CNC 19 #1 Posted November 19, 2025 I have been using the horse for the last 3 or 4 months everything worked fine until a few days ago. I stared it up pulled it outside it started as usual, when I went back a few hours later it would not start ( engine would not turn over,no noise from solenoid nothing). I push the dead horse back into the garage and changed out the solenoid and battery from my other wheel horse ranger. Still nothing so I said must be the 2 safety switches. Pulled them off one of the brake switch wires was broken ( that must be the problem!) clean both switches and replaced with new wires. I reinstall everything still nothing. No noise engine will not turn over. Can anyone give me some suggestions on what to do next. I hope the ole c160 horse is not ready for the pasture Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #2 Posted November 19, 2025 Follow the red wire from the ignition switch to the starter solenoid. It should have power with the ignition switch in the START position. 2 Share this post Link to post Share on other sites
CNC 19 #3 Posted November 19, 2025 Many thanks gwest-ca I will check that out Friday when i get back into the shop Share this post Link to post Share on other sites
squonk 47,729 #4 Posted November 19, 2025 Everything goes thru the ammeter first. If this was mine that would be the first thing I check. Seen it many times. 8 Share this post Link to post Share on other sites
CNC 19 #5 Posted November 20, 2025 Many thanks gwest-ca I will check that out Friday when i get back into the shop You know Squonk I don't know if I wired the ammeter. The glass is broken and it has no needle need to check that! Thanks Share this post Link to post Share on other sites
kpinnc 18,851 #6 Posted November 20, 2025 5 hours ago, CNC said: I hope the ole c160 horse is not ready for the pasture If it is, I live an hour away and have a big pasture... 1 4 1 Share this post Link to post Share on other sites
Pullstart 70,994 #8 Posted November 20, 2025 15 hours ago, squonk said: Everything goes thru the ammeter first. If this was mine that would be the first thing I check. Seen it many times. Had this recently with my 1445. Everything was good, until it wasn’t. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,647 #9 Posted November 20, 2025 Electrical problems are the worst.........they can very easily send you on a wild goose chase. Like squonk said check the ammeter. I'd also try bypassing the safety switches. If it starts, you know at least one of them is the issue and can connect them again one at a time until you find the bad one. 2 Share this post Link to post Share on other sites
Handy Don 17,189 #10 Posted November 20, 2025 3 hours ago, Mike'sHorseBarn said: and can connect them again one at a time until you find the bad one. And replace it! Just helpin’ out. 2 1 Share this post Link to post Share on other sites
953 nut 68,140 #11 Posted November 21, 2025 If your Wheel Horse won’t start with the key, what should you do? Don’t panic, it happens to all of us. Don’t run out and buy a new ignition switch. Don’t rip out the wiring. Don’t loose your mind and give the tractor away because it is dead. S Systematic troubleshooting will isolate the cause of the problem. T Think about the last thing you did before the problem occurred. Many times we are our own worst enemies. O Once you calm down begin searching for the cause. P Plan your attack. One of the most common causes of a “won’t start with the key” is the PTO not being OFF. You may have been mowing and stopped to move something out of the way, get back in the seat and it won’t start The PTO switch is doing its job and preventing you from starting the engine with the PTO on. Is your transmission in neutral? Is your foot on the brake? These are easy things to overlook. Is your battery in good condition? A battery in marginal condition may start the engine the first time but not become recharged while using the tractor. Have the battery load tested at an auto parts store. Are your battery cables in good condition? Corrosion on the cable terminals can act as a huge resistor reducing the amount of voltage reaching the starter or solenoid to the point it will just click. This is also true for the ground cable too. If you hear clicking check for heat on all of the terminals, The one that is causing the problem will be hot due to the voltage drop. 2 1 Share this post Link to post Share on other sites
wallfish 20,380 #12 Posted November 21, 2025 On 11/19/2025 at 3:02 PM, CNC said: Still nothing so I said must be the 2 safety switches. Pulled them off What did you do with the wires? Easier to jump the wires than remove safety switches. Battery ignition on a vintage C-160 would need those wires connected together to complete the circuit. Is there 12v to the small post on the solenoid when the key is turned to the start position? 1 Share this post Link to post Share on other sites
CNC 19 #13 Posted November 26, 2025 Many thanks gwest-ca I will check that out Friday when i get back into the shop You know Squonk I don't know if I wired the ammeter. The glass is broken and it has no needle need to check that! Hi guys Thanks for all your help. I tried all the suggestion. When I took the wires off the safety switches and connected them together THE OLE HORSE CAME ALIVE !!! Ok must be the safety switch, so I connected the PTO switch. Again it started right up. Then the brake switch was connected. I pushed it in with my thumb it started right up.Ok we are ready to go, not so fast CNC. Because when I got on the seat and pushed the brake padel nothing! Oh No!!! Sometimes it is best to stay cool and think about what you are doing. After looking at the tractor while cooling down I notice the bracket holding the safety switch was bent straighten the bracket and guess what everything works great. Boy is my face red!!! HAPPY THANKSGIVING TO ALL!!!! 5 2 Share this post Link to post Share on other sites
