702854boy 606 #1 Posted October 3, 2025 What size belt do I need for the spindle belt on previously said mower deck? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #2 Posted October 3, 2025 For an RL-426 side discharge deck Drive belt 9782 (1/2" x 69") Spindle belt 6738 (1/2" x 86") Share this post Link to post Share on other sites
953 nut 64,847 #4 Posted October 3, 2025 Save this download for future refence. . Share this post Link to post Share on other sites
peter lena 9,812 #5 Posted October 3, 2025 @702854boy always ask , how easily does related , PULLEY / BELT SET UP , MOVE BY HAND ? having done all my decks for pulley related , lubrication failure / rough movement , pto lever engagement , will tell you the statis , of movement , never replaced a clutch disc due to burn out wear , I regularly hear neighbors , scream in the deck drive , every related movement spot , should be free and easy , just my own experience , also like tractor supply aramid belts , pete Share this post Link to post Share on other sites
702854boy 606 #6 Posted October 3, 2025 2 minutes ago, peter lena said: @702854boy always ask , how easily does related , PULLEY / BELT SET UP , MOVE BY HAND ? having done all my decks for pulley related , lubrication failure / rough movement , pto lever engagement , will tell you the statis , of movement , never replaced a clutch disc due to burn out wear , I regularly hear neighbors , scream in the deck drive , every related movement spot , should be free and easy , just my own experience , also like tractor supply aramid belts , pete It all moves pretty easily and last night I was doing what I've seen you suggest and going through all of the sealed bearings and cleaning them up and replacing with the green Lucas. 1 Share this post Link to post Share on other sites
peter lena 9,812 #7 Posted October 3, 2025 @702854boy know I sound like a broken record , when I first experienced , W/H rotational movement failures , it was quickly obvious to me , it was lube failure , drag / heat / loading quickly exceeds original lube , also bearing size / type . many were ceiling FAN bearings , just the OPOSET LOADING , of a mower deck . those tiny IDLER PULLEY BEARINGS , are another consistent failure , due to belt bounce , from incremental bearing hang up . added a flat belt idler , to back side of belt bounce point , instantly gets that belt under control , sent in related info to site , on deck belt bounce . good for you , pete Share this post Link to post Share on other sites
Brockport Bill 2,259 #8 Posted October 3, 2025 59 minutes ago, peter lena said: @702854boy know I sound like a broken record , when I first experienced , W/H rotational movement failures , it was quickly obvious to me , it was lube failure , drag / heat / loading quickly exceeds original lube , also bearing size / type . many were ceiling FAN bearings , just the OPOSET LOADING , of a mower deck . those tiny IDLER PULLEY BEARINGS , are another consistent failure , due to belt bounce , from incremental bearing hang up . added a flat belt idler , to back side of belt bounce point , instantly gets that belt under control , sent in related info to site , on deck belt bounce . good for you , pete always enjoy Pete's perspective and insights even if i have read them previously ! Repetition is the best teacher! 1 1 Share this post Link to post Share on other sites
