David414 322 #1 Posted October 20, 2025 Please, I need help in identifying this tiller model number and year. Gear housing casing is stamped 6837 on both right and left side. (picture 2) Thanks! 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #2 Posted October 20, 2025 Click on the photo in this link. That will take you to a list of all of them. Some of the known differences are listed there. I will guess 1975 or newer. 2 Share this post Link to post Share on other sites
oliver2-44 11,628 #3 Posted October 21, 2025 @David414 Those tines look very worn, are you planning to weld them back up or or try to find replacements. I also have a worn set and would lover to see a how a good welder would go about building them up. I have a flat heavy chunk of brass that I've been thinking of using as a backer. (steel weld doesn't stick well to cold brass I'm told) 1 Share this post Link to post Share on other sites
David414 322 #4 Posted October 21, 2025 AZ tractor has replacement shaft with bolt on tines that replaces the original parts. 1 Share this post Link to post Share on other sites
