Krice58 138 #1 Posted October 1, 2025 Got an M12 and k301 off of some beat up 312-8s. Looking at a C100 8 speed, it’s my understanding that at least the K301 should both right up with no modifications. Is this the case? What about the M12? Thanks! 1 Share this post Link to post Share on other sites
pfrederi 19,463 #2 Posted October 1, 2025 M-12 will bolt on but will require re wiring to work on C-100 4 1 Share this post Link to post Share on other sites
ri702bill 10,965 #3 Posted October 1, 2025 And a different ignition switch too. You would be going from battery ignition to magneto ignition... 1 1 Share this post Link to post Share on other sites
Lee1977 7,499 #4 Posted October 1, 2025 (edited) The K 301s on 312's may have a different charging system. I know my 1985 312-8 has a 3 amp. charging system with AC lights. What I see in 1986 electric wiring diagrams the 1986 is the same. Edited October 3, 2025 by Lee1977 1 1 Share this post Link to post Share on other sites
953 nut 63,548 #5 Posted October 1, 2025 4 hours ago, pfrederi said: M-12 will bolt on but will require re wiring to work on C-100 1 hour ago, ri702bill said: And a different ignition switch too. You would be going from battery ignition to magneto ignition... Adding a kill relay is all that would be needed for the Magnum swap, everything else would remain the same. 14 minutes ago, Lee1977 said: The K 301s on 312's may have a different charging system. I know my 1985 312-8 has a 3 amp. charging system lights. What I see in 1986 electric wiring diagrams the 1986 is the same. Good point, the engine Spec Number would be the best way to find out. 1 Share this post Link to post Share on other sites
