JoeM 10,317 #1 Posted November 7, 2025 Straight from the back burner, I have been tinkering with this 520H. I bought an orbital steering valve from 19richie66 and decides to modify the 520 to power steering. I seen a thread a while ago were someone added steering to a 518. Figured that would be a nice side project if I came across a reasonably priced steering valve. I wanted to keep it looking the same and tucked in the column. It was a little tricky with a mix of face seal and jic piping. Picked up some face seal fitting from MMC and silver soldered to the steel pipe. For now it is on ice, next will be the front axle mod to accept the steering cylinder. Absolutely don't need a 520H with power steering but I like to build things and keeps me out of the Mrs. cross-hairs. Used the c120 and old deck belt to test run. front view 10 Share this post Link to post Share on other sites
ebinmaine 81,046 #2 Posted November 7, 2025 Interesting concept. I've mentally tossed about the idea of using a steering quickener from a race car - but reversed. Twice the steering wheel turns but with half the effort..... 2 Share this post Link to post Share on other sites
peter lena 10,103 #3 Posted November 7, 2025 @JoeM like it ! for me experimentation is a regular thing , don,t have any hydro anything , but can relate to the piping set up . like trying to improve / remove repetitive issues . your side view pictures , did it for me , often refer to roller stooling around a set up , while trying something , makes it much easier, like to change over a plow and frame set up , that way , 2 milk crates hold the frame / plow at close to original set up height , yet you are free , to swap out and detail linkage rods , improve functional detailing, once swapped out improved , you can easily make it effortlessly swing and move , the swing quadrant squeeze lever , runs the entire show . grand son is slotting a golf ball size , palm grip metal push / pull point , he builds welds truck frames . stay at it , pete 1 Share this post Link to post Share on other sites
JoeM 10,317 #4 Posted November 7, 2025 32 minutes ago, ebinmaine said: a steering quickener from a race car - but reversed years ago, I kicked that around myself. In the end I was thinking if the fan gear would hold up and moved on. 2 Share this post Link to post Share on other sites
Handy Don 17,634 #5 Posted November 7, 2025 The 518 conversion was in the UK. As part of the project, the member replaced the lower steering shaft and the tie rods with a solid bar linking the spindles. The hydraulic power steering cylinder moved the bar. Turns out the different linkage configuration didn’t have a proper Ackerman geometry and so steering was easy but cornering caused tire scuffing and wander. 3 Share this post Link to post Share on other sites
JoeM 10,317 #6 Posted November 8, 2025 Testing vid 4 1 Share this post Link to post Share on other sites
Pullstart 71,482 #7 Posted November 8, 2025 @Bow_Extreme Matt, did you have the 520H power steering prototype of many years past? 1 Share this post Link to post Share on other sites
Bow_Extreme 584 #8 Posted November 9, 2025 On 11/8/2025 at 11:13 AM, Pullstart said: @Bow_Extreme Matt, did you have the 520H power steering prototype of many years past? It’s still here. 1 Share this post Link to post Share on other sites
Bow_Extreme 584 #9 Posted November 10, 2025 On 11/8/2025 at 7:32 AM, JoeM said: Testing vid Nice job on this! 1 Share this post Link to post Share on other sites
JoeM 10,317 #10 Posted November 10, 2025 On 11/7/2025 at 5:13 PM, Handy Don said: Turns out the different linkage configuration didn’t have a proper Ackerman geometry and so steering was easy but cornering caused tire scuffing and wander. HD good catch! I went back and searched for the PS thread and found it was done by @Damien Walker. He wrote an excellent PDF with updates. The steering geometry was solved by adding these plates to the arms on both sides. This will save me from cipher'n the problem myself. Damien also sited the number of turns lock to lock. I have about 3 1/2 turns lock to lock. I may replace the cylinder with a smaller lift cylinder from a 520H. It should get me below 2. Damien says he used a 1 inch cylinder and it worked good plus the steering was still easy. 1 Share this post Link to post Share on other sites
Blue Chips 881 #11 Posted November 10, 2025 (edited) On 11/7/2025 at 5:13 PM, Handy Don said: Turns out the different linkage configuration didn’t have a proper Ackerman geometry and so steering was easy but cornering caused tire scuffing and wander. I encountered a similar Ackermann geometry issue on my1953 Ford NAA (Golden Jubilee) tractor. After resetting the front axle to a wider track width (to match the widened rear track width) and resetting the toe-in to the correct amount, it steered easily and tracked perfectly when driving in a straight line, but the sharper the turn, the more the wheels scuffed and dug in, since the radii inscribed by the left and right wheels were no longer concentric with each other. I could see no way to correct the geometry without custom alterations, so I'm planning to change the front track width back to standard width. The main reason I widened the front track width to match the rear was so that I could mow very close to obstacles with the front tires, knowing that the rear tires would also clear the obstacles. I'll just have to be more careful when going by obstacles after I change the front back to standard width. Edited November 10, 2025 by Blue Chips Share this post Link to post Share on other sites
