hotajax 230 #1 Posted September 28 Can I please request some assistance on this? I have the belt, however I MAY have lost a part. On a 1986 side discharge 48-in mower deck, what is the order of assembly down at the part that holds 2 pulleys - one that is flat and one for a V-groove? I checked my Wheel Horse manual, and it shows a spacer to the outside of the flat idler. I only have one spacer that is about 5/8" and I thought that went between the two pulleys to keep them from touching as they go in opposite directions. With what I have now, that pulley cover rubs against the belts and doesn't tighten on the threaded shaft. Are there supposed to be two spacers on that shaft? Thanks a lot. Can really use some help. Share this post Link to post Share on other sites
Lee1977 7,464 #2 Posted September 28 (edited) The mule drive belt is 1/2" x103 or WH 102742. There are two spacers on the mule drive just from my bad memory the 5/8" goes on the outside next to the cover. The other spacer is wider around 3/4" goes between the inside v-groove and the flat idler. The spacer is WH 101734, Partstree has it for $5 .49. Edited September 28 by Lee1977 2 Share this post Link to post Share on other sites
ri702bill 10,789 #3 Posted September 28 On one Mule drive I picked up, the inner spacer was tack welded in place and it looked to be done at the Factory... Share this post Link to post Share on other sites
hotajax 230 #4 Posted September 28 52 minutes ago, Lee1977 said: The mule drive belt is 1/2" x103 or WH 102742. There are two spacers on the mule drive just from my bad memory the 5/8" goes on the outside next to the cover. The other spacer is wider around 3/4" goes between the inside v-groove and the flat idler. The spacer is WH 101734, Partstree has it for $5 .49. Lee, do you happen to know the part number for the other spacer? I could probably get away with using a series of fat washers, too. Thanks for your help, gents. Share this post Link to post Share on other sites
Lee1977 7,464 #5 Posted September 28 1 hour ago, hotajax said: Lee, do you happen to know the part number for the other spacer? I could probably get away with using a series of fat washers, too. Thanks for your help, gents. The longer spacer is the one I gave the number for.. The deck I checked was an 80's they change number on the same part on newer parts.. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #6 Posted September 28 https://www.partstree.com/models/05-48ms05-toro-48-side-discharge-mower-deck-1986/side-discharge-mower-42-in-107-cm-vehicle-identification-number-05-42ms04-6/ Share this post Link to post Share on other sites
hotajax 230 #7 Posted September 28 1 hour ago, Lee1977 said: The longer spacer is the one I gave the number for.. The deck I checked was an 80's they change number on the same part on newer parts.. Thanks bud, but.... being a good Navy man, I owe you a sixer if you lived near me. But I found the short spacer, all is cool now. Thanks very much for your help. The short spacer rolled down the driveway, like 30 feet from where I was working. What a dope, eh? 1 Share this post Link to post Share on other sites
Handy Don 15,371 #8 Posted September 29 2 hours ago, hotajax said: The short spacer rolled down the driveway, like 30 feet I've had dropped stuff roll away, but wow! 1 Share this post Link to post Share on other sites
