Pullstart 71,259 #1 Posted September 30, 2025 Check this out! It all starts with a clothes hanger 1 4 Share this post Link to post Share on other sites
lynnmor 9,040 #2 Posted September 30, 2025 That type of machine was available for many years. I took a pair of heads to a shop and after they were sanded I could get a .012" feeler gauge between them when placed face to face. I all depends on how flat the platen is. Just because it is glass doesn't mean that it is flat. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #3 Posted September 30, 2025 2 hours ago, lynnmor said: I could get a .012" feeler gauge between them when placed face to face Ok, school me please ‘cause I’m now really curious! Of course .000” would be perfect in this case, but maybe face-to-face isn’t the best way to test (additive and subtractive variances and all that...) BUT, what is a reasonable tolerance for a head measured from dead flat? Share this post Link to post Share on other sites
ri702bill 13,068 #4 Posted September 30, 2025 (edited) OK kids, my 2 cents. First - that is not a milling process. It is sanding. Milling the mating surface of a head usually involves precision fixturing and linear motion of either the part or the head of a rotary flycutter. No switching belt grits from cut to clean to finish pass as most of us do with K series heads?? Material removal is one thing, but what is the surface finish that is the end result?? This ties in with Don's reply - part of the tolerance will be taken up by the microscopic peaks & valleys. The rougher the surface, the more of the allowable tolerance is eaten up.... Edited September 30, 2025 by ri702bill 2 1 Share this post Link to post Share on other sites
lynnmor 9,040 #5 Posted September 30, 2025 59 minutes ago, Handy Don said: Ok, school me please ‘cause I’m now really curious! Of course .000” would be perfect in this case, but maybe face-to-face isn’t the best way to test (additive and subtractive variances and all that...) BUT, what is a reasonable tolerance for a head measured from dead flat? Of course I could have checked the heads on a surface plate using feeler gauges or an indicator, but I did a quick check right at the machine shop and handed them right back. They were better than that before he sanded them. He has a proper milling machine that was used to get them right. These cast iron heads use a thin metal gasket so they need to be right. It is surprising just how bad a head can be and still be pulled down with the head bolts, but I didn't want to be a test case. I have read various tolerances for aluminum, iron, 6 cylinder, etc. but there is no excuse to have the flatness out more than a couple of thousandths. 1 1 1 Share this post Link to post Share on other sites
Handy Don 17,474 #6 Posted September 30, 2025 47 minutes ago, ri702bill said: The rougher the surface, the more of the allowable tolerance is eaten up.... Yeah, I can see that. During one of my summer jobs I was given grunt work in a quality control department--measuring surface roughness on ceramic high-voltage insulators. We used a clever gadget that we ran across the surface--it had a phonograph needle and a wheel in a housing. The device calculated “frequency vs. speed” as a numerical index that we compared to the required specs for that piece. Why, you might ask? Turns out that too rough a surface allowed moisture and dust to accumulate which let electricity “short circuit” across the insulator. Not good. 1 2 Share this post Link to post Share on other sites
ri702bill 13,068 #7 Posted September 30, 2025 "Profilometer". to measure the profile of a surface.. 2 Share this post Link to post Share on other sites
adsm08 5,149 #8 Posted September 30, 2025 8 hours ago, Handy Don said: Ok, school me please ‘cause I’m now really curious! Of course .000” would be perfect in this case, but maybe face-to-face isn’t the best way to test (additive and subtractive variances and all that...) BUT, what is a reasonable tolerance for a head measured from dead flat? From the shop manual of the 96 Ford Explorer, spec sheet for the 4.0 V6: 0.003 in any 6 inches — 0.006 overall. 1 Share this post Link to post Share on other sites
