702854boy 1,245 #51 Posted May 5 36 minutes ago, Handy Don said: The transaxle drive pulley on the 6-speeds is unusual in that the sheave must run very, very close to the transaxle body (~.125”) to maintain the proper belt alignment to the small block K181. As well, the input shaft is very short, not leaving enough room for a hub on the side away from the transaxle case. To accommodate both requirements, the stock pulley has the setscrew in the valley of the sheave. My transaxle came without the pulley (which should have gotten my attention!). After not finding a suitable after-market pulley I finally got a used one. I would check with the vendors on this site--AtoZ (CALL Lincoln, don’t email) and K&B horse parts (Brian Badman @76c12091520h) My 6 speed also has a 5/8 input shaft instead of the 3/4 but it still has the 6 speed brake linkage, did they make the right pulley for the 5/8 shaft or do we have to figure out how to get something else to work Share this post Link to post Share on other sites
Handy Don 17,735 #52 Posted May 5 1 minute ago, 702854boy said: My 6 speed also has a 5/8 input shaft instead of the 3/4 but it still has the 6 speed brake linkage, did they make the right pulley for the 5/8 shaft or do we have to figure out how to get something else to work Yes, the stock pulley has a ⅝” bore. I think that the largest engine used with 6-speed transaxles was 9hp. With increasing horsepower the width of the engine changed so a longer and thicker transaxle input shaft became necessary, along with other adjustments. Share this post Link to post Share on other sites
702854boy 1,245 #53 Posted May 5 1 hour ago, Handy Don said: I think that the largest engine used with 6-speed transaxles was 9hp. Wouldn't the 1067 and 1267 have had a 6 speed? Share this post Link to post Share on other sites
kpinnc 19,105 #54 Posted May 5 (edited) 5 minutes ago, 702854boy said: Wouldn't the 1067 and 1267 have had a 6 speed? And Raiders up to 14hp. My 1973 Bronco (hydrostatic) still had the 10 pinion differential originally. I thought the 1973-1974 period was when the heavy differentials were introduced? Maybe my question should be what exactly is a 6 speed vs an 8 speed? I know the brake drum orientation changed at some point but did the differential change coincide with this? And I also thought all trannies with high/low had 5/8 input shafts? Edited May 5 by kpinnc Share this post Link to post Share on other sites
Handy Don 17,735 #55 Posted May 5 (edited) 1 hour ago, 702854boy said: Wouldn't the 1067 and 1267 have had a 6 speed? Yes 1 hour ago, kpinnc said: And Raiders up to 14hp. Nope. Only to 12 with Unidrive My 1973 Bronco (hydrostatic) still had the 10 pinion differential originally. 6-speeds had LSD, but not all LSDs were in 6-speeds I thought the 1973-1974 period was when the heavy differentials were introduced? Not clear to me. By “heavy” do you mean 8-pinion (vs. 10-pinion in the LSD)? Maybe my question should be what exactly is a 6 speed vs an 8 speed? I know the brake drum orientation changed at some point but did the differential change coincide with this? 6-speed has 1-2-3-R, Hi-Lo, brake drum close to rear axle & clockwise rotation (forward), and LSD. 8-speed (apparently from 1970) moved the brake drum and dropped the LSD (and added dipstick?) And I also thought all trannies with high/low had 5/8 input shafts? I think you are correct here. Length, though, I’m not sure. Apologies. Here’s the info from the Unidrive Repair Manual. “III” indicates 6-speed version (5060 and 5071); “II” indicate 3-speed (5053 & 5058) The Raider 10 & 12 did use 6-speed in ’68 & ‘69 No 6-speeds after 1969 Clearly my memory has gotten fuzzy on the input shaft lengths and diameters. Edited May 5 by Handy Don 1 Share this post Link to post Share on other sites
kpinnc 19,105 #56 Posted May 5 22 minutes ago, Handy Don said: Clearly my memory has gotten fuzzy For me, that's everything. Thank you for the clarification. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #57 Posted May 5 9 minutes ago, kpinnc said: For me, that's everything. Thank you for the clarification. Thank YOU for the call out! It just occurred to me that the input shaft accommodating the wider, large block engines could have been as simple as using a pulley with a normal hub with the hub toward the case. That would move the sheave outward by perhaps an inch compared to the snug-to-the-case, setscrew-in-the-sheave pulley on “small block” versions, as on my “upgraded” 854! Share this post Link to post Share on other sites
