stevasaurus 23,517 #26 Posted October 8 This is a 3 speed...just pictures. This one is a 4 speed with videos. The two transmissions are the same except where the brake drum mounts, and where the involved shafts then move too. 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,185 #27 Posted October 9 It is all back together! Shifts through all gears and spins very good. We hooked up the drill toit and filled it up with oil and ran it for about 10 minutes with the drill. Going to let all of it settle overnight, and drain it out, then put it back into the tractor and put the steering colum and all of that back on and then hopefully the engine will be easier 🤞 IMG_2314.mov 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,185 #28 Posted October 11 Got the transmission,belt,and brake pedal and parking brake all hooked up and bolted on. Also put the steering tower on. Waiting for the shifter bolts to come in. Hopefully Sunday I will make a new thread for working on the engine part. Will post pictures tommorow. Share this post Link to post Share on other sites
Easton Rich 770 #29 Posted October 11 Great job! It has nice patina! Share this post Link to post Share on other sites
TonyToro Jr. 2,185 #30 Posted October 11 13 minutes ago, Easton Rich said: Great job! It has nice patina! Thank you. Hopefully all the mold from being under a tree will come off and clean up good even though it was repainted. Also going to have to do some paint removal as they just painted over a lot of stuff (For example the lift rod handle or the lift adjuster knob). Share this post Link to post Share on other sites
Easton Rich 770 #31 Posted October 11 I saw why you were interested in a new dash. They must not know what masking tape is 😂 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,185 #32 Posted October 11 19 minutes ago, Easton Rich said: I saw why you were interested in a new dash. They must not know what masking tape is 😂 I completely forgot to send you those pictures! I will do that tommorow. Share this post Link to post Share on other sites
