The Rooster 2 #1 Posted October 2, 2025 Shy of 3 acres, I've used a White lawn tractor to cut the grass and pull a small trailer. I've forked out enough renting subcompact tractors in the past for landscaping and some construction works but never had an interest in owning something "that big." Recently thought of getting an old Craftsman or Husqvarna with a front scoop like the Johnny Products stuff or building a FEL but someone had me look at WH products and I've spent HOURS now looking into 400 & 500 series stuff - very impressive! Up here in Canada there's someone passionate about WH tractors selling a 1995 520H with 800 hours including wheel weights and a Kwik-way FEL (incl. New hydraulic hoses and repacked cylinders). Asking $CDN 7000 (~USD 5000). I figure this is as big a tractor I need or want to get so appealing to the wise folk here on 1. What to look for in buying this kit so I'm not pulling my hair out in a few months? Or what questions should I be asking? 2. Does this seem a reasonable asking price? From what I've seen so far, yeah the WH community seems very upbeat, helpful and positive! 2 Share this post Link to post Share on other sites
Ed Kennell 45,796 #2 Posted October 2, 2025 to the The 520 experts will be here soon to report the good and the bad. Share this post Link to post Share on other sites
Achto 31,617 #3 Posted October 2, 2025 Price is not too bad with a loader included. Find an immoveable object to run the loader against. Try pushing it and make sure it will spin the tires. This ensures the hydro is good. 2 Share this post Link to post Share on other sites
Handy Don 16,286 #4 Posted October 2, 2025 (edited) Welcome to the forum. We’re glad you found us. The ’95 520-H was at or near the end of production for that model. 20hp with plenty of torque (though it can be thirsty). The Eaton hydro and Unidrive transaxle are rock solid. The “swept” front axle angles forward and wider than pre-92 (?) models. Has 1” spindles and heavier wheel bearings. It’s designed to allow room for a 60” mower deck and for better stability with an FEL. Gear reduction steering (twice as many turns lock-to-lock for easier steering with loads) The hydrostatic forward/revers motion control is column-mounted. To me, though, USD 5,000, even for a well-maintained, 800 hour unit with Kwik-way in excellent condition is a bit ambitious. You didn’t mention a mower deck or other implements. In my New York Metro area the ask would be more like $4,000. Adding an excellent condition 60” deck would be another 500-700. Things I would check: - records, especially of oil & filter changes on the engine and transmission - any sign of “surging” in the engine (i.e. revving up and down on its own) - make sure that once warmed up it runs without any choke at all - a foam rubber gasket installed around the engine oil filter (absolutely critical for proper flow of cooling air) - oil levels and condition in the engine and the transaxle - echoing @Achto suggestion--with the bucket low against something immovable, and the front wheels just barely off the ground, can the tractor spin the rear wheels? Edited October 3, 2025 by Handy Don 5 Share this post Link to post Share on other sites
953 nut 65,335 #5 Posted October 3, 2025 If the 520 and Kwik-Way are in great condition as stated then you will not have overpaid in the long run. They will both last a long time with proper maintenance and before long you will wonder how you got by for so long without it. 2 Share this post Link to post Share on other sites
Ed Kennell 45,796 #7 Posted October 3, 2025 (edited) 520H Value - Page 2 - Wheel Horse Tractors - RedSquare Wheel Horse Forum Some good current info here. I have never experienced any problems with the Eaton 1100 hydro, although some of them require a long (10 minute) warm up time in cold temperatures. I found the surging of the Onans was cured with a good cleaning of the carbs. Edited October 3, 2025 by Ed Kennell 1 Share this post Link to post Share on other sites
