6wheeler 675 #1 Posted November 13, 2025 Just a quick question. I need a carb for my 165. I ordered one online. Put it on. And cannot get the crappy thing to adjust to save my life. The original carbs throttle plate screws let go so the plate beat up the throat pretty bad. I did scab a new plate and rod from the crapperator that I had ordered. It is pretty sloppy in there and the the throttle rod doesn't seal well. The tractor does start and run. But, the carb. has to be replaced. So, Has anyone found a place to get a good replacement? Isave tractors, does not have any in stock. TIA Pat 1 Share this post Link to post Share on other sites
ebinmaine 77,323 #2 Posted November 13, 2025 I make no secret about how I feel on aftermarket carburetors. I've had several fail. I will not use another one. IMHO And experience you have two options. 1. Contact Brian Badman @76c12091520h 2. CALL Lincoln at A to Z Tractor in PA. 5 2 Share this post Link to post Share on other sites
953 nut 64,108 #3 Posted November 14, 2025 The crappy Chinese carburetors are generally a Carter 26 knock-off and your K341 needs a Carter 30. Lincoln's phone number is 717-821-5242, good guy to work with. 2 2 Share this post Link to post Share on other sites
