8ntruck
Massey Ferguson SCUT
8ntruck
I've stumbled onto a Massey Ferguson CG1700 series tractor for sale.  It comes with a FEL , small backhoe, and a trailer.  450 hours, 20hp diesel and the possibility of some other implements - most of them I'm not really interested in.  Asking price $13k.  Best of all, I guess, is that it is red.
Sounds tempting and would be very useful in our 20 acre wood.  I dunno, though.....
Edited by 8ntruck
oliver2-44
That has the Iseki engine, which I hear are very good.
While your 8n has weight and torque, the power steering, FEL and backhoe sure are handy developing a new property.
T-Mo
The 1700 series from MF are good little tractors, falling into the sub-compact scope of things.  If I was in the market for a sub-compact, it would be up there with Deere's 1-series and Kubota's offerings.
wh500special
@8ntruck
My dad has the Kubota equivalent of that machine, the BX23 (or something like that) with the 60” deck, FEL, and backhoe.
He uses it all the time. If he’s outside, chances are the tractor is nearby serving as a wheelbarrow, puller-outer of things, or  digger.  He uses it to put heavy things into or out of the truck bed, lifts firewood up on to the deck, and touches up the driveway.
obviously the backhoe isn’t used as often as the tractor and loader, but he uses it a lot more than I ever guessed he would.   He’s dug trenches with it, drug stuff out of the woods, taken out stumps, and planted countless trees and bushes.   It’s been really good for ripping out roots of nearby plants that have encroached into a spot where he wanted to dig.
the backhoe is amazingly powerful for such a diminutive thing.  It has enough power to flip the tractor over if you’re not careful.  So it has capability beyond what it looks like.
If you’re looking for an excuse to buy it you’ll find them within ten minutes of having it home.
steve
Edited by wh500special
8ntruck
12 hours ago, wh500special said:
@8ntruck
steve
I've  already got a list of about half a dozen things it will do nicely before I've started to deal on it.
8ntruck
I made a deal on this tractor today.  A GC 1720 with FEL  and backhoe.  Also included a York type landscaping rake, a chain drag harrow, and a sizeable dual axle trailer (with a title!).  He threw in some scaffolding sections that were on the trailer as well.  Pictures tomorrow.
  • Like 4
  • Excellent 2
T-Mo
Nice, I looking forward to the pictures.  There are so many brands now in the sub-compact market, most are pretty good, though I have been hearing some noise on the TYMs.  But, I would trust the MF name and Iseki, who made these for MF.
My_horse
congrats!
I love my gc2400. Bought it new in 2010. So useful for so many things. In addition to the loader and hoe, I’ve got the front mounted 52” snow blower, 3 pt chipper, box blade, York rake, and clamp on forks for the loader. Never any major issues with it, and it’s never needed to go back to the dealer. Which is good, because the dealer I bought it from closed up and now the closest is over an hour away.
I buy all my parts online from an AGCO dealer in PA. Just coming up on the 300 hr service. Not a lot of hours for owning it so long. But those hours were spent working. Lots of logs moved and brush chipped when all the ash trees died off.
some handy accessories were the side step and the hydro fan/filter guard made by RetailREMS.
WHX??
:text-worthless:
8ntruck
Posted (edited)
:text-yeahthat:  NAG, NAG, NAG!  Just for that, you only get the quick & dirty picture.
The deal officially closes at the end of the month.
I get the MF, the trailer in the foreground, and everything on it except the tiller.
Edited by 8ntruck
  • Haha 1
8ntruck
I closed the deal on this today.  Only had time to work the paperwork and write the check.  Supposed to be raining here for a few days.  Won't be able to try it out for a few days.
JCM
Nice that it has the ROPS too. Good luck with it.
WHX??
Couldn't find a 1720 but this one has to be close.
https://www.tractordata.com/farm-tractors/010/7/1/10710-massey-ferguson-gc1723e.html
One thing I liked about the Massys is the hydro pedal is linked to the throttle. Don't know if this one has it or not.
