JimSraj 550 #1 Posted 20 hours ago Does anyone have a source for 101480 bearings? That’s the number from the parts blowup. The ones I’m replacing are 1630RS, Japanese. Local bearing supply has 1630CD, Chinese. I’d really rather use an SKF or Timken. They are for the end of the auger on a 06-42ST05 snowthrower. Share this post Link to post Share on other sites
lynnmor 8,085 #2 Posted 20 hours ago The letters designate the type of seal which is important in the wet environment of a snowblower. 2 Share this post Link to post Share on other sites
eo1bart 20 #3 Posted 10 hours ago I ordered two of these the other day for my single stage. They're in the mail to me now. https://www.ebay.com/itm/335937075878 Share this post Link to post Share on other sites
JimSraj 550 #4 Posted 8 hours ago 12 hours ago, lynnmor said: The letters designate the type of seal which is important in the wet environment of a snowblower. Yes, the RS is rubber seal but, my understanding is, CD can mean different things depending on manufacturer. Those that were in it have RS as suffix although they are rubber sealed on both sides which, again, my understanding is that should be 2RS. 1 Share this post Link to post Share on other sites
peter lena 9,455 #5 Posted 6 hours ago @JimSraj realise what I am going to suggest is a , you can't do that type of thing , reason for this is , consistent , repetitive lubrication failure . have a number of , 6203 ZNL bearings in my stuff , also in my mule drive bearings , regularly search for a similar bearing with WIDE SIDE GREASE SHIELDS ? small flat pocket screwdriver , or small flat putty knife , easily removes the side grease shields , wipe out, original lube , carb cleaner flush out , repack with lucas X-TRA, heavy duty grease , 560 deg flash point , polyurea rated, hand repack , reinstall seals , also have this in all my mower deck spindles , related pto cone needle bearings , guess what ? no whyining noise , or any related failure , blowers are another , GOLD MINE FOR IMPROVEMENT , attachment , ? loaded with hang up areas , specific chain / cable lubricant , snow slider gasket UNDER CHUTE BASE , PAM cooking lubricant makes that swing with ease , a specific change out , to a problem , made it just go away ? thats only me , pete Share this post Link to post Share on other sites
oliver2-44 10,976 #6 Posted 6 hours ago Your local bearing house should be able to measure that bearing and match it up to an SKF or Timken Share this post Link to post Share on other sites
