Tonytoro416 1,372 #1 Posted October 27, 2025 Last of my grandfathers tractors to restore. Procrastinated on this although have been gathering parts for several years. I knew the tractor was modified but to what extent I had no clue. Ross steering boxed had been a problem for years luckily it was still there. Fuel tank and battery swapped positions and rock shaft and hydraulic lift was stripped long ago. Someone added a longer steering column and smaller steering wheel. Motor was swapped with a Briggs at some point. None of these original parts remained. Belt guards where thin tin type material. Toolbox rear sections was long gone replaced with plywood. Of course seat was missing along with frame so I began THE GOAL: for it to be close to factory as I could get it and function rebuilt Ross steering box and replaced column or tube with correct length one and remade toolbox to the best of my abilities 4 15 Share this post Link to post Share on other sites
ebinmaine 80,067 #2 Posted October 27, 2025 Super cool... Share this post Link to post Share on other sites
Tonytoro416 1,372 #3 Posted October 27, 2025 (edited) Battery box fabbed although with countless other holes and things welded up front axle pin was excessively worn. Luckily axle itself was ok. The pin and frame not so much. I machined a bushing with a through hole and used a 1/2” grade 8 bolt . The front axle and steering are now whisper smooth and tougher than it ever was Edited October 27, 2025 by Tonytoro416 2 20 Share this post Link to post Share on other sites
Tonytoro416 1,372 #4 Posted October 27, 2025 For the life of me I CAN NOT understand why people hack up these tractors the way they do 4 1 Share this post Link to post Share on other sites
JoeM 10,120 #5 Posted October 27, 2025 (edited) Awesome Work! I like attention to details. Making the weights match the wheels. Edited October 27, 2025 by JoeM 4 1 Share this post Link to post Share on other sites
ML3 2,464 #6 Posted October 27, 2025 46 minutes ago, JoeM said: Awesome Work! I like attention to details. Making the weights match the wheels. 1 Share this post Link to post Share on other sites
ML3 2,464 #7 Posted October 27, 2025 I like the 953s. Mine is an early model w/ross steering. s/n 62-613. My rear wheel weights are painted white also. 3 10 Share this post Link to post Share on other sites
Handy Don 17,168 #8 Posted October 27, 2025 3 hours ago, Tonytoro416 said: For the life of me I CAN NOT understand why people hack up these tractors the way they do I can. Quite easily. 1. Their tractor--their choice 2. It’s just a machine--I’ll make it the way I want it 3. Expediency 1 Share this post Link to post Share on other sites
ri702bill 12,689 #9 Posted October 27, 2025 6 minutes ago, Handy Don said: I can. Quite easily. 1. Their tractor--their choice 2. It’s just a machine--I’ll make it the way I want it 3. Expediency Sad, but the hack "fixes" are seldom, if ever, followed by more robust correct long term ones. Their motto - "Good e'nuf is good e'nuf" 2 1 Share this post Link to post Share on other sites
Handy Don 17,168 #10 Posted October 27, 2025 28 minutes ago, ri702bill said: Sad, but the hack "fixes" are seldom, if ever, followed by more robust correct long term ones. Their motto - "Good e'nuf is good e'nuf" Number 4 on the list! Thanks 1 Share this post Link to post Share on other sites
953 nut 68,133 #11 Posted October 27, 2025 Tony, that is an impressive transformation, your grandfather would be so proud to see his 953 looking better than new. 1 2 2 Share this post Link to post Share on other sites
RED-Z06 2,718 #12 Posted October 27, 2025 2 hours ago, Handy Don said: Number 4 on the list! Thanks "Fixed for now" 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,372 #13 Posted October 28, 2025 1 hour ago, 953 nut said: Tony, that is an impressive transformation, your grandfather would be so proud to see his 953 looking better than new. Thank you sir. That means a lot 1 1 Share this post Link to post Share on other sites
mrc 1,108 #14 Posted October 28, 2025 beautiful job. well done sir! 2 1 Share this post Link to post Share on other sites
WHX?? 57,629 #15 Posted October 28, 2025 WOW ... 953/1054 the hardest of models to restore @Achto knows. 1 2 1 Share this post Link to post Share on other sites
Tonytoro416 1,372 #16 Posted October 28, 2025 1 hour ago, mrc said: beautiful job. well done sir! Thank you Share this post Link to post Share on other sites
Achto 32,245 #17 Posted October 28, 2025 Great Job !!! 953's are a bigger challenge than some of the other tractors. 1 Share this post Link to post Share on other sites
rjg854 13,268 #18 Posted October 28, 2025 Wonderful job, she's a real beauty. Even better than off the assembly line. 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,372 #19 Posted October 28, 2025 Not a lot of progress but decals on. And some other odds and ends things. Mostly buttoning up and fitment addressing. Kind of stepped back to see what else I need part wise and tried to get some of that on its way 1 7 Share this post Link to post Share on other sites
