meadowfield
Ultimate basket case 400
meadowfield
Not super rare, but equally they only surface once every six months and there’s a queue waiting to grab them!
I managed to acquire a suburban 400 from a young lad who bought it then realised he couldn’t do anything with it!
Had a very large Briggs engine fitted, a VW Beetle steering box and too many hacks to mention.
he nabbed the narrow rears and left me with the rest!
gearbox full to the brim with water!
Interesting stretch chassis to take a Briggs engine.
lots of chassis patching!
rolling.....
making a new hoodstand
steering gears - same size and ratio as the original - but will outlast them!
looking more like it
onto that gearbox
it was a mess, all the bearings were gone!
they had chopped the bottom of the casing for some reason
nearly together - amazon packaging to the rescue as a gasket :D
done - with a modifed C series shifter
onto the brake drum - I turned down and old cast pulley.
reamed the inside to 3/4"
all done - just the pedal and linkage to sort....
Ewan very kindly fired up the forge and made me a pedal.
new brake/clutch pedal in place - I thought a bigger bush can't be a bad thing!
donor Clinton engine didn't spark - home made puller did a reasonable job. Points cleaned up and all connections clean - we were in action!
didn't have a pull start either - so made a start cup and used a new tecumseh pull start
finally made two footrests to match. Hard work in the press, but a modified bolster chisel did the job!
Finished - just needs the right steering wheel and hood!
Edited by meadowfield
  • Excellent 4
oldlineman
Very nice work and weld, looks like your right leg won't get cold :lol:
  • Haha 1
meadowfield
thanks - longer pipe is on the way :D
Pullstart
Those welds look better than robotic!  Awesome work!
