JimSraj 585 #1 Posted November 8, 2025 Does anyone have a source for 101480 bearings? That’s the number from the parts blowup. The ones I’m replacing are 1630RS, Japanese. Local bearing supply has 1630CD, Chinese. I’d really rather use an SKF or Timken. They are for the end of the auger on a 06-42ST05 snowthrower. Share this post Link to post Share on other sites
lynnmor 9,007 #2 Posted November 8, 2025 The letters designate the type of seal which is important in the wet environment of a snowblower. 2 Share this post Link to post Share on other sites
eo1bart 52 #3 Posted November 8, 2025 I ordered two of these the other day for my single stage. They're in the mail to me now. https://www.ebay.com/itm/335937075878 Share this post Link to post Share on other sites
JimSraj 585 #4 Posted November 8, 2025 12 hours ago, lynnmor said: The letters designate the type of seal which is important in the wet environment of a snowblower. Yes, the RS is rubber seal but, my understanding is, CD can mean different things depending on manufacturer. Those that were in it have RS as suffix although they are rubber sealed on both sides which, again, my understanding is that should be 2RS. 1 Share this post Link to post Share on other sites
peter lena 10,013 #5 Posted November 8, 2025 @JimSraj realise what I am going to suggest is a , you can't do that type of thing , reason for this is , consistent , repetitive lubrication failure . have a number of , 6203 ZNL bearings in my stuff , also in my mule drive bearings , regularly search for a similar bearing with WIDE SIDE GREASE SHIELDS ? small flat pocket screwdriver , or small flat putty knife , easily removes the side grease shields , wipe out, original lube , carb cleaner flush out , repack with lucas X-TRA, heavy duty grease , 560 deg flash point , polyurea rated, hand repack , reinstall seals , also have this in all my mower deck spindles , related pto cone needle bearings , guess what ? no whyining noise , or any related failure , blowers are another , GOLD MINE FOR IMPROVEMENT , attachment , ? loaded with hang up areas , specific chain / cable lubricant , snow slider gasket UNDER CHUTE BASE , PAM cooking lubricant makes that swing with ease , a specific change out , to a problem , made it just go away ? thats only me , pete Share this post Link to post Share on other sites
oliver2-44 11,694 #6 Posted November 8, 2025 Your local bearing house should be able to measure that bearing and match it up to an SKF or Timken Share this post Link to post Share on other sites
JimSraj 585 #7 Posted November 11, 2025 Got them and installed but still a lot of noise. The drive shaft had a lot of noise too so I got into it and found one of the bearings had a big chunk out of the race. Bearings #110569. Comes with a collar. I’m replacing both and have them ordered. I’ve never installed this type bearing before so I’d appreciate any and all advice on how to. Share this post Link to post Share on other sites
lynnmor 9,007 #8 Posted November 12, 2025 On 11/11/2025 at 9:58 AM, JimSraj said: Got them and installed but still a lot of noise. The drive shaft had a lot of noise too so I got into it and found one of the bearings had a big chunk out of the race. Bearings #110569. Comes with a collar. I’m replacing both and have them ordered. I’ve never installed this type bearing before so I’d appreciate any and all advice on how to. Get the bearing bolted in place first, then turn the lock collar in the normal direction of operation. You can use a punch and hammer to tighten it, then tighten the set screw in the collar. There is at least one YouTube video with wrong directions. Share this post Link to post Share on other sites
JimSraj 585 #9 Posted November 13, 2025 2 hours ago, lynnmor said: Get the bearing bolted in place first, then turn the lock collar in the normal direction of operation. You can use a punch and hammer to tighten it, then tighten the set screw in the collar. There is at least one YouTube video with wrong directions. Thanks lynnmor. Since I’ll be using a hammer and punch to tighten I’m guessing there should be no play between the collar and the bearing. Share this post Link to post Share on other sites
lynnmor 9,007 #10 Posted November 13, 2025 12 hours ago, JimSraj said: Thanks lynnmor. Since I’ll be using a hammer and punch to tighten I’m guessing there should be no play between the collar and the bearing. "Tighten" of course means no play. 1 Share this post Link to post Share on other sites