Be interesting to know what the bucket can lift.
I love the subs ... can get them in tight places.
8ntruck
:text-yeahthat: 580lb at max lift height, 760lb at 1.5m lift, and 920lb opening force at ground level - per the manual, if I'm reading the chart correctly.
8ntruck
Posted (edited)
I moved the tractor out of the neighbor's driveway this afternoon.  I worked on a rather compacted spoils pile that has collected next to the front walk from the front porch cconstruction to make friends with the FEL and build some muscle memory with the directional pedals and brake pedal.
The bucket didn't break into the pile very well.  Next session, I'll loosen things up with the back hoe before doing more bucket work.
I'll also move the mini van out of the driveway to make more room to spread what I am removing out front in the alley behind the garage - did good today, didn't hit my 72 Chevy pickup or the neighbor's fence with the back hoe or snag the mini van with the bucket when turning into and out of the alley.
Got to talk with the previous owner as well - the temp gage said it was running hot, but it didn't act like it was hot.  Didn't feel overheated when I opened the hood when I parked it, either.
Edit: I checked it when it had cooled down - the temp gage still said it was hot.  I suspect a bad gage - which appears to be built into the printed circuit board that runs the rest of the dashboard. :(
Edited by 8ntruck
Handy Don
The sensor is usually a resistor-based item with the resistance varying by temp. I’d look there first and in the wiring. A short might look like HOT as a safer indication than having it look like FINE.
8ntruck
Posted (edited)
:text-yeahthat:  Been looking on line.  I've more likely got a bad wire or a bad sender. There are 3 connections on the PC board that might be loose or dirty, too.
Edited by 8ntruck
WHX??
Just curious is it easy to find service manuals for these tractors?
8ntruck
:text-yeahthat:  I stumbled onto a MF forum through a search on "temp gage doesn't work".
8ntruck
I think i found the problem with the temp gage.  There are supposed to be 3 screws through the PC into the gage.  One is missing.  The whole tractor is metric, soo, more research on the screw size.
Until I get that figured out, I'll check the sending unit and the wire from it to the gage.
8ntruck
I've finally gotten time to move the MF from our Mo. property to our Ky. property for some ditch work.
I had replaced the missing screws on the temp gage.  No longer reads high 'cause it always reads low, now.
I gave the MF an oil change Wednesday and started giving the trailer that came with it a once over.  Didn't plan very well here - first time using a new to me used trailer and it is on a 475 mile tow.
Had to top off the hydraulic fluid - got a couple of leaky hoses.  Not knowing exactly what is in there, I'll schedule a fluid change there in the near future as well.
Anyhow, I spent half of yesterday and most of today looking the trailer over.  The tires are old but look sound, the bearings are well greased, but 2 of them were a bit loose - easy to remedy.  And suprise of suprises, all of the lights work.  The electric brakes do too.  On a test drive a few miles out of town and back, all looked OK.  Unloaded, it tows easily with stability.  When loading the tractor, I ended up with the landscape rake and the chain harrow at the front of the trailer under the FEL bucket.  Two chains across the trailer with a binder on each one.  Less than ideal.  I will be adding two more chains and ratchet binders in the near future - I'll feel much better with that system.  I don't much care for the lever binders.
Best of all, that trailer is big enough to move EJ the 8n around.  And a couple of my projects cars too.
Handy Don
Uh oh.....
8ntruck
Got to out Ky property with just enough daylight left to unload the tractor, drop the trailer, and get checked in at the hotel.
Between the trailer, tractor and a couple implements, I was towing about 5000 pounds.  Turns out that trailer is a really easy tow.  It tracks well and does not fight the truck like the Coleman travel trailer of similar weight does.  The longer 'wheelbase' and smaller frontal area of the utility trailer probably make the difference.  Ended up with 13mpg for the trip.
Ya, I know - no pictures.  I'll take some tomorrow.
