wheelhorsejoe 4 #1 Posted October 21, 2025 Kohler M14 Carb which is better Walpro or Kohler, came with a Walpro ? Thanks Share this post Link to post Share on other sites
953 nut 64,108 #2 Posted October 21, 2025 I have some with the Carter carburetors and some with the Walbro and both are about equal in my estimation. 2 1 Share this post Link to post Share on other sites
ri702bill 11,254 #3 Posted October 21, 2025 I look at this two ways - availabilty of quailty (OE) rebuild parts, and if the low and high circuits are externally adjustable.... Share this post Link to post Share on other sites
Lee1977 7,551 #4 Posted October 22, 2025 If I have a Walbro giving me trouble it is going to get replaced with a Carter or Kohler if I have one. Back in the 60's they had Carter on them, the later ones don't have a name I assume they are Kohler. Share this post Link to post Share on other sites
kpinnc 17,149 #5 Posted October 22, 2025 Walbros don't have the low speed mix adjustment. They seem to work fine but if I have a choice I go with a Carter. Share this post Link to post Share on other sites
Racinbob 12,765 #6 Posted October 22, 2025 Some do have the low speed adjustment. This one was on a M14 and I thought it was giving me trouble but it wasn't. Educate me, I always thought Kohler was the carb to have. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,448 #7 Posted October 23, 2025 I didn’t even know Kohler made their own carburetors? Were these used on newer models like 80`s and up? I usually stick with the older models 60s. I had a few early 70.`s models. My first wheel horse was a 312 A it’s been so long. I don’t remember what it had for a carb. I don’t miss that one. Share this post Link to post Share on other sites
Handy Don 15,933 #8 Posted October 23, 2025 6 hours ago, Retired Wrencher said: I didn’t even know Kohler made their own carburetors? Makes more sense to me that WH just set their desired build specs for engines based on their needs (including price) and what the manufacturers had on offer. 1 Share this post Link to post Share on other sites
Racinbob 12,765 #9 Posted October 23, 2025 7 hours ago, Retired Wrencher said: I didn’t even know Kohler made their own carburetors? Were these used on newer models like 80`s and up? I usually stick with the older models 60s. I had a few early 70.`s models. My first wheel horse was a 312 A it’s been so long. I don’t remember what it had for a carb. I don’t miss that one. The Kohler carbs go way back. All the 60's and 70's I've had have/had them. Share this post Link to post Share on other sites
Retired Wrencher 6,448 #10 Posted October 24, 2025 (edited) 16 hours ago, Racinbob said: The Kohler carbs go way back. All the 60's and 70's I've had have/had them. Is there a logo or some kind of marking that indicates Kohler made this carb? I believe I’ve never seen one or just never noticed it. Edited October 24, 2025 by Retired Wrencher Share this post Link to post Share on other sites
Racinbob 12,765 #11 Posted October 24, 2025 Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum 1 Share this post Link to post Share on other sites
sqrlgtr 2,165 #12 Posted October 24, 2025 On 10/21/2025 at 6:51 PM, 953 nut said: I have some with the Carter carburetors and some with the Walbro and both are about equal in my estimation. same here Share this post Link to post Share on other sites
Retired Wrencher 6,448 #13 Posted October 25, 2025 22 hours ago, Racinbob said: Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum Well, Bob, I guess we learned something every day. I probably had one in my hand and I didn’t even know it. But all good info thanks for the reply. Share this post Link to post Share on other sites
squonk 45,500 #14 Posted October 25, 2025 Never seen a "Kohler carb" all I have run into are Carter's (which probably made them for Kohler) and the Walbro's 1 Share this post Link to post Share on other sites
Racinbob 12,765 #15 Posted October 25, 2025 Carter did make the Kohler carbs with some nickle and dime differences, mainly stamping. Generally they are the same but my guess is that Kohler simply wanted 'their' carb on their engines. 1 Share this post Link to post Share on other sites
squonk 45,500 #16 Posted October 26, 2025 If anyone has a pic of a "Kohler" name stamped on a carb, I'd like to see it. The Carter carbs had a "Kohler " number in the stamping. Most of those carbs listed in that reference are probably Carters 1 1 Share this post Link to post Share on other sites
Racinbob 12,765 #17 Posted October 26, 2025 I don't think that exists Mike. As I said, Carter made the carbs for Kohler. As far as I know only a few minor changes were made. As you said, mostly stampings. Both carbs use the same rebuild kits. 1 Share this post Link to post Share on other sites
