FLtractor 253 #1 Posted November 1, 2025 Evening, other than the engine size, are there any differences between a 856, 857 and 1057? Are any of them considered more rare useful or valuable as a work horse mower? Easier to maintain or desirable features? Share this post Link to post Share on other sites
rjg854 13,454 #2 Posted November 1, 2025 All those are basically the same tractor as my 68 Commando 8, nothing rare about them. Just model changes yearly. 3 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #3 Posted November 2, 2025 (edited) Basically decals. Or possibly seat change design wheel horse golden era. Because these are four speeds, I would not consider them rare. But that timeframe if you had a six speed that would be somewhat rare because of the production numbers I hope this helps. Edited November 2, 2025 by Retired Wrencher 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #4 Posted November 2, 2025 18 hours ago, FLtractor said: Evening, other than the engine size, are there any differences between a 856, 857 and 1057? The mid 60s model numbers break down: Ex: 856 8 HP 5 = THREE speed 6 ≈ 1966 Transmissions: 4 or 5 = THREE speed 6 = SIX speed 7 ≈ hydro 18 hours ago, FLtractor said: Are any of them considered more rare useful or valuable as a work horse mower? The six speeds are a special tractor because of the Limited Slip Differential. IMHO the SIX speeds with the Limited Slip Differential are the best of the mid to late 60s workers. 18 hours ago, FLtractor said: Easier to maintain or desirable features? Maintenance would be about equal across any model. Desirable features might be a certain correct steering wheel or the cigar lighter. Certain implements too. 1 Share this post Link to post Share on other sites
squonk 48,427 #5 Posted November 2, 2025 Best thing about the short timers. Turning radius. Great for mowing. I can buzz around and trim around my trees with my 875 and RD deck whilst my C-160 I have to futz around the trees to get it all. They are also great for plowing snow. 2 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #6 Posted November 2, 2025 856 and 857 short frame tractors with 41-1/4" wheelbase 1057 long frame tractor with 45-1/2" wheelbase 2 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #7 Posted November 3, 2025 11 hours ago, gwest_ca said: 856 and 857 short frame tractors with 41-1/4" wheelbase 1057 long frame tractor with 45-1/2" wheelbase Thanks Garry. I forgot about the long frame on the 1057. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #8 Posted November 4, 2025 I’ll chip in that the LSD has more internal metal-to-metal friction than the 8-pinion or older bevel gear differentials whenever the real wheels are turning at different speeds. For that reason, it runs with a higher oil level than the earlier 3-speeds and I keep a closer eye on the transaxle oil and change it every other year (I estimate 30-ish hours of runtime per year). I’ll be putting in a magnetic drain plug at the next oil change, as well. 4 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #9 Posted November 8, 2025 @Handy Don I’ll be putting in a magnetic drain plug at the next oil change, as well. Why? Share this post Link to post Share on other sites
Handy Don 17,735 #10 Posted November 8, 2025 (edited) 6 hours ago, Retired Wrencher said: @Handy Don I’ll be putting in a magnetic drain plug at the next oil change, as well. Why? Generally, any stuff suspended in the oil as it circulates can become an abrasive and cause unwanted wear. Metal in particular. Transaxles have lots of metal rubbing against metal which can create metal particles through ordinary use. The design of the 5060/5071 LSD differentials has even more metal on metal friction. (This is not a criticism--I chose to take on the potential wear to get the benefits.) While all the hydros and some engines in WHs have oil filters, most do not (my 854 with its 5060 and K181, for example). The magnetic plug can attract and hold metal particles and prevent them from circulating between oil changes. Edited November 8, 2025 by Handy Don Share this post Link to post Share on other sites
Retired Wrencher 7,043 #11 Posted November 8, 2025 2 hours ago, Handy Don said: Generally, any stuff suspended in the oil as it circulates can become an abrasive and cause unwanted wear. Metal in particular. Transaxles have lots of metal rubbing against metal which can create metal particles through ordinary use. The design of the 5060/5071 LSD differentials has even more metal on metal friction. (This is not a criticism--I chose to take on the potential wear to get the benefits.) While all the hydros and some engines in WHs have oil filters, most do not (my 854 with its 5060 and K181, for example). The magnetic plug can attract and hold metal particles and prevent them from circulating between oil changes. Don Just saying I believe in diesel fuel or kerosene flush. I had a 606 one time of of EBay bid I could not move this. Tranny was frozen. Many flushes it freed up. Changed all sealers and sold it in the spring. 2 Share this post Link to post Share on other sites
Handy Don 17,735 #12 Posted November 8, 2025 50 minutes ago, Retired Wrencher said: Just saying I believe in diesel fuel or kerosene flush. Different steps for different objectives. If I don’t detect water, rust, or other contamination, I drain and refill without flushing. In that case, any residual gear oil isn’t worth fighting over. The plug is for extra insurance. (Also, I don’t have an easy way to properly discard used diesel or kerosene so I avoid creating any when possible!) 2 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #13 Posted November 16, 2025 On 11/8/2025 at 3:42 PM, Handy Don said: Different steps for different objectives. If I don’t detect water, rust, or other contamination, I drain and refill without flushing. In that case, any residual gear oil isn’t worth fighting over. The plug is for extra insurance. (Also, I don’t have an easy way to properly discard used diesel or kerosene so I avoid creating any when possible!) Well Don there used to be a auto parts store that used to take oil and what I used to fly shot the tranny and they just put it in their furnace that was happy with that but they knew what I had in there also. They used to see if it’s fuel it would burn. Share this post Link to post Share on other sites
Handy Don 17,735 #14 Posted November 16, 2025 4 hours ago, Retired Wrencher said: Well Don there used to be a auto parts store that used to take oil and what I used to fly shot the tranny and they just put it in their furnace that was happy with that but they knew what I had in there also. They used to see if it’s fuel it would burn. NY requires any shop that does oil changes to accept used motor oil from the public, but they are allowed to set some standards for what they will accept. ALL of the shops in my village demand plain oil, either dino or synthetic, with no adulteration whatsoever. If they detect a whiff of gas, kerosene, or diesel they just flat reject it. Why? Because all of them are selling that used oil to a re-refiner who imposes the standards on them. A couple of quarts of contaminated oil in their 55-gallon collection drum and the entire barrel might be rejected (the pickup people don’t sniff, they sample and test). When/if that happens, the shop has to PAY a hazardous waste company to take it. ’Nuf said. 1 Share this post Link to post Share on other sites
