Joefrommi65 19 #1 Posted yesterday at 02:33 PM Good Day all, I have been trying to get this 416 running but no luck ( electrical gremlin) I see on my dash that the pto clutch and seat switches seem to be working as they go off when I activate them I have checked the fuses if I cross the starter over it spins but does not ingage to the flywheel I am by no means I electrical guru and have an electrical diagram I think is correct but the question is what else do I look for from here ? Thanks for your time and patience Joe Share this post Link to post Share on other sites
OutdoorEnvy 1,785 #2 Posted yesterday at 02:37 PM I would start and see if you have voltage at the solenoid and back trace from there. Just test one wire at a time for the voltage to be routing correctly. There are good wiring diagrams on the forum here. You would need your exact model number, which should be on a metal plate under the seat or fender area, to ensure you have the right diagram. 1 Share this post Link to post Share on other sites
pfrederi 18,866 #3 Posted yesterday at 02:42 PM Starter motor spinning but not engaging the flywheel,,, could be bad starter. stuck bendix or a weak battery (or high resistance cables) 3 1 Share this post Link to post Share on other sites
Joefrommi65 19 #4 Posted 23 hours ago Thanks folks going to try those things now Share this post Link to post Share on other sites
pfrederi 18,866 #5 Posted 23 hours ago Is this a Kohler Magnum or an OnaN? Share this post Link to post Share on other sites
Joefrommi65 19 #6 Posted 23 hours ago Onan sorry forgot that8 Share this post Link to post Share on other sites
pfrederi 18,866 #7 Posted 23 hours ago I will step aside as I know nothing about Onans don't have any and not looking to add one. 1 Share this post Link to post Share on other sites
953 nut 61,625 #8 Posted 23 hours ago 18 minutes ago, pfrederi said: weak battery (or high resistance cables) These are my first thoughts. You are getting some power to the starter but not enough to get the job done. Clean, inspect and tighten all connections including grounds. If this 416 is Onan powered check the 9 pin connector for any signs of corrosion or overheating. 1 Share this post Link to post Share on other sites
Joefrommi65 19 #9 Posted 22 hours ago Thanks folks going to try those things now 1 Share this post Link to post Share on other sites
ri702bill 9,881 #10 Posted 22 hours ago 1 hour ago, 953 nut said: check the 9 pin connector for any signs of corrosion or overheating. Share this post Link to post Share on other sites
kpinnc 15,303 #11 Posted 9 hours ago Onan engines have the solenoid built onto the starter itself. Those solenoids get "sticky" for a while before finally failing altogether. They magnetically push the bendix out to the flywheel, and when they stick the bendix will not engage. But- the starter will usually spin regardless unless it's bad. Definitely agree with the previous posts on the thread. If all that checks out the solenoid and starter would be my next suspect. But the 9 pin connector is definitely the source of most electrical gremlins on that tractor. Second to that with mine were always the start keyswitch itself. 1 Share this post Link to post Share on other sites
