Phan 68 #1 Posted October 21, 2025 Hello, any please tell me: 1) To disengage the Electro Cluch. The engine starts, the cluch is engaged. 2) The lift level assist cannot be hold a deck 42 for WH 12 Auto. Thanks ! Share this post Link to post Share on other sites
pfrederi 20,992 #2 Posted October 22, 2025 There should be a switch on the dash board to turn PTO on and off. Did someone bypass it and wire the PTO directly to the Ignition switch ?? Is your implement lift manual or hydraulic??? Share this post Link to post Share on other sites
Phan 68 #3 Posted October 22, 2025 1 hour ago, pfrederi said: There should be a switch on the dash board to turn PTO on and off. Did someone bypass it and wire the PTO directly to the Ignition switch ?? Is your implement lift manual or hydraulic??? Hello - Thank you! The dash has a switch marking "Electro Clucth". I have to turn it to the left side in order to start, as the engine runs, the clucth turns. However, I have NEVER tuned the swicth to the right side when the engine is running. I don't know if there was bypassed. The person passed away. But there is a gas electric pumb. The lift implement is manual. Share this post Link to post Share on other sites
pfrederi 20,992 #4 Posted October 22, 2025 There was a safety switch set up to prevent you from starting tractor with PTO engaged. Sounds like someone tried to by pass it and messed things up. This shows how it should be wired. For your lift issue make sure the spring 7-33 is on place and the block 7-37 move freely 1 Share this post Link to post Share on other sites
Phan 68 #5 Posted October 22, 2025 Thank you - It will be a project next spring for me ! Pxl 20251022 175959504(1).mp4 Share this post Link to post Share on other sites
pfrederi 20,992 #6 Posted October 22, 2025 You are missing the field coil for your electric PTO...may want to look at converting to a manual PTO 1 Share this post Link to post Share on other sites
Phan 68 #7 Posted October 23, 2025 I do not know parts in the two boxes. I also think to convert to manual too. The tractor runs very strong, I got for 300 CAD - an unual price selling in Canada. Share this post Link to post Share on other sites
Phan 68 #8 Posted October 23, 2025 16 hours ago, pfrederi said: You are missing the field coil for your electric PTO...may want to look at converting to a manual PTO The boxes are bearings - Thank you ! Share this post Link to post Share on other sites
