homefried1@yahoo.com 2 #1 Posted October 3, 2025 I finally got the pipe loose on both ends. Talking about the pipe that runs from down in the hole between the legs when sitting on the machine, to the oil filter. Now I cant get it out! Share this post Link to post Share on other sites
homefried1@yahoo.com 2 #4 Posted October 3, 2025 I cant see how in the world that pipe is supposed to come out! If not for the connector, I believe it would just come right out but even if I were to cut it off, how would I get the new one back on? Does anyone have any advice? Share this post Link to post Share on other sites
Ed Kennell 44,060 #5 Posted October 3, 2025 Do you have the seat and seat pan off? 1 1 Share this post Link to post Share on other sites
Handy Don 15,578 #6 Posted October 3, 2025 Firstly, wondering why you need that pipe out. Secondly, VERY concerned that you are opening up the oil path connected to the hydro when the surrounding area is so dirty. That pipe carries FILTERED oil directly into the charge pump which also supplies makeup oil to the hydro pump/motor. 4 Share this post Link to post Share on other sites
953 nut 63,527 #7 Posted October 3, 2025 Is this the the same GT-1800 you had another thread on, right? Seems to me you were told that the seat and fender needed to come off. Share this post Link to post Share on other sites
homefried1@yahoo.com 2 #8 Posted October 4, 2025 13 hours ago, Ed Kennell said: Do you have the seat and seat pan off? Yes. Share this post Link to post Share on other sites
homefried1@yahoo.com 2 #9 Posted October 4, 2025 13 hours ago, Ed Kennell said: Do you have the seat and seat pan off? Yes. The stopping spot is shown in the 2nd picture where the pipe goes thru the frame and just above the brake band. I have removed the brake band also. I wonder if I'm gonna need to separate the rear end from the tractor. Share this post Link to post Share on other sites
c-series don 10,926 #10 Posted October 4, 2025 Like @Handy Don said I’m VERY CONCERNED that you are taking that apart without cleaning that area first. Any work you do will be negated if dirt gets in the hydraulic system. As a fellow owner of two Work Horse GT-1800’s I’m happy that you are trying to keep yours going. Please post pictures, we love pictures! 1 1 Share this post Link to post Share on other sites
oldlineman 1,626 #11 Posted October 4, 2025 Yes the whole area should have been cleaned very well before attempting to remove the line. Clean area also helps with seeing the work area better. Share this post Link to post Share on other sites
homefried1@yahoo.com 2 #12 Posted October 5, 2025 On 10/3/2025 at 5:28 PM, Handy Don said: Firstly, wondering why you need that pipe out. Secondly, VERY concerned that you are opening up the oil path connected to the hydro when the surrounding area is so dirty. That pipe carries FILTERED oil directly into the charge pump which also supplies makeup oil to the hydro pump/motor. That pipe leaks hydraulic oil. It needs replacing. Share this post Link to post Share on other sites