mrc 1,071 #9 Posted October 4, 2025 i've had 2 wheelhorse tractors with loaders. so i have some experience. you will need: rear wheel weights (as heavy as can be) rear tire chains some sort of rear counterweight. foot pedal drive (not absolutely necessary but, well worth the extra coin) the wheel horses with loaders are ok for snow, mulch and light dirt/stone work. if i were going down that road again i would look for an older 4WD diesel powered kubota with loader and 3 pt on the back. regards mike Share this post Link to post Share on other sites
sergeant 350 #10 Posted October 4, 2025 32 minutes ago, mrc said: i've had 2 wheelhorse tractors with loaders. so i have some experience. you will need: rear wheel weights (as heavy as can be) rear tire chains some sort of rear counterweight. foot pedal drive (not absolutely necessary but, well worth the extra coin) the wheel horses with loaders are ok for snow, mulch and light dirt/stone work. if i were going down that road again i would look for an older 4WD diesel powered kubota with loader and 3 pt on the back. regards mike While 4WD or AWD is nice, it's not really necessary for loader work. It's the lack of power steering that always kept me away from buying a WH 300, 400, or 500 series Wheel Horse, and go figure, my 1st garden tractor with a loader lacked power steering, which was a 1999 White GT2055, which I bought new. A year later, I bought a used JD 425 with a 40 loader, which I had for 3 years, and I traded the JD 425 in on a JD 2WD X485 with a 45 loader, and it had power steering and a liquid-cooled Kawasaki engine with EFI. I used it for 11 years on a 5.5-acre spread. I could have bought a 4WD JD X575, X585, or a diesel X595; they had manual shift 4WD. But I didn't like their turning radius in 2WD. Well, in 2014 I bought a used 2012 JD X748 diesel with hydraulic front-wheel drive. I traded my X485 for attachments for my X748 and kept the 45 Loader. With a shimmed transmission, the X748 with a 45 Loader will pick up more weight than most subcompact tractors with a non-self-leveling loader. I have a JD compact with a loader as well. But I use that X748 for most loader work, as it can get in places most subcompact tractors will not fit. I still have the White GT2055 with a Kwik-way loader, but it's on sort of permanent loan to my older brother, who uses it for mulch and snow work. So he's not carrying heavy loads where it gets tiresome to use with the lack of power steering. I Bought the X748 for it weight not the AWD though it is a nice Bonus. The Deere AWD or Hydraulic front wheel drive tractors give you a tight 25-inch turn radius which is the same as the 2WD tractors I considered a 5Xi in 1999, but the lack of a 3-point hitch is what made me go for the lower-cost White GT2055 because it came standard with a Cat 0 3-point hitch. At that time, Master sergeants (E-8) didn't make the money they do today. For the size of the tractor, Toro should have had a 3-point hitch and diff/lock. My purchase of the used JD 425 gave me a 3-point hitch, rear PTO, diff/lock, and a loader powered by the tractor's onboard hydraulic system. That is, place Deere always seemed to beat the competition with their hydraulic systems. The Case and later Ingersoll hydraulic systems could actually run the Kwik-Way Loader. Kwik-Way only made loaders for the Case 400 and Ingersoll 4000 series. . The Case 200 or Ingersoll 3000 series could have run it as well. But Kwik-way didn't make a subframe for those tractors. I also have an Ingersoll 3016PS. Which we purchased new in 1992 because the dealer claimed the Kwik-Way Loader would work on it. I bought that because John Deere had dropped the 318. When I could finally afford one on an E-7's salary. But that's another story. But don't sell 2WD short for loader work. That 2WD X485 dug a loader-wide, 3-foot-deep by 100-foot-long trench for a drainage system I built for a driveway on my last property. For the Wheel Horse 300 through 500 series I think the Johnny Bucket Jr's are better suited for moving material . I just need to Buy a Johnny Bucket sub frame for my Wheel Horse 416H. I have a JB Jr for My Cub Cadet XT3GSX. I do agree foot Pedals make loader work a Lot easier though. With the white GT2055 you needed 3 hands to operate the Loader while Maneuvering as it also has Hand speed controls on the same side as the loader levers 2 1 1 Share this post Link to post Share on other sites
