Caleb Jones 0 #1 Posted September 15, 2025 Has anyone ever put a 4 inch pulley on the transaxle of a wheelhorse 312-8? I seem to struggle to find the right belt size. I believe the Kohler motor has a 4 inch and there was a 6 or 6.5 on the transaxle. Im thinking I need a79 inch belt but I'm not sure. Does anyone know? Share this post Link to post Share on other sites
Ed Kennell 45,379 #2 Posted September 15, 2025 (edited) to the Caleb If your 312-8 has stock engine and transmission pulleys it should take a 5/8X82" belt. If you want to increase the tractor speed by replacing the stock 7" pulley with a 4"pulley a shorter belt and possibly belt guard modifications may be required to permit proper belt stopping for gear shifting. I buy all my belts at TSC. If they don't fit, you can exchange them for the correct belt. Just keep the belt and sleeve clean for a full refund. Edited September 15, 2025 by Ed Kennell 1 Share this post Link to post Share on other sites
oliver2-44 11,329 #3 Posted September 15, 2025 3 hours ago, Ed Kennell said: to the Caleb If your 313-8 has stock engine and transmission pulleys it should take a 5/8X82" belt. If you want to increase the tractor speed by replacing the stock 7" pulley with a 4"pulley a shorter belt and possibly belt guard modifications may be required to permit proper belt stopping for gear shifting. I buy all my belts at TSC. If they don't fit, you can exchange them for the correct belt. Just keep the belt and sleeve clean for a full refund. Share this post Link to post Share on other sites
JoeM 9,694 #4 Posted September 15, 2025 Someone here had some kind of homegrown formula for every inch of pulley subtract 2 inches of belt???? It was a long time ago when i seen that thread and not sure if it is even accurate. 1 Share this post Link to post Share on other sites
953 nut 64,707 #5 Posted September 15, 2025 2 hours ago, JoeM said: homegrown formula for every inch of pulley subtract 2 inches of belt???? The diameter of the pulley multiplied be 3.14 will yield the circumference of the pulley but the belt generally only contacts half of the circumference, SOOOOOO, for each inch of pulley size change the belt would be 1.57" longer or shorter as the case may be presuming both pullies are relatively close in size. If you were going from a 2" to a 12" pulley that formula would be out the window because more than 50% of the 12" pulley circumference would probably be contacting the belt. With any luck this will clarify rather than confuse the issue. Share this post Link to post Share on other sites
Handy Don 16,063 #6 Posted September 16, 2025 Being a nerd and enjoyer of math, I have collected links to quite a few online calculators, including this one for calculating a belt length around three co-planar pulleys. Of course, with an 8-speed, you have to choose the dimensions of the idler/clutch pulley carefully to a position between fully engaged and fully disengaged. Enjoy! Share this post Link to post Share on other sites
Ed Kennell 45,379 #7 Posted September 16, 2025 (edited) This thread may be of some help in understanding how the clutching system works on these tractors. 310-8 Clutch Problem - Page 2 - Transmissions and transaxles - RedSquare Wheel Horse Forum Decreasing the size of the transmission input pulley may have an effect on the belt brake and the clutch damper. Please be aware the belt must not be moving to engage a gear. Do not force it in gear with the belt or the tractor moving as the grinding will cause serious damage to the gears. Edited September 16, 2025 by Ed Kennell Share this post Link to post Share on other sites
