RJR49
How does a hydro lever work
RJR49
Attached is my 1975 C-160 operating smoothly. Notice the bushing i circled is not turning. But, the lift mechanism is moving. There is a Woodruff key holding it to the shaft to the bushing so thats not a surprise. On my 1977 C-160 it's the same configuration but the bushing and the lift mechanism have flats to lock them together. Apparently the mechanism worked once upon a time but I don't see how it could
Edited by RJR49
Mistyped the year of the 2nd tractor
RJR49
RJR49
Back to my problem. I cut the rod to remove the assembly from the tractor, and made a brass rod to replace it. The rod is bolted to the chassis so it can't turn. A Woodruff key locks the bushing (circled in white) to the rod. The flat on the bushing locks the bushing to the assembly. So I don't tee how the fwd / rev lever can possible move!
RJR49
This picture shows the rod & the bushing "locked up"
pfrederi
The rod that goes through from the left side  (with the tab welded to it and bolted doesn't turn.  The D shaped end of the friction collar (cup like) (#80) and the related  D hole in the end plate of #73 hold it constant to #73.  The woodruff key engages the friction cone #82 and immobilizes it as that cross shaft doesn't move.  The Spring and nuts press that cone  82 into the collar 80.  When you move the motion control lever the the collar #80 tries to move...the cone #82 resists (depending how tight the spring is pushing on it.
The woodruff key locks the cone  82 to the shaft.  Your set up seems to lock the collar 80 to the shaft it should only lock the cone 82....
EDIT:  The woodruff key is only 1/2" long your slot for it looks longer.
Edited by pfrederi
RJR49
Thank you very much! So, the problem is that I thought 80 & 82 were ONE piece! Mine seem to be welded together! I suspect that's the problem with the one I tried to  buy as well.
pfrederi
Some pics note the size and location of woodruff key also the D shape on the #80 and 81
RJR49
Thanks again guys!
RJR49
Interesting that none of your parts are corroded. The ones ive seen are corroded to the point that their welded together.
Thanks again guys!
pfrederi
It took awhile to get this one apart and cleaned up
RJR49
I doused the joint with Liquid Wrench and have a 12 ton press. I'm thinkingthat if I make a base to set it on and the press. It should come apart.  Did you have to use heat? I've never tried that and am afraid of annealing or warping the metal.
ineedanother
I suspect it will come apart much much easier than that. A light tap with a hammer on a punch is all I've ever used and they've popped apart even when neglected for years.
pfrederi
Kroil some time and a whack with a hammer and punch.
After you get it cleaned up make sure you  do NOT apply anything to the mating surfaces of the cup and cone (80  82)
RJR49
No grease?
pfrederi
No grease no lube....If you do that you will find you cannot get the motion control lever to stay in position.  The cup and cone create drag.
Edited by pfrederi
RJR49
I put the nut in a vise and gave it a hard tug with a long wrench. I don't think it's coming apart
pfrederi
Kroil on the threaded shaft, both sides, some time and then a bit of heat (propane torch) if still needed. Don't forget the collar is threaded and has that D shape to lock it into the mechanism.  Do not want to booger that up. That threaded shaft has been abused.  When you do get it free you need to square up the last 1/2 inch or so.  Supposed to fit a 5/8" open end wrench
RJR49
I used the press to get it apart. Probably didn't need to. It came apart with one pump. I am afraid of damaging the adjustable collar so I left it along. PIA compressing the spring but it didn't take to long. The rod goes through but not smoothly. I can see a few thousands misalignment but haven't been able to get it out. I'm puttingitall back k togetherthis afternoon. Ill let you know ow how I make out.
pfrederi
You really need to free up the lock nut and the collar  (81 and 85) from the threaded tube. Other wise you will not be able adjust the tension on cup and cone and thus how well your motion control stays where you set it
RJR49
Right now it works ok. If it starts to give me trouble I'll take it apart but I'm afraid that I'll end up having to make a new one.
RJR49
New coller and threaded rod that is