rjg854 12,964 #11 Posted October 4, 2025 11 hours ago, sergeant said: Do you have a thing for JD 1 1 Share this post Link to post Share on other sites
sergeant 350 #12 Posted October 5, 2025 10 hours ago, rjg854 said: Do you have a thing for JD I actually have a thing for all garden tractors, regardless of manufacturer. My Current collection Cub Cadet Original Garden Tractor Cub Cadet 60 Rear engine rider Cub Cadet 70 Garden Tractor Cub Cadet 106 Garden Tractor Cub Cadet 1450 Garden Tractor Cub Cadet 2182 Garden Tractor Cub Cadet 3208 Garden Tractor Cub Cadet XT3 GSX Garden Tractor Cub Cadet Z-Force SX54 Zero turn Ingersoll 3016PS Garden Tractor John Deere 110RF Garden Tractor John Deere 112SF Garden Tractor John Deere 140H3 Garden Tractor John Deere GX335 Garden Tractor John Deere X748 Garden Tractor John Deere Sabre 1542 HS Lawn Tractor Simplicity Wonder-Boy Rear Engine Rider Wheel Horse 416H Garden Tractor White GT2055 Garden Tractor John Deere 2025R TLB Compact Tractor The Deere-painted label on the walls matched my former 1025R hood label. The barn addition is white on the inside but has 5 doors, each painted a different tractor color. Deere Green and Yellow, Wheel Horse Red, Cub Cadet Yellow, Allis Orange (non-working doorway), and Ford Blue (non-working doorway) 3 1 Share this post Link to post Share on other sites
The Rooster 2 #13 Posted October 10, 2025 Thanks for the suggestions and general insights! I have yet to see the tractor in person but I've got a little FOMO about this 520H with Kwik-way FEL. I appreciate it's a rare combo so the asking price is a bit steep. @Handy Don, the asking price is really just for the 520H, wheel weights, rear box weight, and Kwik-way FEL, there are no other implements in the $CAD 7000 / USD5000 asking price Could I appeal to the collective wisdom here for some suggestions? I'm looking for a garden tractor with a front end loader and a good mower. It's a cherry on top to have a snowblower, front blade, grading blade and a plough or harrow which. I'm not married to red tractors (although I'm very impressed with the equipment, especially that you can put 70s implements on a 2000s tractor and the little kid inside me likes a little red tractor more than any other colour). Seems garden tractors with FEL are hard to come by around here, or I'm just not looking in the right places. I appreciated @sergeant's insight about JD 2WD X485 with a 45 loader. Am I missing obvious, reliable and easy to come-by combinations of tractors and FELs? Share this post Link to post Share on other sites
c-series don 11,851 #14 Posted October 11, 2025 (edited) I will say this: If you’re looking for a tractor that you can use as a loader and mow grass with a Wheel Horse is not your best bet. Unless you by two!! Once the loader is mounted on the tractor it’s pretty much committed to the tractor. Taking it off to mount the deck will be a very time consuming process and not just something you just easily switch back and forth. If that’s what you’re looking to do I’d look at a newer small JD or Kabota. Something with 4wd and power steering. Some of those tractors allow you to have both the loader and the deck mounted at the same time. Edited October 11, 2025 by c-series don 3 1 Share this post Link to post Share on other sites
Handy Don 16,286 #15 Posted October 11, 2025 (edited) 13 hours ago, c-series don said: a tractor that you can use as a loader and mow grass with a Wheel Horse is not your best bet. Unless you by two! Well said. On the Hudson Valley CL, search for "2012 John Deer 2305 MFWD Compact Tractor w Loader & Mower Deck” to see an example of big enough to do both interchangeably without a lot of fuss. And the cost--quite a bit more than two (or even five?!) nice WHs. Edited October 11, 2025 by Handy Don Share this post Link to post Share on other sites
