clueless 3,365 #1 Posted October 11, 2025 Is the frame on the 704,603,702 the same size? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #2 Posted October 11, 2025 Do not know. Model 702 used part #4401 frame Model 603 used part #2878 frame Model 704 used part #4945 frame An extra hole would generate a new part number Share this post Link to post Share on other sites
clueless 3,365 #3 Posted October 11, 2025 2 hours ago, gwest_ca said: Do not know. Model 702 used part #4401 frame Model 603 used part #2878 frame Model 704 used part #4945 frame An extra hole would generate a new part number So yes? Share this post Link to post Share on other sites
702854boy 606 #4 Posted October 11, 2025 2 hours ago, clueless said: Is the frame on the 704,603,702 the same size? I believe all of the short frame tractors until maybe 65 used all the same frame with different towers and different battery boxes and I'm sure someone more knowledgeable than me could verify that the 65 and beyond short frames were the same. I know all of the short frames could use the same attachments though so they might all be the same. Share this post Link to post Share on other sites
squonk 45,895 #5 Posted October 11, 2025 Chris, what are you trying to do exactly? Share this post Link to post Share on other sites
ri702bill 11,617 #6 Posted October 11, 2025 Here's what I can tell you - The frame on the 1961 701 and the 1962 502, 552, and 702 are the same. Same non-cambered front axle with the flat bar tiebar and drag link, same welded-in battery tray. The 1963 models and up have a different cambered axle, and two ball joint tierods - the mount portion is different from the 1962 models. First one with the bolt-n battery tray. The 1963 and 1964 look identical, but most likely not (different P/N's) 1 Share this post Link to post Share on other sites
clueless 3,365 #7 Posted October 11, 2025 2 hours ago, squonk said: Chris, what are you trying to do exactly? I have a Kohler Magnum 8 never had oil in it, it has all the K161 dimensions and the right PTO shaft size. I'm thinking I might put it on the 702 or the 704 (li'l Red). I know I'll have to work out the electrical but just spit balling here on which one, the 704 is in far better shape. 1 Share this post Link to post Share on other sites
squonk 45,895 #8 Posted October 11, 2025 (edited) 4 minutes ago, clueless said: I have a Kohler Magnum 8 never had oil in it, it has all the K161 dimensions and the right PTO shaft size. I'm thinking I might put it on the 702 or the 704 (li'l Red). I know I'll have to work out the electrical but just spit balling here on which one, the 704 is in far better shape. The engine mounting holes are the same for all the short frame tractors. The Magnum height and length may be an issue with the hood Edited October 11, 2025 by squonk 2 Share this post Link to post Share on other sites
953 nut 64,853 #9 Posted October 11, 2025 37 minutes ago, clueless said: I know I'll have to work out the electrical By now I thought you had become an electrical guru but if questions come up we are here for you. 37 minutes ago, squonk said: The engine mounting holes are the same for all the short frame tractors. The Magnum height and length may be an issue with the hood This thread could be helpful. 1 1 Share this post Link to post Share on other sites
Pullstart 69,457 #10 Posted October 12, 2025 The front axle pivot did change with the axle upgrade. This link shows the difference in the frames and steering. https://www.wheelhorseforum.com/topic/73794-502-worker-refresh/?tab=comments#comment-713402 1 Share this post Link to post Share on other sites
