Racinbob 12,552 #401 Posted Monday at 03:22 PM We don't get near the lake effect here as we did just northeast of here but it does happen. The bulk of the system snow stayed south but the lake effect hit overnight. By this morning it was just east of us so I got some playtime. Maybe 6" and very light. The county pulled the plows off the roads last night but got them out there this morning. I got most of the drive done but the plow hasn't made a pass yet. I didn't bother doing much at the end of the drive. I came in to unfreeze my fingers and will wait on the plow before I go back out. I thought about getting some of those one use heat thingys to slip in my mittens and I'm thinking about it again. But I still don't have any. 4 Share this post Link to post Share on other sites
ML3 2,096 #402 Posted Monday at 03:41 PM Still snowing here since early Sunday morning. Cleared driveway & already 2" accumulated. Gave the 702 quite a workout. Snow was pretty light yet still almost a foot deep so it did a pretty good job. Took today off so I had time to play on tractor instead of using Toro 2stage walk behind.....thats not as fun🤪 VID_20260126_101329.mp4 VID_20260126_101359.mp4 1 1 Share this post Link to post Share on other sites
kpinnc 16,774 #403 Posted Monday at 04:06 PM 3 hours ago, Bar Nuthin said: Probably not up to code but works great for us That is awesome! 1 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,687 #404 Posted Monday at 04:15 PM We got about 18” with drifts 2-3’. I’ve had the blower attachment for years, but most of our storms are ink the 6” range so never really had to use it. The beginning of this season however, I said what the heck, and put it on the 416-8. Well I am sure glad I did, that single stage on a 16hp Onan throws the snow unbelievably far. I probably could have done everything with the blade, but my driveway would have been 33% narrower. Had so much fun, I helped my neighbor too. 8 2 Share this post Link to post Share on other sites
Ed Kennell 44,314 #405 Posted Monday at 05:39 PM I woke up this morning to the sound of my neighbor firing up his Kubota. All the driveways were packed tight with 3-4 feet of snow from PENNDOTS plowing. He used the Kubota with the FEL to remove the packed snow so I could get in with the 520H to plow the driveways. We just finished all seven driveways. We had about 10 inches of snow then several hours of sleet creating one of the heaviest snows I had to plow. 8 3 Share this post Link to post Share on other sites
Sodaking27 1,093 #406 Posted Monday at 07:28 PM 416H with the blower not so good. The clip and washer under the blower that holds it to the lift rod came off. As I was backing it into the garage the right side chain came off and I also noticed the battery was not charging. Discovered the 30 amp fuse was very loose in its connection. Looks like I need to spend some time on it when it warms up. Blower was working great up until that. Finished up with the blade on the 315 without any further issues. Great time while it lasted. 1 Share this post Link to post Share on other sites
Blue Chips 613 #407 Posted Monday at 08:44 PM Finally got the driveway cleared. The backpack leaf blower experiment was a failure. It cleared newly fallen snow pretty well, but if the snow was allowed to sit for a couple of hours, the snow flakes seemed to sort of cake together and wouldn't blow away, despite the snow being cold, dry, and light. I measured 14 inches in several places on the driveway. Might get some more snow tonight...maybe. Ended up using Mr. Case to clear the drive, which is sort of like using a wrench to fix a watch, but it worked. 5 Share this post Link to post Share on other sites
cleat 8,546 #408 Posted Monday at 09:20 PM Too much snow for my 520HC with the plow so I got out the big girl. First time it has been started since last fall an parked in an unheated coverall building and we just had a very cold weekend. But the diesel engine roared to life almost instantly. 8 1 Share this post Link to post Share on other sites
ebinmaine 76,863 #409 Posted Monday at 09:24 PM 10 hours ago, ebinmaine said: Nowhere near the original forecast here. We're currently setting with 11" of very fluffy snow on the side deck. Driveway likely has a touch more. It appears that we won't see much more. At last check we had some areas of the yard with 13" - 15" Still snowing much of the night but very light. 2 Share this post Link to post Share on other sites
rjg854 12,750 #410 Posted Monday at 10:16 PM I ended up with 9-10" depending on where I measured. It was a dry snow and blew nicely. The only problem I had was, in I lost one of the roller chains, but the blower found it. Locked the auger up and shut the 16 Auto down. Took some effort but all is well, except for that roller chain. 6 Share this post Link to post Share on other sites
squonk 45,167 #411 Posted Monday at 10:24 PM Got between 8 and 10" Did most of it with the 953 but it had already started to compact itself so the Village and State boys leftovers were a challenge. Got out the Ariens and was hitting the top of the trees but it only made it about 10 ft and it stopped blowing. I had to adjust the auger belt all the way out. Got new belts ordered. I think they are original 1990 vintage. Pushed all the piles back with Elvis. The hydraulic system did not like this cold weather! 5 1 Share this post Link to post Share on other sites
