kpinnc 18,851 #1 Posted October 2, 2025 No rush, but I've been looking for a while for one for my 701. The original looked decent on the outside and was like someone was trying to grow crystals on the inside. It's corroded beyond what I want to deal with. Anybody know a good source for them? Jungle site has them for around $60 but I have no idea if that is good or not, or if the quality is any good. Share this post Link to post Share on other sites
ebinmaine 80,075 #2 Posted October 2, 2025 Like most Wheelhorse parts I'd be more prone to asking one of our main vendors for a used VR than chancing a new one. @76c12091520h Brian Badman Or call Lincoln at A to Z Tractor in PA. Share this post Link to post Share on other sites
ri702bill 12,693 #3 Posted October 2, 2025 Agreed. And if you were able to find a good used period-correct one, it is easily adjustable, unlike the newer knockoff reproductions. 2 Share this post Link to post Share on other sites
953 nut 68,139 #4 Posted October 2, 2025 (edited) A three terminal voltage regulator like the ones used on GM cars and trucks from 1955 to about 1972 can be used. They do not have the "L" terminal but will do the job and will probably be more affordable. Edited October 2, 2025 by 953 nut fat finger 5 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,647 #5 Posted October 2, 2025 These are pricey, but made in USA, and I've never had an issue with one that I've bought. https://www.amazon.com/Standard-Motor-Products-VR219-Regulator/dp/B000O3HYLG 3 Share this post Link to post Share on other sites
Handy Don 17,188 #6 Posted October 2, 2025 2 hours ago, ri702bill said: Agreed. And if you were able to find a good used period-correct one, it is easily adjustable, unlike the newer knockoff reproductions. Heartily agree. I was unable to tweak an “aftermarket”, non-adjustable unit to hit the correct voltages on my K181. It is now in my “use as a last resort” bin--replaced with a period-correct unit I found at the big show. 1 1 Share this post Link to post Share on other sites
Handy Don 17,188 #7 Posted October 2, 2025 4 minutes ago, Mike'sHorseBarn said: These are pricey, but made in USA, and I've never had an issue with one that I've bought. https://www.amazon.com/Standard-Motor-Products-VR219-Regulator/dp/B000O3HYLG From the image, note the different terminal configuration. Share this post Link to post Share on other sites
Mike'sHorseBarn 3,647 #8 Posted October 2, 2025 Just now, Handy Don said: From the image, note the different terminal configuration. It is, but it will work. The only terminal that is missing is the L terminal, which doesn't really matter because you can run that wire directly off the BAT terminal. 4 Share this post Link to post Share on other sites
ebinmaine 80,075 #9 Posted October 2, 2025 2 hours ago, Mike'sHorseBarn said: These are pricey, but made in USA, and I've never had an issue with one that I've bought. https://www.amazon.com/Standard-Motor-Products-VR219-Regulator/dp/B000O3HYLG FYI. There are some of those on sale on eBay right now for about $44 out the door to you. New open box. I ordered one to see what they look like. 1 Share this post Link to post Share on other sites
Handy Don 17,188 #10 Posted October 2, 2025 2 hours ago, Mike'sHorseBarn said: It is, but it will work. The only terminal that is missing is the L terminal, which doesn't really matter because you can run that wire directly off the BAT terminal. Yep, I had one of these. Just pointing it out so there is no confusion due to the different-than-probably-expected configuration. 😁 ✅ Share this post Link to post Share on other sites
Mike'sHorseBarn 3,647 #11 Posted October 2, 2025 1 hour ago, ebinmaine said: FYI. There are some of those on sale on eBay right now for about $44 out the door to you. New open box. I ordered one to see what they look like. Thanks for that tip, i just ordered one for the shelf lol 1 Share this post Link to post Share on other sites
kpinnc 18,851 #12 Posted October 3, 2025 (edited) 7 hours ago, ebinmaine said: FYI. There are some of those on sale on eBay right now for about $44 out the door to you. New open box. I ordered one to see what they Can you link me the one you are talking about? All I see have different mounting brackets. Edited October 3, 2025 by kpinnc Share this post Link to post Share on other sites
ebinmaine 80,075 #13 Posted October 3, 2025 8 hours ago, kpinnc said: Can you link me the one you are talking about? All I see have different mounting brackets. PM sent Share this post Link to post Share on other sites
