markseven   38 #1 Posted 18 hours ago  I got this one Sunday in Corcoran mn 250. I know i can make it sweet 😋 5 5 Share this post Link to post Share on other sites
ebinmaine   74,611 #2 Posted 18 hours ago Cool.   What year? Share this post Link to post Share on other sites
markseven   38 #3 Posted 17 hours ago 1968 to 70 about not exactly sure . Share this post Link to post Share on other sites
ebinmaine   74,611 #4 Posted 17 hours ago 12 minutes ago, markseven said: 1968 to 70 about not exactly sure .  1968 and 69 would have the older smaller hood. 1970 was the new larger type. Share this post Link to post Share on other sites
markseven   38 #5 Posted 6 hours ago Going to remove engine and go thru it . Remove grenade gears and new piston rings bore if necessary. Share this post Link to post Share on other sites
pfrederi   18,980 #6 Posted 6 hours ago You have the Breakerless Ignition system. When it works it is great but when it dies you will be looking at switching to battery points. Make sure you NEVER apply voltage to the terminal on the bottom of the coil. Use only ignition switches with an "M" terminal (magneto type) 1 Share this post Link to post Share on other sites
markseven   38 #7 Posted 5 hours ago Yep that's going away. Share this post Link to post Share on other sites
ebinmaine   74,611 #8 Posted 5 hours ago 16 minutes ago, markseven said: Yep that's going away.   Test it for fire first. If it's still working it has value. In fact if it's still working, I wouldn't remove it. 1 1 Share this post Link to post Share on other sites
pfrederi   18,980 #9 Posted 4 hours ago 54 minutes ago, ebinmaine said:   Test it for fire first. If it's still working it has value. In fact if it's still working, I wouldn't remove it.  I have a couple Breakerless they are much nicer than the battery points or Mag points. No points to ever clean or adjust and timing is always spot on!!!  If it fires and you still want to get rid of it I would buy the trigger and coil from you . 1 Share this post Link to post Share on other sites
