question. Share this post Link to post Share on other sites
Dand685 0 #9 Posted November 23, 2025 Lynnmor. What signals all the lights on the dashboard to light up when switch is turned on? Agreed, no test switch, tried to look at older Whs that I have, couldn’t figure what the test switch does to light them all up.That’s why I replaced ignition switch twice figuring it had to be a fault in there. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #10 Posted November 23, 2025 There is a tan wire going from the ignition START terminal/wire to the dash indicator light module. That is the one that would trigger the bulb check on startup. All the low oil level lights and low oil pressure lights flash when activated on all models that have them. Share this post Link to post Share on other sites
Dand685 0 #11 Posted November 23, 2025 (edited) Wow, thanks. I’ll check that out tomorrow between football games to see if that’s the problem. I may take out the indicator module to check the circuit board, too. Nasty job. Edited November 23, 2025 by Dand685 Share this post Link to post Share on other sites
