JimSraj 593 #1 Posted November 6, 2025 I’m looking to find a tractor with more tan 12 hp to mount my snowblower on and this 1999 314-8 (73449) has come up for sale not far from me. It’s got a CH14S with 1400 hrs on it. Spec # 1838. I’m not familiar with the Command series engines. Seller says he’s 2nd owner and used it as a cart horse, bought from neighbor who mowed with it. Always kept inside. Looks good in pictures. Any and all comments on this engine series are appreciated. Thanks in advance. Share this post Link to post Share on other sites
daveoman1966 3,885 #2 Posted November 6, 2025 (edited) I have a 416-8 with the Kohler Magnum 16hp engine. No muffler and it needs a battery. Starts quickly and doesn't smoke. The trans fulid is milky and needs changed....I'll give you the 90-140wt gear lube 5 qt jug. Seat isn't the best, but useable. $500---come and get it. N/W PA---40m south of Lake Erie at zip 16433 416-_CARB.AVI Edited November 6, 2025 by daveoman1966 bad image 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 5,005 #3 Posted November 6, 2025 The Kohler Magnum series was a continuation or improvement on the K-series. Good engines, as good and if not better than the K-series. The Command series replaced the Magnum series and was also great engines. The only Kohler engine series to avoid is the Courage, with its plastic internal parts. 4 Share this post Link to post Share on other sites
clueless 3,440 #4 Posted November 6, 2025 I don't think 2 more hp is going to make a big difference with you snowblower Share this post Link to post Share on other sites
sqrlgtr 4,225 #5 Posted November 6, 2025 3 hours ago, T-Mo said: The only Kohler engine series to avoid is the Courage, with its plastic internal parts. Its named right takes "Courage" to use one over a K or Magnum. Share this post Link to post Share on other sites
My_horse 152 #6 Posted November 6, 2025 I have a year 2000 314-8 with 73449 model #. Never had any real problems with it when running a blower. Plenty of power. Share this post Link to post Share on other sites
JimSraj 593 #7 Posted November 6, 2025 My_horse. Are you running a single stage or 2 stage? Share this post Link to post Share on other sites
squonk 48,427 #8 Posted November 6, 2025 I ran a SS tall shoot on a C 145 with a k321 1 Share this post Link to post Share on other sites
JimSraj 593 #9 Posted November 7, 2025 Squonk, that’s one helluva snow throwing going on there. I’ve never been able to get close to that kind of performance out of mine running off of a M12 with a short chute. Impressive! Share this post Link to post Share on other sites
T-Mo-(Moderator) 5,005 #10 Posted November 7, 2025 18 hours ago, sqrlgtr said: Its named right takes "Courage" to use one over a K or Magnum. I think Kohler was counting on their reputation with their other engines, K-Series up to the Command, to convince buyers that the Courage was a good engine. A lot of entry level machines, plus a few more expensive ones, got the Courage. So buyers bought that machine because it had a Kohler in it. Share this post Link to post Share on other sites
