Joefrommi65 26 #1 Posted October 15, 2025 Good Day all, I have been trying to get this 416 running but no luck ( electrical gremlin) I see on my dash that the pto clutch and seat switches seem to be working as they go off when I activate them I have checked the fuses if I cross the starter over it spins but does not ingage to the flywheel I am by no means I electrical guru and have an electrical diagram I think is correct but the question is what else do I look for from here ? Thanks for your time and patience Joe Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #2 Posted October 15, 2025 I would start and see if you have voltage at the solenoid and back trace from there. Just test one wire at a time for the voltage to be routing correctly. There are good wiring diagrams on the forum here. You would need your exact model number, which should be on a metal plate under the seat or fender area, to ensure you have the right diagram. 1 Share this post Link to post Share on other sites
pfrederi 21,151 #3 Posted October 15, 2025 Starter motor spinning but not engaging the flywheel,,, could be bad starter. stuck bendix or a weak battery (or high resistance cables) 3 1 Share this post Link to post Share on other sites
Joefrommi65 26 #4 Posted October 15, 2025 Thanks folks going to try those things now Share this post Link to post Share on other sites
pfrederi 21,151 #5 Posted October 15, 2025 Is this a Kohler Magnum or an OnaN? Share this post Link to post Share on other sites
Joefrommi65 26 #6 Posted October 15, 2025 Onan sorry forgot that8 Share this post Link to post Share on other sites
pfrederi 21,151 #7 Posted October 15, 2025 I will step aside as I know nothing about Onans don't have any and not looking to add one. 1 Share this post Link to post Share on other sites
953 nut 69,341 #8 Posted October 15, 2025 18 minutes ago, pfrederi said: weak battery (or high resistance cables) These are my first thoughts. You are getting some power to the starter but not enough to get the job done. Clean, inspect and tighten all connections including grounds. If this 416 is Onan powered check the 9 pin connector for any signs of corrosion or overheating. 1 Share this post Link to post Share on other sites
Joefrommi65 26 #9 Posted October 15, 2025 Thanks folks going to try those things now 1 Share this post Link to post Share on other sites
ri702bill 13,068 #10 Posted October 15, 2025 1 hour ago, 953 nut said: check the 9 pin connector for any signs of corrosion or overheating. Share this post Link to post Share on other sites
kpinnc 18,967 #11 Posted October 16, 2025 Onan engines have the solenoid built onto the starter itself. Those solenoids get "sticky" for a while before finally failing altogether. They magnetically push the bendix out to the flywheel, and when they stick the bendix will not engage. But- the starter will usually spin regardless unless it's bad. Definitely agree with the previous posts on the thread. If all that checks out the solenoid and starter would be my next suspect. But the 9 pin connector is definitely the source of most electrical gremlins on that tractor. Second to that with mine were always the start keyswitch itself. 1 Share this post Link to post Share on other sites
Lee1977 7,772 #12 Posted October 16, 2025 Those open fuse holder can be the problem. Had a good battery and fuse and and nothing coming out the other side of the holder. 1 Share this post Link to post Share on other sites
Joefrommi65 26 #13 Posted October 16, 2025 Thanks lee Funny enough I was just looking at that I think I will order a small one for a boat from Amazon .It looks like the previous owner had the same issue and put in line fuses and only left 1 fuse in it Share this post Link to post Share on other sites
Joefrommi65 26 #14 Posted October 17, 2025 Think I figured it out.....bad relay dumped a little fuel it fired but I stopped there and pulled the fuel tank to clean it I due have an online fuse that the wire pulled out of somewhere I have to track down think it is black whit a red strip Any way I thank you all for your help and suggestions 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #15 Posted October 18, 2025 Don't know when it happened or for how long but Wheel Horse did use black wires with a colored stripe. A black wire with a red strip was considered a red wire. Do you have the model number of the tractor so we can look at a correct wiring diagram? 1 Share this post Link to post Share on other sites
Joefrommi65 26 #16 Posted October 18, 2025 Thanks for the help it's model number 31-160802 I believe. I have 2 different wireing diagrams cant quite make either out as far as the colors of the wires Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #17 Posted October 18, 2025 If you download the 6-page file each circuit has it's own diagram. 1 Share this post Link to post Share on other sites
Joefrommi65 26 #18 Posted October 18, 2025 Thanks alot I don't think the engine side plug has black with red stripe but will check tommarow Share this post Link to post Share on other sites
Joefrommi65 26 #19 Posted October 19, 2025 Well the engine side harness did not have a black with red stripe it was solid red so the opposite plug for the tractor side was missing the wire it would've connected too so I guess I will add an inline fuse to that wire. The red wire went to the voltage regulator is there a way to test if it's working when I get it running ?and again thanks very much!!!!! Share this post Link to post Share on other sites
lynnmor 9,040 #20 Posted October 19, 2025 23 minutes ago, Joefrommi65 said: Well the engine side harness did not have a black with red stripe it was solid red so the opposite plug for the tractor side was missing the wire it would've connected too so I guess I will add an inline fuse to that wire. The red wire went to the voltage regulator is there a way to test if it's working when I get it running ?and again thanks very much!!!!! You really need the Onan Service Manual. 1 Share this post Link to post Share on other sites
Joefrommi65 26 #21 Posted October 19, 2025 (edited) Looking through it now but what is confusing me is I believe this engine or wireing harnesses has been replaced. Edited October 19, 2025 by Joefrommi65 Share this post Link to post Share on other sites
lynnmor 9,040 #22 Posted October 19, 2025 You can download the Demystification Guide to see a simplified diagram of each circuit. 1 Share this post Link to post Share on other sites
Joefrommi65 26 #24 Posted October 20, 2025 Well folks thanks for everyones help got the old girl fired up this morning lots of work left to do but I believe the hard part is done 20251020_093850.mp4 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #25 Posted October 20, 2025 On 10/19/2025 at 9:01 AM, Joefrommi65 said: Is there a way to test if it's working when I get it running ? and again thanks very much!!!!! Check voltage across the battery terminals at the battery. Record voltage. Start engine and voltage should increase if the system is in order. 1 Share this post Link to post Share on other sites
