"Manic-Mechanic" 1,485 #1 Posted October 19, 2025 Diagram number 100, part 2660. Can I get someone to give me the dimensions for this guard? Share this post Link to post Share on other sites
IndyFord2 52 #2 Posted October 23, 2025 I'm going to chime in here, cause I need one also. And / or are there any out there that could be bought ? Share this post Link to post Share on other sites
peter lena 10,013 #3 Posted October 23, 2025 @Manicmacanic pay attention to related idler pulleys , usually tiny bearing with unknown lubricant , enhance / ensure easy spin up , pete Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #4 Posted October 23, 2025 3 hours ago, peter lena said: @Manicmacanic pay attention to related idler pulleys , usually tiny bearing with unknown lubricant , enhance / ensure easy spin up , pete Say Pete, this is for the lower belt guard but did get some super high heat grease awhile ago. What do you recommend? Share this post Link to post Share on other sites
peter lena 10,013 #5 Posted October 24, 2025 @Manicmacanic https://www.walmart.com/ip/Lucas-Xtra-Heavy-Duty-Grease/36052505?wmlspartner=wlpa&selectedSellerId=0&wl13=2200&gclsrc=aw.ds&adid=2222222227736052505_117755028669_12420145346&wl0 , cleaned out and re greased all of my bearings with this , also always look for wide bearing plyable / removable , side shields , making for an easy transition , have it in every related , engine driven hook up , except outer pto cone bearing , available at napa , inner needle gets a wipe out and light greasing, excess would fling onto clutch disc face . mower decks , run quietly , easily , pto lever engagement . is smooth / quiet easy . also do mule drive bearings , 6203 3/4 ) 2rsc3 , when you eliminate any rotational drag point , the operational running ease , is totally different from the usual screaming drag , that goes with belt drives , pete 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #6 Posted October 24, 2025 (edited) 57 minutes ago, peter lena said: @Manicmacanic https://www.walmart.com/ip/Lucas-Xtra-Heavy-Duty-Grease/36052505?wmlspartner=wlpa&selectedSellerId=0&wl13=2200&gclsrc=aw.ds&adid=2222222227736052505_117755028669_12420145346&wl0 , cleaned out and re greased all of my bearings with this , also always look for wide bearing plyable / removable , side shields , making for an easy transition , have it in every related , engine driven hook up , except outer pto cone bearing , available at napa , inner needle gets a wipe out and light greasing, excess would fling onto clutch disc face . mower decks , run quietly , easily , pto lever engagement . is smooth / quiet easy . also do mule drive bearings , 6203 3/4 ) 2rsc3 , when you eliminate any rotational drag point , the operational running ease , is totally different from the usual screaming drag , that goes with belt drives , pete I have the replacement bearing for the wobble box, it’s open on the bottom side for splash lube. It’ll be imperative to have high quality oil in that box! I am almost out of grease so it’s time for another can, I will get this product per your recommendation Lucas is a great product, I use their fuel additive as well. Edited October 24, 2025 by "Manic-Mechanic" Added content Share this post Link to post Share on other sites
