Blue Chips 855 #1 Posted October 30, 2025 (edited) On the 5xi-series tractors, the plastic fuel tank (which I assume is some kind of polyethylene) is secured at its top and sides by several irregularly-shaped pieces of foam rubber sandwiched between the tank and the rear fender. The old foam rubber on my GT18 had deteriorated to what was essentially powder, which allowed the tank to flop around, and it's probably not in any better shape on my 522xi, which is the same vintage (2001). I haven't yet been able to find any OEM or specific aftermarket replacements for the foam pieces, but if anyone knows of any, let me know. In the meantime, I'm going to experiment a bit and try fabricating some replacements. I didn't know how thick the original foam was, since there wasn't any intact foam to measure, so I thought I would start by determining what the space is between the fender and the tank. To measure the space, I stuck little mounds of modeling clay at several locations on the tank, placed a little piece of polyethylene over each one to keep it from sticking to the fender, laid the fender in place with the mounting holes aligned with the captive nuts in the frame, and pushed straight down on the fender until it contacted the frame. When I lifted off the fender, the height of each mound of clay was mashed down to match the space. All of the mounds measured 9/16" or very close to it. The foam rubber will need to be a little thicker than the space, so that it compresses just enough against the tank to hold it securely. I'm going to have to guess as to what thickness and compressibility would work best, based on a combination of intuition, logic, and black magic. It's possible that I might have to try a few different foam rubber combinations before I find one that will hold the tank securely without stressing anything. To begin my first experiment, I just ordered some 3/4" foam made of a blend of Buna-N, neoprene, and vinyl. It's listed as having good oil resistance, and it's considered ultra soft (rated at 4 psi to compress it 25%). This is a closed-cell foam, but the original foam might have been open cell (I think there are some pros and cons to each). I will need to be careful to place the foam pieces so that they allow drainage and not trap water anywhere. The foam should arrive in a day or two, and I'll post an update on how it goes. Edited October 31, 2025 by Blue Chips 5 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #2 Posted October 30, 2025 Seeing under the rear fender pan reminded me of this service bulletin. Most likely does not apply to you. May get an idea for the shape of some of the foam. The rear one not in view. https://www.partstree.com/models/73545-520-lxi-toro-garden-tractor-sn-089000001-089999999-1998/fender-and-fuel-system-assembly-11/ Hope you have the service manual Service manual split up for higher resolution 2 1 Share this post Link to post Share on other sites
Blue Chips 855 #3 Posted October 31, 2025 (edited) 6 hours ago, gwest_ca said: Seeing under the rear fender pan reminded me of this service bulletin. Most likely does not apply to you. My 522xi has cruise control, but the serial number is not in the list of affected units. I checked just now anyway, and the wiring is routed correctly. As to the tank venting, it's been fine, and both of my tractors have a different (newer?) vent tube configuration than the one shown in the service bulletin. 6 hours ago, gwest_ca said: May get an idea for the shape of some of the foam. The rear one not in view. https://www.partstree.com/models/73545-520-lxi-toro-garden-tractor-sn-089000001-089999999-1998/fender-and-fuel-system-assembly-11/ Hope you have the service manual Even though the foam pads on mine had deteriorated, you could still see the remnants of the adhesive backing before I cleaned it off, so I know where the pads went and how they were shaped. I just don't have an actual sample of the pads in good enough condition to see what kind of foam was used and how compressible it was, so I'm going to wing it and see what works best. Who knows, maybe I can improve upon what was used originally. And yes, thank you, I have files and/or links for all of the manuals for my 522xi and GT18, as well as the Kohler engines. Edited October 31, 2025 by Blue Chips 2 Share this post Link to post Share on other sites
Pullstart 71,259 #4 Posted October 31, 2025 Reading the thread topic, I thought you were acquiring more fuel tanks, or securing them for future use! Great thread! 1 1 Share this post Link to post Share on other sites
Blue Chips 855 #5 Posted October 31, 2025 (edited) 2 hours ago, Pullstart said: Reading the thread topic, I thought you were acquiring more fuel tanks, or securing them for future use! Great thread! I can see where the topic title could have been interpreted that way. I just addressed the situation by carrying out a disambiguation operation upon the inexplicit verbiage to avoid potential misinterpretation (i.e., I edited the title). Edited October 31, 2025 by Blue Chips 3 Share this post Link to post Share on other sites
kpinnc 18,969 #6 Posted October 31, 2025 3 hours ago, Blue Chips said: just addressed the situation by carrying out a disambiguation operation upon the inexplicit verbiage to avoid potential misinterpretation I suddenly felt like I was working. ...oh wait a minute, I AM at work! Hate it when that happens... 3 Share this post Link to post Share on other sites
ebinmaine 80,740 #7 Posted November 2, 2025 On 10/31/2025 at 8:53 AM, Blue Chips said: I just addressed the situation by carrying out a disambiguation operation upon the inexplicit verbiage to avoid potential misinterpretation (i.e., I edited the title). Nicely done 1 Share this post Link to post Share on other sites
Blue Chips 855 #8 Posted November 4, 2025 I received the foam rubber that I ordered and started making the replacement foam fuel tank pads. Based on the tell-tale adhesive residue from the original foam pads, I made some paper templates that I think are a pretty close match to the original pad shapes. I then traced the patterns onto the new foam, cut out the pieces, and chamfered the edges with an angle grinder. Here are a couple of the patterns: I did a 'dry run' by setting the fender in place over the foam and fuel tank without gluing down the foam, and then pressing down on the fender to see where any adjustments in the foam might be needed. I think the replacement foam might be a little firmer than the original foam, and there was one area that didn't compress as easily as I thought it should, so I marked cut lines on that area and cut grooves into the foam to make it easier to compress. I cut all of the pads and grooves freehand, but any unevenness will be completely out of sight, hidden between the fender and the fuel tank. I didn't have anything to go by other than my gut feeling, but I 'think' that worked pretty well. I tried another dry run, and when I pushed down on the fender, it seemed to me that the tank was held firmly and fairly evenly without putting too much pressure on it. The next step is to adhere the foam pieces to the tank and do the final assembly. I'm just waiting for an order of special double-sided tape that is supposed to adhere well to low-surface-energy (LSE) materials. https://www.3m.com/3M/en_US/p/d/b5005036159/ I haven't used this particular tape before. We'll see how it goes... 2 Share this post Link to post Share on other sites
kpinnc 18,969 #9 Posted November 4, 2025 15 minutes ago, Blue Chips said: I cut all of the pads and grooves freehand, but any unevenness will be completely out of sight, hidden between the fender and the fuel tank. Freehand or not, that looks awesome! 1 1 Share this post Link to post Share on other sites
ebinmaine 80,740 #10 Posted November 4, 2025 10 minutes ago, kpinnc said: Freehand or not, that looks awesome! Nice 1 Share this post Link to post Share on other sites