Handy Don 17,634 #12 Posted November 10, 2025 19 minutes ago, Blue Chips said: I encountered a similar Ackermann geometry issue on my1953 Ford NAA (Golden Jubilee) tractor As noted in the couple of previous posts, your issue might be remediable by relatively simple changes. Lots of tractors were designed to have adjustable front tracks and included alternate positions for attaching the tie rods to the central steering actuator and the spindles to maintain good steering geometry. The math for it is standard 11th grade trigonometry combined with carefully accurate measurements. The best explanation I’ve seen online is this one 1 Share this post Link to post Share on other sites
Blue Chips 881 #13 Posted November 10, 2025 (edited) 4 hours ago, Handy Don said: As noted in the couple of previous posts, your issue might be remediable by relatively simple changes. Lots of tractors were designed to have adjustable front tracks and included alternate positions for attaching the tie rods to the central steering actuator and the spindles to maintain good steering geometry. The math is no problem. And yes, the NAA front axle was designed to be adjustable to several different widths, ranging from 48 to 76 inches IIRC. However, I have several shop/service/owner manuals for it, and I have not seen any mention of any steering adjustments to be made after changing the width other than adjusting the tie rods (aka, drag links) for toe-in. Here is a LINK to an owner's manual (see pages 27-30). From my readings and from other owners, the general consensus seems to be that for agricultural use, it wasn't considered very important if the wheels scuffed the ground on sharp turns in soft soil, but if you were using the tractor primarily on hard/paved/smooth surfaces, such as for mowing lawns, it would be a much bigger factor, and you would probably want to leave it set to the standard width. NOTE that the spindle arms only have one attach point for the tie rod end and can only be attached to the spindles in one position, as they are keyed to the spindles. Likewise, the two sector shaft arms (pitman arms) also have only one attach point each for the tie rod end, and the splines were cut in a way that only allows one position on the sector shaft. IF I modified the splines to allow different positions of the pitman arms on the sector shafts, I might have a little to play with regarding changing the relative turning radii of the inside and outside wheels on sharp turns. I don't know if it would be enough, and it's not a high priority, so it will probably never happen. Now that I'm no longer bush hogging about 20 acres of fields (since we sold our other property), I only use the tractor for a once-a-year first mowing/de-weeding of about an acre of grass and cutting down encroaching shrubs around the edges, and I don't want to tear things up too much, so it's going back to a standard width. Edited November 10, 2025 by Blue Chips 1 Share this post Link to post Share on other sites
JoeM 10,317 #14 Posted January 17 Got back to the PS project. Figured out the drag link, next is the steering cylinder mount. 1 2 Share this post Link to post Share on other sites
cleat 9,403 #15 Posted January 17 On 11/8/2025 at 7:32 AM, JoeM said: Testing vid Great way to test. The only issue I heard was the steering lugging the engine at the end of it's stroke. The lift valve has a pressure relief valve built in but because your steering is plumbed in first that valve is not going to help. Long story short, make sure you have a pressure relief ahead of the steering control valve to prevent over pressure issues. Just my 2 cents. 2 Share this post Link to post Share on other sites
JoeM 10,317 #16 Posted January 17 2 hours ago, cleat said: The only issue I heard was the steering lugging the engine at the end of it's stroke. Yeah man, both the steering (power beyond type) and the left valve have reliefs. The lift valve is defiantly set to high. I have not gauged it yet but will have to fine tune as the we get closer. Steering Valve I did get the steering cylinder in place and tested today, need a little adjusting the stops on the spindels but it was real close. 3 1 Share this post Link to post Share on other sites
JoeM 10,317 #17 Posted January 19 A few pics from the project Most of the parts I have laying around. Just a budget friendly thing to do. The spindles and cylinder are xi. I have the front wheels too. The correct hoses and fittings are ordered and on the way. I figured this deserves a foot control.......maybe yes! That will be next. 3 Share this post Link to post Share on other sites
Bill D 3,177 #18 Posted January 19 Very nice. Are you going to make your own foot control? Having fabricated a couple, I look forward to seeing what you come up with. Share this post Link to post Share on other sites
JoeM 10,317 #19 Posted January 19 33 minutes ago, Bill D said: make your own foot control? yep, a little different then the typical versions. This one i have done in the past, uses a grease-able shoulder bolt for the pivot. I like leaving the hand lever hooked up. I have a fused right ankle and sometimes it is cumbersome to use the foot control. this time I might have to work around stuff then usual. 2 Share this post Link to post Share on other sites
JoeM 10,317 #20 Posted January 26 some of the foot control installed have to take a break for the snow storm. 1 Share this post Link to post Share on other sites
JoeM 10,317 #21 Posted May 25 Finally got around to putting on the new tires. New hose are on the steering cylinder. When the wheels are turn to the right and the axle is tilted up the left front tire just touches the front cylinder fitting. Not sure if I am going to mess with it or not. Have to start working on fuel line, pump and sheet metal . Painted the wheel with Krylon metallic paint/primer. Not a restoration grade job but they look okay. 3 Share this post Link to post Share on other sites
Handy Don 17,634 #22 Posted May 25 (edited) Oops Edited May 25 by Handy Don Share this post Link to post Share on other sites
