Retired Wrencher 6,993 #26 Posted September 25, 2025 On 9/21/2025 at 9:41 AM, WHX?? said: I know a guy that has them for 45 clams. PM me you want his info Wrencher. I always have them on hand since most of my tractors are 60s & SG. Supposedly they are 70 amp switches. You guys and your solenoids ... what's everyone got against ORIGINAL these days! Jim, I wish I would’ve saw this earlier after I went out and bought a solenoid my bad. But I have a 1057 also I might look into that for that tractor. I’ll be working on that starting in the fall so I will save this post when the time comes Share this post Link to post Share on other sites
Retired Wrencher 6,993 #27 Posted September 25, 2025 On 9/21/2025 at 1:21 PM, WHX?? said: This was a po thing on a tractor i restoed. There was a mounting tab on the regulator most don't have tho. I will agree on that the regular I have does not have that tab that goes to the A. Share this post Link to post Share on other sites
pfrederi 21,215 #28 Posted September 25, 2025 2 hours ago, Retired Wrencher said: I will agree on that the regular I have does not have that tab that goes to the A. Some regulator models the A "Armature" terminal is on the bottom of the unit. There are 4 terminals on this type. A on the Bottom with Load Battery Field on the front edge. Share this post Link to post Share on other sites
Retired Wrencher 6,993 #29 Posted September 25, 2025 1 hour ago, pfrederi said: Some regulator models the A "Armature" terminal is on the bottom of the unit. There are 4 terminals on this type. A on the Bottom with Load Battery Field on the front edge. I will look today. Thanks Pfrederi! Share this post Link to post Share on other sites
WHX?? 58,290 #30 Posted September 25, 2025 4 hours ago, Retired Wrencher said: bought a solenoid Not that I have anything against solenoids but for a quick replacement since the heavy wires are there and already somewhat formed. Also if your not into electrical the way some of us are. I have good luck with them and have 60's orginals that work fine. Some have a weak return to run spring. They don't work well on a 1045 or 1055 with non ACR motors. The starter draw is quite abit more when trying to get the motor past the compression stroke and rolling. Even tho the contacts are rated at high amperage they can smoke abit when trying to turn these motors over cold. Big and small block motors with ACR no problems. The guy that has them is a member here but not on anymore I would have to give you his contact info. Share this post Link to post Share on other sites
Handy Don 17,546 #31 Posted September 25, 2025 2 hours ago, WHX?? said: Not that I have anything against solenoids but for a quick replacement since the heavy wires are there and already somewhat formed. Also if your not into electrical the way some of us are. I have good luck with them and have 60's orginals that work fine. Some have a weak return to run spring. They don't work well on a 1045 or 1055 with non ACR motors. The starter draw is quite abit more when trying to get the motor past the compression stroke and rolling. Even tho the contacts are rated at high amperage they can smoke abit when trying to turn these motors over cold. Big and small block motors with ACR no problems. The guy that has them is a member here but not on anymore I would have to give you his contact info. I'll add that the early K181s (as in my 854) are also non-ACR. They retard the spark instead of releasing compression so the starter faces full compression. Share this post Link to post Share on other sites
