peter lena 9,715 #1 Posted October 22, 2025 https://www.google.com/search?q=shoulder+bolt&oq=shoulder+bolt+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQABiABDIHCAIQABiABDIHCAMQABiABDIHCAQQABiABDIHCAUQABiABDIHCAYQABiABDIKCAcQABiLAxiABDIKCAgQABiLAxiABDIKCAkQABiLAxiABNIBCDYwMDhqMWo3qAIAsAIA&sourceid=chrome&ie=UTF-8 often refer to this type bolt , as a swivel / movement point , terrific on a swing lever , shift point , allowing you to washer up a lubricated hold / swing point , with very little resistance . personally experiment with a regular nut , for actual fit , functional ease , then change that out for an elastic lock nut / washers , lubrication , for holding swing spot . my plow lever squeeze lever set up, is driven by the swing quadrant spring / red aerosol lube detailing , also a similar detailing on my PTO lever set up , both work with solid / smooth functional ease . only a tried tested . set up , make a point of ELIMATING A REPEDITIVE PROBLEM , like doing that , pete 3 Share this post Link to post Share on other sites
