Denis L Goulet 22 #1 Posted November 2, 2025 i have a wheelhorse 520h 1996,i have an issue with starter,it clicks a few times before starting,i replaced starter with new one and i have same problem,i checked all connections,all grounding wires,charged battery,replaced ignition,but have same problem,i tried to acces start relay under battery but cant acces because of cab,any ideas on what else i should verify before removing cab. Share this post Link to post Share on other sites
ri702bill 11,254 #2 Posted November 2, 2025 If you jump +12 volts to the starter connection - the one with the cable from the solenoid, and it spins right over 3 or for times, I'd be looking at the solenoid as the cause. Secondly, pull the dreaded 9-pin connector apart & inspect for evidence of corrosion and / or overheating.... It may not be sending full voltage to the solenoid.... 4 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,998 #3 Posted November 2, 2025 3 relays are all the same part number. The wire colors going to each will be the way to identify what each does. You need the kill relay to have ignition. You could borrow it to try in place of the switching relay and start relay as both are needed for the starter. It just won't run because of no ignition. 1 Share this post Link to post Share on other sites
lynnmor 8,623 #4 Posted November 2, 2025 It is possible that your battery is bad, connect jumper cables from your car and try to start. 3 Share this post Link to post Share on other sites
Handy Don 15,933 #5 Posted November 4, 2025 On 11/2/2025 at 4:31 PM, lynnmor said: It is possible that your battery is bad, connect jumper cables from your car and try to start. Seconding this. A dying battery can easily read 12v or more with no load but drop down a lot once connected to a load. 2 Share this post Link to post Share on other sites
Denis L Goulet 22 #6 Posted November 9, 2025 ok i will check battery, and ckeck the 9pine connection Share this post Link to post Share on other sites
953 nut 64,108 #7 Posted November 9, 2025 You should also take a look at the fuse holder for the 25 Amp fuse, if it is corroded that can reduce the voltage going to your solenoid to activate it. Share this post Link to post Share on other sites
