"Manic-Mechanic" 1,485 #1 Posted November 3, 2025 (edited) Adjusting the PTO can be hit & miss for sure! Here it’s just barely holding on “brake” Edited November 3, 2025 by "Manic-Mechanic" Share this post Link to post Share on other sites
ri702bill 11,629 #2 Posted November 3, 2025 When you engage the PTO, does the engine / shaker plate assembly torque back towards you?? Mine used to on the C81. Went with the solid mounts; engagement now is smooth and predictable unlike before... Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #3 Posted November 3, 2025 (edited) 2 minutes ago, ri702bill said: When you engage the PTO, does the engine / shaker plate assembly torque back towards you?? Mine used to on the C81. Went with the solid mounts; engagement now is smooth and predictable unlike before... Not so much as to effect this assembly, but the drive belt while using the deck off that older pulley system used to come off on occasions. I may just remove that older mule off the tractor.. Edited November 3, 2025 by "Manic-Mechanic" Share this post Link to post Share on other sites