sergeant 350 #16 Posted October 11, 2025 (edited) 4 hours ago, Handy Don said: Well said. On the Hudson Valley CL, search for "2012 John Deer 2305 MFWD Compact Tractor w Loader & Mower Deck” to see an example of big enough to do both interchangeably without a lot of fuss. And the cost--quite a bit more than two (or even five?!) nice WHs. Again, no need for a subcompact. The following Deere garden tractor models allow the loader and mowing deck to be on at the same time if needed. even the Older 1980's Deere 300 & 400 series even with the seperate Pump Loaders allowed the Mowing deck to be Mounted at the same time as the 44 Loader if Needed 425 OEM 40 Loader or aftermarket CTC Loader 445 OEM 40 Loader or aftermarket CTC Loader 455 OEM 40 Loader or aftermarket CTC Loader X475 OEM 45 Loader or Aftermarket MFP Loader X485 OEM 45 Loader or Aftermarket MFP Loader X495 OEM 45 Loader or Aftermarket MFP Loader X575 OEM 45 Loader or Aftermarket MFP Loader X585 OEM 45 Loader or Aftermarket MFP Loader X595 OEM 45 Loader or Aftermarket MFP Loader X700 OEM 45 Loader or Aftermarket MFP Loader X720 OEM 45 Loader or Aftermarket MFP Loader X724 OEM 45 Loader or Aftermarket MFP Loader X728 OEM 45 Loader or Aftermarket MFP Loader X729 OEM 45 Loader or Aftermarket MFP Loader X740 OEM 45 Loader or Aftermarket MFP Loader X744 OEM 45 Loader or Aftermarket MFP Loader X748 OEM 45 Loader or Aftermarket MFP Loader X749 OEM 45 Loader or Aftermarket MFP Loader X710 OEM 45 Loader or Aftermarket CTC Loader X730 OEM 45 Loader or Aftermarket CTC Loader X734 OEM 45 Loader or Aftermarket CTC Loader X738 OEM 45 Loader or Aftermarket CTC Loader X739 OEM 45 Loader or Aftermarket CTC Loader X750 OEM 45 Loader or Aftermarket CTC Loader X754 OEM 45 Loader or Aftermarket CTC Loader X758 OEM 45 Loader or Aftermarket CTC Loader Now the CTC Loader https://compacttractorandcomponents.com/products/front-end-loaders/ is available for all tractors listed, but it is a US manufacturer out of Wisconsin, and with the border issue right now, it might cost extra to have it shipped to Canada. The MFP Loader https://www.mennonitefarmingproducts.ca/product-page/full-size-loader is made in Ontario, about an hour southeast of London, Ontario. Right now, he only makes them for the tractors I listed. The 45 Loader will fit on the current X700 Signature Series, but you'll need an aftermarket sub frame made by this company: https://landmconcepts.com/. But he also makes a sub frame kit to allow you to put a 120R loader for a Deere subcompact on any of the X700 signature series as well. He would also be making a 120R Loader sub frame kit for the X475 through X749. Now if You decide to go the Sub Compact route I do not recommend a used John Deere 2210 or 2305 do to known drive shaft issues a Used Deere 1026R, 1025R or a 1023E would Be OK the Known issues were fixed by the time the 1026R came out BTW this is my old X485 with a 45 loader and mowing deck mounted at my previous house. I could even put a PTO-driven tiller on that X485 at the same time as the loader and mowing deck. I do recommend dropping the loader if you are going to mow; it only takes 3 minutes to detach, and it walks on and off. Just have to hit a mechanical release lever, then push forward on the hydraulic lever to park the loader and disconnect 4 hoses. To connect the loader drive to the parked loader, connect hoses and walk the loader onto the sub frame with hydraulic power. Once the front parking stand latches, shift the mechanical lever to the locked position. Edited October 11, 2025 by sergeant Share this post Link to post Share on other sites
Handy Don 16,286 #17 Posted October 12, 2025 (edited) Strangely, I’m not an expert on JD models. Edited October 12, 2025 by Handy Don Share this post Link to post Share on other sites
