C100_NY 1 #1 Posted September 26, 2025 My c100 wheelhorse transaxle oil has recently been changed. I use 80w-90 gear oil. I check the oil the other day and it has a ton of small bubbles in it that will not go away. The tractor has set overnight to let bubbles calm and they will not go away? Also the tractor has some minor trouble slipping into 3rd gear. But i know that is expected with old tractors. Share this post Link to post Share on other sites
Achto 32,816 #2 Posted September 26, 2025 1 hour ago, C100_NY said: has some minor trouble slipping into 3rd gear. I would not be too concerned with the bubbles as long as the oil looks clean. 5 Share this post Link to post Share on other sites
C100_NY 1 #3 Posted September 26, 2025 Thank you. I changed the oil that was in it when i got it. it was fairly dirty. Then mowed the lawn and dropped the oil again and refilled in hopes of getting the majority of the dirty and bad oil out. 1 Share this post Link to post Share on other sites
ri702bill 13,163 #4 Posted September 26, 2025 Did you raise the front about a foot to allow all the gear oil inside get out over the hump inside?? If not, old oil remains to get mixed with the new... 2 Share this post Link to post Share on other sites
Ed Kennell 47,554 #5 Posted September 27, 2025 to the Share this post Link to post Share on other sites
JoeM 10,316 #7 Posted September 27, 2025 Maybe the gear oil used has a anti foaming additive problem. For little money, might want to change it again and use a different brand. At least contact the oil mfg. and ask about the problem. 1 Share this post Link to post Share on other sites
C100_NY 1 #8 Posted September 27, 2025 I am thinking about trying some john deere brand gear oil. I used coastal which is a cheaper brand. Share this post Link to post Share on other sites
peter lena 10,082 #9 Posted September 27, 2025 @C100_NY agree with @ri702bill 0n the possible retention of old oil mixture in front of trans , went over to hi mileage , atf fluid as a flushing agent , also raise my front end for better draining , also recommend getting some road time on that oil flush , have any CUL DE SACS in your area ? put some miles on that flushing , an empty road , or housing area , lets you use every gear / range , picture that oil flinging around to every area , also replace the shift boot , grease the underside of it? helps it slide over the irregularities' on top of the gear box , like a tye wrap on the shifter rod , just ABOVE THE boot holding spot ? the spot it stays at is what you want to hold , also like a climbing gear oil , read specs . regularly check over my horses after use , top up fuel , sta bil in gas , check engine oil , gear oil , basic stuff , pay attention to what its telling you . do that after EVERY USAGE , pete Share this post Link to post Share on other sites
JoeM 10,316 #10 Posted September 27, 2025 (edited) 1 hour ago, C100_NY said: I used coastal which is a cheaper brand I have used it and had no issues. Coastal is a Warren Oil Co. their reputation is pretty good. web site https://www.warrenoil.com/ourproducts/Coastal80W-90GL-5-d Edited September 27, 2025 by JoeM Share this post Link to post Share on other sites