kpinnc 19,105 #58 Posted May 5 40 minutes ago, Handy Don said: It just occurred to me that the input shaft accommodating the wider, large block engines could have been as simple as using a pulley with a normal hub with the hub toward the case. That would move the sheave outward by perhaps an inch compared to the snug-to-the-case, setscrew-in-the-sheave pulley on “small block” versions, as on my “upgraded” 854! I wish the "newer" 8 speeds didn't have such short input shafts. The transmission pulley on my 310-8 chewed the seal and the place for it completely out. The case was effectively ruined. There wasn't enough material left to cut in another place for a seal. By the time I noticed the leak it was too late. Luckily I had a spare transmission... 2 Share this post Link to post Share on other sites
ri702bill 13,390 #59 Posted May 6 You can add a spacer using one of the slotted holes near the "C" shaped input cutout to move the guard slightly outward at allieviate the pulley rubbing... 1 Share this post Link to post Share on other sites
702854boy 1,245 #60 Posted June 3 I did it a few weeks ago but I got the belt guard put on 2 Share this post Link to post Share on other sites
953 nut 70,648 #61 Posted June 4 Somewhere a vintage truck is missing its clearance lights, I love the look. 1 2 Share this post Link to post Share on other sites
Retired Wrencher 7,042 #62 Posted June 12 On 10/25/2025 at 10:46 AM, ebinmaine said: I like that off-white seat. Gives good contrast to the sea of red. Back in the day I did a lot of that. Know I did not paint any thing. Pain in the A>>> 1 Share this post Link to post Share on other sites
702854boy 1,245 #63 Posted July 24 (edited) Bought a Farmall Cub muffler and installed it today. I do like the nice mellow sound it gives 20260723_213324.mp4 Edited July 24 by 702854boy 1 Share this post Link to post Share on other sites
Handy Don 17,735 #64 Posted July 24 That is a nice mellow sound. Be sure to support that with more than just the threaded nipple in the engine block--something that tall has a LOT of leverage! 3 Share this post Link to post Share on other sites
8ntruck 9,420 #65 Posted July 24 Yup. The Cub mufflers have a nice sound. I'm running one of those on my C-195. Share this post Link to post Share on other sites
adsm08 5,247 #66 Posted July 26 On 5/5/2026 at 2:27 PM, Handy Don said: Clearly my memory has gotten fuzzy on the input shaft lengths and diameters. I'm told this happens with age. The hair begins to grow inward, rather than outward, and so the mind becomes fuzzy, and the top of the head less so. 1 Share this post Link to post Share on other sites
702854boy 1,245 #67 Posted August 2 Spent the last few days making my tractor more Wisconsin. Now I need to get it some cheese curds. I put the wheelweights I bought from @WHX?? at the show on and went through the RM-425 deck I got from @Achto and put it on too. This deck was the nicest deck I've ever gone though so far. None of the bearings were seized and all of the grease looked good but I still cleaned it up and put some fresh Lucas green in it. The nla double-d blades looked like they had either never been sharpened or sharpened very little. 1 6 Share this post Link to post Share on other sites
702854boy 1,245 #71 Posted September 2 What steps do you guys recommend taking for painting a one piece gas tank? I remember seeing something a while back about the aluminum giving fits but trying to search I'm not finding anything Share this post Link to post Share on other sites
Handy Don 17,735 #72 Posted September 2 1 hour ago, 702854boy said: What steps do you guys recommend taking for painting a one piece gas tank? I remember seeing something a while back about the aluminum giving fits but trying to search I'm not finding anything I painted mine with regular Rustoleum auto primer and Regal Red. Carefully taped over the filler hole and exit nipple. Take care when removing old paint to not scratch the soft aluminum (yeah, I won’t do that again). Share this post Link to post Share on other sites
Bar Nuthin 3,642 #73 Posted September 2 I saw a couple last week with just a bare tank. Looked pretty sharp! Not sure what process was used to get into that condition, or what (if anything) was applied to preserve it. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #74 Posted September 2 36 minutes ago, Bar Nuthin said: just a bare tank. Looked pretty sharp! Not sure what process was used to get into that condition, or what (if anything) was applied to preserve it. I seen both “bare” and finished. Bare was carefully polished using aluminum-safe polishing compound followed by an auto ceramic body coating. Finished used aluminum paint due to discolorations in the original metal. Share this post Link to post Share on other sites
rjg854 13,454 #75 Posted September 2 I wonder if a laquer finish would hold up against possible gas drips and spills. 1 Share this post Link to post Share on other sites
