amiga4001 33 #1 Posted November 20, 2025 I wanted to remove a wheel from my B115 as it needed a new Tyre. Nightmare to get these wheels off I ended up dismantling the gearbox and taking out the axle and use a press and torch. I got those wheels off but I damaged the wheels (centre is not straight anymore) so I am looking for a new set, I was thinking about mounting a wheelflange with studs to be able to easy mount dismount the wheels in the future. Anyone tried this?Any tips?Most flanges I can find are metric size not imperial 3/4? Thanks! Share this post Link to post Share on other sites
oliver2-44 11,313 #2 Posted November 20, 2025 You could use some WH hubs from 4/4 speed transmissions that have a 1” ID. Then use a 3/4 to 1” bushing. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,060 #3 Posted November 20, 2025 Someone was making replacement hubs that use a split tapered bushing between the hub and the axle. Using the same hub with the appropriate tapered bushing ID should be possible. Make sure the axle key will fit. I just don't know who it was nor can I find anything about them. Share this post Link to post Share on other sites
JoeM 9,671 #4 Posted November 20, 2025 2 hours ago, amiga4001 said: it needed a new Tyre. I know a guy that had that problem and changed the tire on the tractor. Share this post Link to post Share on other sites
Bill D 2,677 #5 Posted November 20, 2025 46 minutes ago, gwest_ca said: Someone was making replacement hubs that use a split tapered bushing between the hub and the axle. Using the same hub with the appropriate tapered bushing ID should be possible. Make sure the axle key will fit. I just don't know who it was nor can I find anything about them. I believe A-Z tractor sells them. 1 Share this post Link to post Share on other sites
adsm08 4,249 #7 Posted November 21, 2025 5 hours ago, amiga4001 said: ?Most flanges I can find are metric size not imperial 3/4? I don't know what the tolerance on a bearing is, but in the world of sockets 3/4 of an inch is considered interchangeable with 19mm. Share this post Link to post Share on other sites