Handy Don 15,682 #412 Posted Monday at 10:37 PM Well, my spouse and I took a short vacay with a planned return on Sunday, the 25th, to New York. By Friday it was clear we needed a new plan and traveled on Saturday instead (our original flight was later cancelled. Whew!) By this morning we had 14” which needed a session last evening after the first 8 or so inches and then again this morning for the rest. Two neighbors had their snowblowers break down so I got a lot of extra seat time being a Good Samaritan. Two and a half tanks of fuel on the sipper K181. Today’s learning? I’d retired my walk behind blower to storage after the blade did such a great job last year and up to now this year on spaced out snowfalls of up to 5”, including the wet stuff. Well, the blower will get un-retired this week. We don’t have enough places where the 854+blade can park a heavy snow so extra pushing past 18” high banks took a lot of time. A pass down each side with the blower could’ve knocked down those banks to make room. Forecasts tell me what we have isn’t gonna melt soon and more is coming! 3 Share this post Link to post Share on other sites
MainelyWheelhorse 2,300 #413 Posted Monday at 10:38 PM We got close to 12” of sand like snow and have been off and on getting more all day. The 308 didn’t break a sweat. 3 1 Share this post Link to post Share on other sites
Wayne0 1,458 #414 Posted Monday at 10:47 PM (edited) We got a good 15" and the 520H with the deuce stood up to the task. The 3 foot berm at the street had to be taken down in layers. Even with weights and chains, I did get stuck a couple times due to ice under the snow. I need to load the tires. Also noticed the auger bearings are junk. Edited Monday at 10:47 PM by Wayne0 1 1 Share this post Link to post Share on other sites
WHX?? 54,096 #415 Posted Monday at 11:01 PM (edited) 15 minutes ago, Wayne0 said: Also noticed the auger bearings are junk. Posted in your other thread Wayne. I can send you my old bushings to get ya by. Best thing to try when you get hung up drop the blower to get weight off the front and back on the rear. Back out carefully in the same tracks dragging the blower. Lift the blower back up when clear. Edited Monday at 11:05 PM by WHX?? 2 Share this post Link to post Share on other sites
Bar Nuthin 2,152 #416 Posted yesterday at 02:23 AM Didn't realize the wife was recording from inside her warm kitchen. Like I said earlier, I love Hydros! 5 1 Share this post Link to post Share on other sites
kick 80 #417 Posted yesterday at 03:58 AM (edited) I’m glad to have two horses set up for snow duty. Had a chain come off my D160 so i finished up with my 417. We have another storm potentially brewing here NJ. Possibly a NorEaster. Edited yesterday at 04:01 AM by kick 2 5 Share this post Link to post Share on other sites
Wayne0 1,458 #418 Posted 23 hours ago (edited) 14 hours ago, WHX?? said: Posted in your other thread Wayne. I can send you my old bushings to get ya by. Best thing to try when you get hung up drop the blower to get weight off the front and back on the rear. Back out carefully in the same tracks dragging the blower. Lift the blower back up when clear. Thanks for the offer, WHX??. I think I can get by for now with the blade on 'Ol Rusty. Edited 23 hours ago by Wayne0 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,803 #419 Posted 20 hours ago Well a little bit of thawing seemed to really help. Wet concrete grips better than frozen. So got a couple driveways done. Then my friend and I got a Wheel Horse Man Date in as we plowed the parking lot for small school. Mine is the 416-8 and his is the 417-A. We were plowing after dark for a few hours. First time I needed the headlights for work. Was glad I had them though. Parking lot lights were out. But we got it cleared off pretty good. 7 Share this post Link to post Share on other sites
kick 80 #420 Posted 17 hours ago 3 hours ago, OutdoorEnvy said: Well a little bit of thawing seemed to really help. Wet concrete grips better than frozen. So got a couple driveways done. Then my friend and I got a Wheel Horse Man Date in as we plowed the parking lot for small school. Mine is the 416-8 and his is the 417-A. We were plowing after dark for a few hours. First time I needed the headlights for work. Was glad I had them though. Parking lot lights were out. But we got it cleared off pretty good. I’m surprised you guys get traction with no chains. I’m running turf tires/chains. But if I had agriculture tires with all the ice. I think my Horses would be stuck 99% of the time. 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,803 #421 Posted 16 hours ago 5 minutes ago, kick said: I’m surprised you guys get traction with no chains. I’m running turf tires/chains. But if I had agriculture tires with all the ice. I think my Horses would be stuck 99% of the time. You should see my earlier post on the previous page from a couple days ago...it was a major problem Chains are in the near future. I have an extra set of rims and old turf tires perfect to be a dedicated set with chains on them. 1 Share this post Link to post Share on other sites
AlexR 2,385 #422 Posted 14 hours ago I cheated today... Used my neighbors skidsteer. With the wind, we are getting bad drifting still. (Large empty field across the road from my property where the wind is blowing from) Lot of snow piled up around the mailbox and the ends of my driveway. It's drifting in the road a bunch and the plows keep pushing it towards the mailbox and the mailman was having difficulty getting to the mailbox. And lots of other drifts I had to clear out, and the skidsteer does what these Wheelhorse's can't really do unless you have a loader and that is stack snow piles 1 1 Share this post Link to post Share on other sites
Handy Don 15,682 #423 Posted 13 hours ago 1 hour ago, AlexR said: does what these Wheelhorse's can't really do ALWAYS important to use the right tool for the job! 1 Share this post Link to post Share on other sites
WHX?? 54,096 #424 Posted 11 hours ago 3 hours ago, AlexR said: unless you have a loader Should we start looking for you??? Pullstart has one that is a basket ... nevermind 1 Share this post Link to post Share on other sites
AlexR 2,385 #425 Posted 2 hours ago 9 hours ago, WHX?? said: Should we start looking for you??? Pullstart has one that is a basket ... nevermind Don't tempt me! Haha I do plan on either building or getting a loader some day, but not yet. 1 Share this post Link to post Share on other sites
